05-17-2022, 07:18 PM | #1 |
Rep 36
Drivetrain Malfunction
I have a 2016 328i with 95k miles on it. When I first got it in Febuary I had a drivetrain malfunction a couple times, brought it into the dealership and they said it was just some glitch with the computer system. It has happened a couple times since then, but recently, I got a new job that has more of a commute so I am driving a lot more, and it is happening a lot more… maybe 2-3 times out of 5 days a week. When it happens it shows symptoms for maybe 30 seconds before just being sluggish then popping up. I pull over and restart the whole car and it goes away and I drive home like normal. Today, my car was being weird, when I would press the gas it would try to go forward but wouldn't, like kind of shaking but very softly, then of course the malfunction popped up, I pulled over, restarted, and was fine. Should I take it in again?
05-17-2022, 09:51 PM | #2 |
Rep 16,143
Get an OBD diagnostic and repair tool. Even freeware like bimmer-tool Lite will reveal most error codes.
23hallkorr4.00 |
05-17-2022, 09:59 PM | #3 |
Rep 36
05-18-2022, 10:11 AM | #4 |
Rep 16,143
There are hundreds of errors that won't cause the check engine light to come on. Error codes are typically saved in iDrive until they're cleared.
23hallkorr4.00 |
05-19-2022, 02:03 PM | #5 |
Rep 63
ISTA+/Rheingold diagnostics are the way to go
My car had a catastrophic engine failure. The console error message was pretty much the same as what you were getting - "drivetrain malfunction" , but when I hooked up to my laptop and read the codes through ISTA+, it gave a lot of BMW specific errors codes which were all pointing to cylinder#3 misfire, in my case , which it turn because of no compression in cylinder#3
2014 328i | M-Sport |M Blue big brake kit|M Performance Exhaust|Dinan Sport Tune
23hallkorr4.00 jsouth112.00 |
05-19-2022, 02:08 PM | #6 |
Rep 63
Please note, it is not my intention to scare you. I was just sharing this just one scenario.
I have had "drivetrain malfunction" few years ago when the car was in factory warranty and that time it was just a faulty spark plug. Car was shaking badly , I had to pull over and tow it to the dealer. it never went away after a restart
23hallkorr4.00 |
05-25-2022, 12:58 AM | #7 |
Rep 25
7654ggy67
23hallkorr4.00 |
05-31-2022, 05:47 PM | #8 |
Rep 212
That "Drivetrain Malfunction" error message is VERY non-specific. In my case, the turbo wastegate arm needed a small 5 minute adjustment. Independent shop charged me only a half hour labor to diagnose and repair it. My scan tool (Foxwell 510) was useless in this case.
23hallkorr4.00 sspade2468.50 |
01-02-2023, 11:39 AM | #10 |
Rep 212
Very similar to mine. The wastegate arm needed adjustment due to wear. I have 167k miles - problem occurred at about 155k. The error messages, even on my Foxwell NT510, were completely vague.
