06-10-2015, 02:28 AM | #1 |
Rep 40
F30 Welcome Light
Hi,
I have coded fog lights for welcome like following, FEM_BODY 3063 MAPPING_NEBELSCHW_L_PART_OF_WL, Soft_On FEM_BODY 3063 MAPPING_NEBELSCHW_R_PART_OF_WL, Soft_On it's working. Also I want to open front left/right turn signals and Left/Rgiht Mirror turn signal at same time for welcome like following. Actual I had previously it. But this is deleted after CC coding. I have searched on the internet but I couldn't find the coding. How can I code turn signals for wlecome? Thanks in advance |
06-10-2015, 05:12 AM | #2 |
Rep 54
To code in all the turn signals as a part of your welcome lights, code the following: In FEMBODY: 3062 > mapping_blinken_v_l_part_of_wl > hard_on - (left turn signal) 3063 > mapping_blinken_v_r_part_of_wl > hard_on - (right turn signal) 3062 > mapping_blinken_z_l_part_of_wl > hard_on - (left mirror turn signal) 3062 > mapping_blinken_z_r_part_of_wl > hard_on - (right mirror turn signal) Note: There is no/little difference between soft_on and hard_on for these two sets of lights, so i have just left them as "hard_on". |
Mental1.50 |
06-10-2015, 06:55 AM | #3 | |
Rep 40
Thank you for help. I will try this evening and inform. Last edited by bryan06; 06-10-2015 at 08:01 AM.. |
06-10-2015, 02:13 PM | #4 | |
Rep 40
I have tried which your shared code, it's working. Thank you again |
06-10-2015, 04:53 PM | #5 |
BMW Fanatic
331
Rep 1,076
Anyone know how to turn on the xenons when unlocking the car? That would be an amazing feature.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
06-10-2015, 05:22 PM | #6 | |
Rep 54
In FEMBODY 3062: Mapping_abblendl_L_part_of_wl > hard_on Mapping_abblendl_R_part_of_wl > hard_on My car has ordinary halogens fitted, but the coding should be similar. Let me know if that works for you! If not, there must be another code to get them to turn on. EDIT: Forgot to mention that this code turns on my low/dipped beams, so it should work for your xenons too. Last edited by re4ryu; 06-10-2015 at 05:29 PM.. |
04-04-2017, 01:05 PM | #7 | |
Rep 1,383
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
04-05-2017, 11:58 AM | #8 |
Rep 962
Is your light switch in the Auto position?
04-05-2017, 04:29 PM | #9 |
Rep 1,383
Headlights? If so yeah
Edit: Ahhh! Went down to my car to double check, the dealer had turned automatic lights off during the service (that day when I coded it). So it's working now.. thanks man!
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 04-05-2017 at 05:50 PM.. |
07-28-2017, 03:27 AM | #12 | |
Rep 938
ETA....just realised you have an F32....bugger!
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
07-28-2017, 03:08 PM | #13 |
Rep 21
01-08-2018, 03:22 PM | #15 |
Rep 308
Soft ON = Fade ON
Hard ON = No Fade
2017 F31 328d xDrive
M Sport M Performance |
CharlieF5767.50 |
08-06-2018, 06:44 AM | #16 | |
Rep 7
Did you try this on your Xenons ? Regards |
11-06-2021, 02:57 PM | #18 |
Rep 50
What do you need to do in the car's latest software (!) To be able to activate the LED fog lights with welcome light (not series, but added to the equipment with the code VO, previously halogen). I have E-SYS 3.27.1 with the latest PSdZData and after coding these standard codes (before the update the cars worked) it does not work. In E-Sys set MAPPING_NEBELSCHW_L_PART_OF_W to soft on, and additionally checked with bimmercod how it looks and:
I suspect that you need to change the Welcome Light cornering light code, not fog light as it was before, but which code in e-sys? I have a free version of Bimmercode and if the app "sees" correctly that it is not coded, maybe it will be able to encode it effectively? |
11-30-2021, 09:22 AM | #19 |
Rep 2
Hello. I have a 4 series with Adaptive LEDs (pre LCI) from factory.
I want to have low beam welcome lights at night when i unlock the car. Now i only have the halos light up in day/night when i unlock the car. I tried looking everywhere and 3 people tried coding but couldn't figure it out. On some places i found that only the normal LED or Xenons can do this, not the Adaptive LED. |
