12-01-2013, 01:10 PM | #5172 |
Rep 40,795
I need to connect with TeamViewer and see what is happening.
12-03-2013, 05:09 AM | #5174 |
Rep 40,795
PM sent.
12-03-2013, 01:14 PM | #5175 |
Rep 11
adding 544
Hi Shawn...
I have 249 and 255 but no cruise control buttons.I will buy the part and add 544 to FA.After that which ECU's I need to VA code? Thanks for everything you've done for us...... |
12-03-2013, 01:18 PM | #5176 |
Rep 40,795
I just went though this last week, and we ended up coding everything except DME to make CC work. It was just easier.
12-03-2013, 01:31 PM | #5177 |
Rep 11
12-03-2013, 01:45 PM | #5178 |
Rep 40,795
Except DME. But this is an easy thing. You can do the whole car in 10 minutes.
12-03-2013, 08:28 PM | #5179 | |
Rep 16
I have a F20 (VIN: E931474), I want to retrofit NBT. I brouht a used NBT head unit from 320d (VIN: KP41538). I add the NBT activtor first, then connect the NBT unit, I check the FSC as below: --> Read the state from "1" ECU(s) <-- HU_NBT[DiagAddress=99(0x63)] WBA3L11080KP41538 RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 158(0x9E) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 160(0xA0) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 222(0xDE) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 111(0x6F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 159(0x9F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 156(0x9C) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 229(0xE5) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 169(0xA9) UpgradeIndex 3(0x03) SWTType SWTshort FSCStatus not available FSCCertStatus not available Then I add 609, 6AK,6NR,6NS, delete 663. code ECU with esys3.23.4+50.4. code work is successful with no error. after code, I check the FSC. 'AppID 160(0xA0)' is gone, replaced by 'AppID 161(0xA1)'. because my NBT display cable has not arrived, so I rewire the orginal display cable. but it don't work, so i can not get information from CID. But I press the telephone button on the steering wheel, the cluster has no response. my cluster is not expanded. what is below AppID mean. why AppID 160 became AppID 161? EPS[DiagAddress=48(0x30)] AppID 131(0x83) HU_NBT[DiagAddress=99(0x63)] AppID 222(0xDE) AppID 229(0xE5) AppID 161(0xA1) AppID 160(0xA0) and below is form the old hu_entry, what is below AppID mean. HU_ENTRY[DiagAddress=99] AppID 129 AppID 130 AppID 143 AppID 144 AppID 27 And the NBT display cable is different with the old cable, do you have the rewire suggestion? thanks! Last edited by zev; 12-03-2013 at 10:04 PM.. |
12-03-2013, 10:49 PM | #5180 |
Rep 40,795
I don't recognize any of these AppID's you show for HU_CHAMP, except 27, which is a 1B Navigation Enabler Code for CIC not CHAMP:
HU_ENTRY[DiagAddress=99] AppID 129 (0x81) AppID 130 (0x82) AppID 143 (0x8F) AppID 144 (0x90) AppID 27 (0x1B) - Navigation Enabler (CIC) Frankly, I don't know where you got this list from, but they did not come from your Head Unit, as I just checked, and the only FSC Code issued to E931474, was E931474_00830001.fsc, which is for AC Servotronic EPS. These are your new NBT ones: HU_NBT[DiagAddress=99(0x63)] AppID 222(0xDE) - Navigation Enabler (NBT) AppID 229(0xE5) - Lap Timer AppID 161(0xA1) - Navigation Application - S609A - Asia (NBT) AppID 160(0xA0) - Navigation Application - S609A - ECE/US (NBT) It changed from 160 Navigation ECE/US to 161 Navigation Asia because it was smart enough to know when you flashed it, based on the Country Controller and Language Options in your VO, that you needed Navigation Application for Asia and not Europe where the used NBT originated. Be glad it did, else you would not be able to load any Asian Map.
12-03-2013, 11:00 PM | #5181 | |
Rep 16
this is FSC status for EPS, why RootCertStatus & SigSCertStatus are 'not available'? --> Read the state from "2" ECU(s) <-- EPS[DiagAddress=48(0x30)] WBA1A3100CE931474 RootCertStatus not available SigSCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 131(0x83) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available HU_NBT[DiagAddress=99(0x63)] WBA3L11080KP41538 RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications |
12-03-2013, 11:05 PM | #5182 | |
Rep 16
that champ has 6NH, and below two FSC existed in the champ. may be it is for USB and bluetooch function. AppID 129 (0x81) AppID 130 (0x82) and do you knoe how to rewire the champ display cable to NBT cable? I am looking for NBT cable pinout diagram, nothing got yet.... |
12-03-2013, 11:15 PM | #5184 | |
Rep 40,795
Maybe Root and Sig Certs are not needed on EPS module.
12-03-2013, 11:20 PM | #5185 | |
Rep 40,795
Are you sure they were in the Head Unit and not another ECU like DME maybe? It did not have these other ones you listed though: AppID 143 (0x8F) AppID 144 (0x90) AppID 27 (0x1B) - Navigation Enabler (CIC) Sorry, I have no idea on the wiring issue.
12-04-2013, 12:43 AM | #5186 | |
Rep 16
could you send me the F294181_00810001.fsc and F294181_00820001.fsc and .der file, I deactivated the FSC by mistake, not familiar with Esys that time... zev.zhou#gmail.com Last edited by zev; 12-04-2013 at 12:55 AM.. |
12-04-2013, 02:43 AM | #5187 |
Rep 40,795
PM sent.
12-04-2013, 06:00 AM | #5188 |
Rep 40,795
I figured out F294181_00810001.fsc and F294181_00820001.fsc:
Entry Radio Head Unit: Media Player = 0081
12-04-2013, 06:23 AM | #5189 |
Rep 16
Hi Shawn, I just put the F294181 champ back to my E931474 with pnp adapter, add VO 6NH and code. and the fsc status as below: --> Read the state from "1" ECU(s) <-- HU_ENTRY[DiagAddress=99(0x63)] WBA3D32030F294181 RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 129(0x81) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 130(0x82) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus cancelled FSCCertStatus accepted ---------- now I can play music from USB, but the Bluetooth handfree is not available. so AppID 129(0x81) should be USB music, and AppID 130(0x82) should be Bluetooth handfree. But as you can see, the AppID 130 FSCStatus is canceled. This should be my mistake operation before. How to upgrade the canceled FSC? I tried to upgrade 0x82 FSC as you said, it is failed. I have decod FSC with http://4mhz.de/b64dec.html |
12-04-2013, 06:29 AM | #5191 | |
Rep 40,795
You are screwed on 82. Once an FSC Code is "Cancelled", a new one must be ordered from special department at BMW as the only way to Import and Activate a replacement FSC Code on top of the "Cancelled" one is if the replacement one has a newer creation date.
12-04-2013, 06:41 AM | #5192 | |
Rep 16
Got it, thank you very much. I think I can handle the NBT retrofit now. thank you very much! where can I buy FSC? In China, BMW dealer have no retrofit service. |
