BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Minimum ramp height to access for oil change?
Studio RSR
      10-31-2020, 11:35 AM   #1
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
From your experience what is the minimum ramp height for oil change on a 2012 and up 328i base model? I am looking at a 6 inch (15cm) ramp for easy drive-on without sliding away. But there is a 9 inch (23cm) ramp for higher clearance, but may be hard to drive on based on some reviews.
rlmesq1038.50
      10-31-2020, 12:33 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Six inches would be a tight squeeze. The only problem with an 8-9" ramp is if you have a front spoiler.
      10-31-2020, 12:37 PM   #3
fe7565
fe7565's Avatar
Thank you Billfitz. I have a factory front-end...a "vanilla" base sedan.
      10-31-2020, 08:34 PM   #4
Logicoeur
Logicoeur's Avatar
993
Drives: F30 335i xDrive
My stock suspension xdrive with Msport bumper can't make it up rhino ramps without boards.
      11-01-2020, 08:16 PM   #5
jsouth
jsouth's Avatar
Drives: 2013 328i
My base 328i drives right up Rhino ramps with no problem.
sspade2466.00
      08-14-2021, 09:46 PM   #6
fe7565
fe7565's Avatar
Changing oil with a portable drive-up ramp of about 7 inches was not a problem. Still some room to spare. I had to do it myself because the commercial quick change places (albeit only $20+) would not allow me to use my own oil/filter, etc. and I am not going to use their generic brands.
      08-15-2021, 04:35 AM   #7
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Rhino ramps work perfect. Literally just used mine for an oil change last night.
fe7565552.50
328i, clearance, oil change, ramp
