10-06-2017, 12:50 PM | #23 |
Rep 216
10-07-2017, 11:08 AM | #25 |
Rep 216
Yes, but with some extra work.
Unlike the f32, our f36s have extra x-bar framework underneath the car. I will upload a picture when I get home today, but the pipe will touch the x-frame and cause vibrations. To get around this, you can rotate the Midpipe a certain number of degrees to lift it off the x-frame, but it will cause your muffler to tilt downward. In turn, your tailpipes will be pointing downward. My shop cut off my tailpipes and rewelded them on at the correct elevation to fix this and I haven’t had a problem at all. |
10-07-2017, 03:26 PM | #26 | |
Rep 216
2. Where the tailpipes need to be cut and rotated to match altitude This is what happened to me and how I fixed it. I can't say it will be the exact same for you * this is an older photo, not of current setup. |
sewhelan934.50 |
10-07-2017, 04:05 PM | #27 |
Rep 146
Drives: BMW's
Garage List 2020 G07 X7 [0.00]
2013 E70 X5 [0.00] 2003 E46 M3 [0.00] 2013 F10 M5 [0.00] 2009 E90 335ix [0.00] 2009 E90 M3 [0.00] |
10-07-2017, 09:30 PM | #28 |
Rep 216
10-10-2017, 08:18 PM | #29 |
Rep 91
Drives: 2022 BMW M5 Comp
Great numbers!
2022 M5: MBB/Aragon Ext Leather/ZCP/ZEC/789M' Wheels/Alu Carbon Struct Dark Trim/Red Calipers
2021 X5 sDr40i: Jet Black/Ivory White Ext Merino Leather/ZP2/ZPK/20'' Wheels (738)/Multi-Contour seats, Htd seats/armrests/steering wheel |
10-11-2017, 10:31 PM | #30 | |
Rep 81
Drives: 2018 BMW 440i F32 Coupe 6MT
10-11-2017, 11:18 PM | #31 | |
Rep 216
I wouldn't say the intake creates an overly loud sound, but I immediately noticed it after installing the intake. Do you have a tune with your intake? More boost = more sound |
10-12-2017, 02:31 AM | #32 | |
Rep 81
01-25-2018, 02:55 PM | #35 |
Rep 216
No, Dinan parts do not void your warranty. I would look at Dinan's website for more in-depth info
01-30-2022, 11:39 AM | #36 |
Rep 66
Hey boss! This gasket you’re referring to- where did you purchase it ? What’s the specific name of it? Downpipe gasket? Lol
01-30-2022, 11:13 PM | #38 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
01-31-2022, 02:35 PM | #39 |
Rep 133
I had my 328xi dyno'd just for shits and giggles cuz I was having a ton of other work done to it last summer. My local third party bimmer specialty shop just disconnected the front driveshaft for the dyno, took 'em less than 15 minutes to both disconnect and reconnect it and they didn't even charge me. Obviously you'll lose a BIT of power but still good enough to give you a pretty damn good idea of what you are putting down. A dynojet said my stage 1 328xi was putting 250hp /306 lb/ft of torque to the wheels which was pretty goddamn good for a car rated at 240hp from factory lol.
F36 /// 440i Grand Coupe - Carbon Black - MPPSK - M Sport - Carbon Fiber Aero - Bm3 Stage 1
