BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 fitment spreadsheet - contributions wanted
proTUNING Freaks
      07-10-2013, 08:06 PM   #1
JN1
JN1's Avatar
301
Drives: S211 AMG E63
No matter what platform, people are always asking what fits (aggressive or not). That being said, I'm working on compiling a spreadsheet that shows what sizes offset fit based on user experience which should hopefully eliminate some repetitive threads here.
Post up your confirmed setups: front/rear, diameter, width, offset, tire size and suspension and I'll add it to the list to publish on the forum.
(i.e. F 19 x 8.5 +35 235/35, OEM suspension)
Giddy up!
All, Vip has kindly created a Google form to submit your wheel setup to go directly to spreadsheet. Please click link and enter your info if you would like so submit your info https://docs.google.com/forms/d/17cm...YniNo/viewform
Spreadsheet can be found here: https://docs.google.com/spreadsheet/...=0&output=html
Thanks!
-JustinNApproved
      07-10-2013, 10:20 PM   #2
diesel86
Drives: 2012 BMW 328i Sportline
Awesome thread.
19"x8.5" et30 (square)
245/40-19 (square)
Stock Sport Suspension.
Fronts have rubbed the inner fender well on a couple of occasions. No real damage to tire or vehicle.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      07-11-2013, 12:25 AM   #3
JN1
JN1's Avatar
301
Originally Posted by diesel86 View Post
Awesome thread.
245/40-19 (square)
Updated. Thanks!
-JustinNApproved
      07-11-2013, 09:46 AM   #4
pkancel
pkancel's Avatar
Drives: BMWs
Base model F30, RWD w/OE Sport Springs
235/35-19 19x8.5et 35 fronts with 275/30-19 19x9.5et38 rears
Better tire option for these wheels/offset
Also, 245/35-19 front, 265-30-19 rear.
      07-11-2013, 09:49 AM   #5
jasonF30
jasonF30's Avatar
Drives: 2019 M2 Competition
This is awesome!! Great work!
You should include in the table what car and xDrive or not =)
2019 M2 Competition | LBB | Manual
2014 335i F30 xDrive MSport (bye)
1988 535i E28 (RIP)
      07-11-2013, 10:25 AM   #6
JN1
JN1's Avatar
301
Good idea. I'll add that column.
-JustinNApproved
      07-11-2013, 12:28 PM   #7
Waterbelly
Drives: 2020 X3M Comp
I have your "better tire option" but will say the rear still is a bit "fat". The et38 on the rear is too little, IMHO. You need 43 or so.
      07-11-2013, 01:06 PM   #8
slmdgee
Usofstance
Drives: 328I 6SPD
19x9.5 plus 20 front and rear with 225/40/19
On Bc Coilovers.
Front fenders pulled and rolled and rears have a slight pull.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      07-11-2013, 01:54 PM   #9
overkill1125
overkill1125's Avatar
Drives: 2019 440xi Gran Coupe
Xdrive with stock suspension
19x8.5 ET35 with 225/40/19
You can also go with a slightly beefier tires 235/40/19 with no problem.
19x9 ET35 square with same tires work also
      07-11-2013, 02:19 PM   #10
MMOTION
MMOTION's Avatar
109
Drives: like you'll never drive again
Great info here! May I suggest people post a pic of their F30 fitment along with wheel/tire specs as well.
This should be Stickied. =)
      07-11-2013, 03:26 PM   #11
pkancel
pkancel's Avatar
Drives: BMWs
I agree completely, 38 is too much push to the outside. 40 to 43 is much better. every little bit helps.
      07-11-2013, 08:43 PM   #12
vip
vip's Avatar
Drives: 2001 Alpine White M5
Giddy up!
FYI... I started pulling some info from searching threads and listed the username in the spreadsheet so you can search for pics in the forum.
great idea. but why dont you create a google spreadsheet so we can all edit it without posting it in the thread???
just a thought.
sent from bimmerpost Android app
      07-11-2013, 08:44 PM   #13
vip
vip's Avatar
just a thought.
better yet, create a form that way people enter the info and gets right into your spreadsheet. i can help with this if need be.
      07-12-2013, 04:03 AM   #14
JN1
JN1's Avatar
301
Google Spreadsheet
not a bad idea. I didnt realize I could make it public, only share with selected email addresses
-JustinNApproved
      07-12-2013, 09:28 AM   #15
vip
vip's Avatar
Google Spreadsheet
Yep. Let me know if you want me to help you create the form.
      07-12-2013, 02:22 PM   #16
JN1
JN1's Avatar
301
Definitely. What's your email address? I'll share the doc with you.
-JustinNApproved
      07-12-2013, 03:32 PM   #17
rxander
rxander's Avatar
Drives: F30 Alpine White
Front: 19x8.5 et 35
Rear: 19x9.5 et 35
Tires: Michelin Super Sport
235/35/19 front 255/35/19 rear
H&R Super Sports
will update pic later
      07-12-2013, 03:33 PM   #18
vip
vip's Avatar
VIPEEZY@GMAIL.COM
      07-12-2013, 03:37 PM   #19
JN1
JN1's Avatar
301
Shared!
-JustinNApproved
      07-12-2013, 05:56 PM   #20
12eight
12eight's Avatar
Drives: 335xi Msport EBII
Does anyone know if I purchased 4 fronts of this wheel for my 2013 335 xi with M Sport brakes would they fit? Thank you for any contribution you can provide.
http://www.allfactorywheels.com/prod...ont-71438.html
      07-12-2013, 06:06 PM   #21
JN1
JN1's Avatar
301
With stock brakes, I don't see any reason they would not fit. I'm pretty sure but can't confirm they clear M Performance brakes though.
-JustinNApproved
      07-14-2013, 09:15 AM   #22
KLC
Drives: Gray
Great thread idea. I'll post when I get my wheels put on about how they fit.
