BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 2013 335xi spacers
      10-24-2013, 11:22 AM   #1
Medal
Medal's Avatar
480
Drives: 2021 M3C
2013 335xi spacers
Little help here all would be great:
I'm looking at 10mm spacers for the front and 15mm for the rear for my winter set up of the stock 403m wheels. Can someone please tell me what size lugnuts I need to ensure I order with these spacers?
Thanks.
      10-24-2013, 11:33 AM   #2
AtlantaDude
Just enjoying my time
AtlantaDude's Avatar
Drives: 2007 BMW E92 335i - Sold
Measure your standard lugs from the beginning of the thread, and add the amount of the spacers, you'll then have your new lug length that you need. Keep in mind, you'll need to ID if your lugs have conical heads or flat heads. I believe most BMWs are conical. Hope that helps.
Current - 2022 Rivian R1T, 2021 Ducati Streetfighter V4S, 1969 Chevy C10
Sold - 2018 Tesla Model 3 Performance
Sold - 2007 E92 335i
If speed is death, then buy a Honda and live forever
      10-24-2013, 11:36 AM   #3
Medal
Medal's Avatar
480
Drives: 2021 M3C
Thanks but I'm trying to not have to do that....I'm hoping someone else here has already used these spacer sizes and can tell me what is needed. I was told 28mm for the 10mm spacers and 35mm for the 15mm spacers, can anyone confirm that?
      10-24-2013, 05:13 PM   #4
Medal
Medal's Avatar
480
Drives: 2021 M3C
can anyone help me out?
      10-24-2013, 07:41 PM   #5
bobblehead
bobblehead's Avatar
Drives: warp speed
For M14 x 1.25 ... I believe the std shaft length bolt is 27mm
You can take a long at the Turner's
http://www.turnermotorsport.com/p-44...-mini-r56.aspx
Not cheap ... for 20 pieces, you are looking at about $100.
Apex is cheaper ...
http://www.apexraceparts.com/F30-BMW...M14_p_210.html
So, therefore, you are looking at about low 40mm shaft length for the front and 50mm shaft length for the rear. Or simply the vendor would most likely going to sell you the 50mm shaft length as standard extended wheel bolts to make it uniform for all wheels.
      10-26-2013, 07:07 PM   #6
Medal
Medal's Avatar
480
Drives: 2021 M3C
Apex is cheaper ...
Ok thanks bro, I'll just give turner a call since they are in my back yard. I really appreciate it!
      10-26-2013, 08:02 PM   #7
bobblehead
bobblehead's Avatar
Drives: warp speed
glad to help in any way.
