10-11-2014, 04:44 PM | #7415 |
Rep 187
The heating of the rear window is temperature controlled i believe. Therefore if its 15 degrees Celsius outside, removing condensation goes really slow. Any idea how to code the temperature of the heating element?
10-12-2014, 12:41 PM | #7418 |
Rep 40,868
PM sent.
10-12-2014, 12:43 PM | #7419 | |
Rep 30
Launch Control
And could someone pm me the right I-step firmware version to flash the EGS module please (second question)? I have E-sys 3.24.3. Thanks |
10-12-2014, 02:39 PM | #7420 | |
Rep 40,868
Use the latest 53.5 firmware. PM sent.
10-12-2014, 03:39 PM | #7422 |
Rep 40,868
PM sent.
10-12-2014, 03:48 PM | #7423 |
Rep 50
I am trying to code BMW 328i from USA to ECE.
How important is parameter in FAList->FZAuftrag->Type->Typshlussel. In my car this looks like this: In google I found list of codes, separate for USA, Europe, UK, Japan etc. http://www.bmwarchiv.de/e-code/f30.html 3A51 328i Limousine N20B20O0 180kW Heckantrieb links Europa 3A52 328i Limousine N20B20O0 180kW Heckantrieb rechts Europa 3A53 328i Limousine N20B20O0 180kW Heckantrieb links USA 3A54 328i Limousine N20B20O0 180kW Heckantrieb links China 3A55 328i Limousine N20B20O0 180kW Heckantrieb links Europa 3A56 328i Limousine N20B20O0 180kW Heckantrieb rechts Europa 3A57 328i Limousine N20B20O0 180kW Heckantrieb links USA 3A58 328i Limousine N20B20O0 180kW Heckantrieb rechts Malaysia 3A59 328i Limousine N20B20O0 180kW Heckantrieb links Russland Is coding car form USA to ECE need Typshlussel change ? |
10-12-2014, 03:53 PM | #7424 |
Rep 30
10-12-2014, 03:59 PM | #7425 |
Rep 40,868
It is critical to set Typshlussel = xxxx correctly.
What is your factory ECE Typshlussel?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 10-12-2014 at 04:04 PM.. |
10-12-2014, 04:05 PM | #7426 |
Rep 50
10-12-2014, 04:32 PM | #7427 | |
Rep 40,868
I don't think your list is correct though as I am pretty sure: 3A55 = F30 325I ECE LL (3A55) [from=0309] 3A57 = F30 328I US LL (3A57) [from=0309] I think you need to use: 3A71 = F30 328I ECE LL (3A71) [from=0309]
10-12-2014, 05:02 PM | #7428 | |
Rep 50
In Vin number is part of Typshlussel, my car vin is: WBA3A5G58. I found a europe BMW 328i vin number: WBA3A51020FZ99737 in vin decoder: Model description: 328i Market: Europa Type: 3A51 E-Code: F30 Chassis: Limousine Steering: links Engine: N20B20O0 - 2,00l (180kW) Drive: Heckantrieb Transmission: automatisch Production date: 02.11.2011 |
10-12-2014, 07:38 PM | #7429 |
Rep 40,868
You are correct. So, the BMW database I am using must have a mistake in it.
10-13-2014, 06:27 AM | #7431 |
Rep 40,868
PM sent.
10-13-2014, 11:35 AM | #7433 |
Rep 40,868
PM sent.
10-13-2014, 01:38 PM | #7434 |
Rep 187
FEM_BODY-> 30D0 remotecontrol, 13 -> Funktionen-> RC_default_IDG_3rd_button_short
It looks like you can programme 2 opening bootlid, 3 panic alarm, or 4 follow me home. Medium and long passing of 3rd button on the remote are programmed to open the bootlid. Has anyone tried to program to follow me home with the remote? Edit: or anyone tried RC_ENABLE_CONFIG_BUTTONS. This should activate 'configuration of the 3rd button via the idrive menu' Last edited by MdW86; 10-13-2014 at 01:53 PM.. |
10-14-2014, 09:54 AM | #7435 |
Rep 1,573
has anyone been able to figure out coding for the "welcome lighting" ?
I hate that it turns into a warm blue once I open the door...I want to keep it cold blue
2015i Cadillac Escalade ESV
10-15-2014, 09:01 AM | #7436 |
Rep 231
Hi Shawn,
I just started coding for the first time and am using the 53.3 data which you sent me awhile back. Since then my car had the MPPK installed and the dealership reset/updated my system. Can I continue to use 53.3 or should I upgrade to 53.5? (Running E-Sys 3.24.3) If it's the latter can you PM me the updated version? Thanks in advance! |
