04-09-2013, 12:06 AM | #3191 |
Yr1OfD1
107
Rep 900
HU CIC error here.. Error missing cafd. Please help
2015 328i Gran Turismo M Sport
2013 328i XDrive Sedan M Sport 2011 X5 xDrive50i 2009 X5 xDrive 30i 2008 135i Coupe |
04-09-2013, 12:23 AM | #3192 |
Rep 2,937
Drives: 2013 Estoril 328i M Sport
Many thanks for the clarification!
04-09-2013, 10:10 AM | #3193 |
Rep 40,789
You really need newer PSdZData full, but it may be possible to get by with just adding the CAFD to your existing PSdZData CAFD library.
What is the CAFD file name you need?
04-09-2013, 10:18 AM | #3194 | |
Yr1OfD1
107
Rep 900
cafd_000000f9-007_003_024 Fehler: File for "cafd_000000f9-007_003_024" not found! [C012] |
04-09-2013, 10:23 AM | #3195 |
Rep 40,789
PM sent.
04-09-2013, 12:56 PM | #3198 | |
Rep 40,789
What version of E-Sys and PSdZData are you using?
04-09-2013, 01:07 PM | #3199 | |
Yr1OfD1
107
Rep 900
C:\ESysData\psdzdata\swe\cafd do i need to put also here? C:\ESysData\SWE E-Sys version is 3.18 i am downloading the 3.22 that you gave right now |
04-09-2013, 01:16 PM | #3200 | |
Rep 40,789
The issue is your PSdZData can not support the new CAFD. What version of the PSdZData did you inject the CAFD into?
04-09-2013, 01:57 PM | #3201 |
Yr1OfD1
107
Rep 900
04-09-2013, 02:02 PM | #3202 |
Rep 40,789
Yes, 47.5 binaries are too old.
I do hope you mean 49.1.
04-09-2013, 02:05 PM | #3203 |
Yr1OfD1
107
Rep 900
04-09-2013, 03:29 PM | #3204 |
Rep 226
So I coded my 2013 F25 and I think I accidentally turned off the comfort opening of the windows and sunroof by the fob can someone tell me the code to turn it back on? I forgot what I touched on Saturday.
04-10-2013, 12:20 AM | #3205 |
Rep 1,622
Do you guys recommend doing all coding for the F10 M5 using Windows 8 or Mac OS X ML?
Also, what application versions should I be using? Still should be using ESYS 3.18.4 with 46.3 data files? And what is PSdZData? I didn't read anything about that in the first post. Trying to get all info I need together so when I get my car I can bang this out. Thanks in advance.. appreciate the help!!
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
04-10-2013, 12:48 AM | #3206 | |
Rep 1,622
I read that F10 function values are the same as F25. There is one fvalue for key fob and one for comfort access. Do both not work? Also note that both (fob and CA) require an additional value to be set.. See the below: Both (fob and comfort acc) require "ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN" set to aktiv. Key Fob (closes mirrors + windows + moon roof thru fob) Module: CAS Section: 3003 FH MASTER Function Value: KOMFORTSCHLIESSUNG_FB New Value: aktiv / Werte=01 Default: nicht_aktiv / Werte=00 Comfort Access (closes mirrors + windows + moon roof thru comfort access) Module: CAS Section: 3003 FH MASTER Function Value: KOMFORTSCHLIESSUNG_PA New Value: aktiv / Werte=01 Default: nicht_aktiv / Werte=00 Let me know if that works for you. I provided this info directly off the attached F10 cheat sheet (which should be the same for F25).
04-10-2013, 09:30 AM | #3207 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
I have 3.22 running psdzdata 49.1 on another laptop running Windows 7. |
04-10-2013, 09:33 AM | #3208 | |
Rep 1,976
Everything on the top list is possible but not the 6NH to 6NK - you definitely need nav for that. If your car had 609 (Nav) it will automatically have a combox since it's needed for the voice control; you will just need to unlock it via coding. |
04-10-2013, 09:35 AM | #3209 |
Rep 1,130
Drives: '16 340i AW MSport
04-10-2013, 10:54 AM | #3210 |
Rep 286
6NH without Combox
Hi everyone,
Very new to the forum and F30. I struck a good deal on a 2012 320i here up north in Canada (Brand new from BMW). Previously had a 323i (E90) After reading 3000+ posts regarding coding i understand i cant do much with my HU/iDrive other than some basic coding. What are my options to add a combox? I looked under the boot and it doesn't have one. Is it as simple as plug and play? or do i have to do any wiring. Friend working at BMW can get me any part with 15-20% discount. However i have also need the combox unit for $330, but it doesn't specify anything in regard to wiring. Any advice? Thanks Vithy |
04-10-2013, 11:38 AM | #3211 | |
Rep 40,789
VO Code: Connect => Read FA (VO) => Activate FA (VO) => Read VCM (SVT) => Right-Click on ECU CAS (the ECU itself not the underlying CAFD) => Select CODE. Repeat for FRM module.
04-10-2013, 11:41 AM | #3212 | |
Rep 40,789
Ideally you should use E-Sys 3.22.5 and the latest PSdZData version available (i.e. 49.1), but it may be possible to use older E-Sys and or PSdZData depending on what version of ISTA/P was last used to program the car.
