03-22-2013, 07:10 PM | #3015 |
Rep 1,894
Hi, I've a semi successful evening coding. At one point I accidentally hit the 'Code Default Values' button, when the iDrive restarted I lost a load of functions inc telephone! Lucky I restored and everything is back in it's right place.
Anyway I wanted to added BMW Live, I followed the instructions that demge01 used (enable ONLINE_BROWSER_LIVE), I get the option and the service starts up but it's taking ages to start. I waited 10+ mins for Live to start and in the end it said: "Current mobile communication network is not supported by BMW Live" , I had my iPhone BT to the car. Anyone know if I need to enabled something else? Thanks. |
03-22-2013, 08:30 PM | #3016 | |
Rep 40,779
03-22-2013, 11:04 PM | #3017 |
Rep 17
Last night I lost power while coding the FEM_01 module, today when I try to read the coding data I get this error:
ransaktions-Report: Aktion: Codierdaten lesen FEM_BODY [40] [ˇˇˇˇˇˇˇ] readCPS o.k. cafd_ffffffff-255_255_255 Fehler: File for "cafd_ffffffff-255_255_255" not found! [C012] I have the original file, how I can restore it? Any help will be appreciated. |
03-22-2013, 11:16 PM | #3018 | |
Rep 40,779
Connect => Read FA => Activate FA => Read VCM => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps. The I-Step (current) is the one you want to match when you select the CAFD from the "Detect CAF for SWE" options (e.g. F020-12-11-502).
03-22-2013, 11:36 PM | #3019 | |
Rep 17
03-23-2013, 04:24 AM | #3020 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
I tryed do it again, reset ECU to VO and change those 3 codes by drop-downs. It's not working. I think it is because of russian localisation... I need a .NCD file from E30 with working passenger SBR to compare with my .NCD file. |
03-23-2013, 07:49 AM | #3021 | |
Rep 40,779
Does this car have factory Comfort Access with the door handle ridges?
03-23-2013, 08:06 AM | #3022 |
Rep 122
03-23-2013, 08:08 AM | #3023 |
Rep 40,779
Sorry, I was thinking of something else.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 03-23-2013 at 08:14 AM.. |
03-23-2013, 08:31 AM | #3024 | |
Rep 40,779
Try adding K-Wort OI12 to your VO under the FA HO-Wort Section, then calculate FP and make sure it appears to the right under Aftermarket_Fitment, then Save FA, Load the FA, then VO Code CAS and FRM.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 03-23-2013 at 08:41 AM.. |
03-23-2013, 08:41 AM | #3025 | |
Rep 122
I haven't an OI12 option in K-Words folder. |
03-23-2013, 09:00 AM | #3026 | |
Rep 40,779
Still, very strange that with all 3 codes aktiv, it does not work. What about adding option 845 to your VO if it is not there, and then VO Coding CAS and FRM?
03-23-2013, 09:02 AM | #3027 |
Rep 490
03-23-2013, 09:06 AM | #3028 |
Rep 122
I have 845 option in VO. SBR is working for driver (acoustic and display warnings), but not for passenger...
03-23-2013, 11:19 AM | #3030 |
Rep 40,779
Very strange. I give up.
03-23-2013, 11:30 AM | #3031 |
Rep 40,779
Are you using Tool32? Which .PRG and job?
03-23-2013, 12:49 PM | #3032 |
Rep 122
I think that problem is relating to probable absence of passenger sensor mat in cars made for Russia (there is not S230A option in VO).
http://en.bmwcats.com/bmw/catalog/F3...cs/65/65_2369/ If I set Sitzpositionssensor_Beifahrer to active I see an error of the passengеr's SRS on iDrive and instrument cluster. |
03-23-2013, 03:36 PM | #3033 | |
Rep 17
I coded the TPM but only see the psi and degrees lables not the values, should I try again? Also the Inband ringing is not working. |
03-23-2013, 03:43 PM | #3034 | |
Rep 40,779
Inband Ringing is phone specific. Not all phones work. |
03-23-2013, 03:58 PM | #3035 | |
Rep 1,892
If they still don't show after that, the you don't have the TPMS sensors and you are SOL. I've only seen in-band ringing on an F30 if you have an iPhone. It does not work on Android. |
03-23-2013, 09:16 PM | #3036 | |
Rep 17
S205A AUTOMATIC GETRIEBE Automatic transmission S216A SERVOTRONIC HYDRO STEERING-SERVOTRONIC S240A LEDERLENKRAD Leather steering wheel S248A LENKRADHEIZUNG Steering wheel heater S249A MULITFUNKTION FUER LENKRAD Multifunction f steering wheel S258A BEREIFUNG MIT NOTLAUFEIGENSCHAFTEN Tire with run-flat functionality S2DXA 17"LM RAEDER STERNSPEICHE 394 BMW LA wheel, Star Spoke 394 My phone is an iPhone, but I noticed that there is also an Inband_Ringing function on the Combox_media that I didn't activate, Will try tomorrow. Thank you |
