05-03-2013, 11:47 PM | #947 | |
Rep 472
Hope this helps?
F30 330d M Sport Mineral Grey / Coral Red
Pro Nav/Visibility Pack/Comfort Pack/Harman Kardon/Head-Up Display/Electric Seats/Comfort Access/Adaptive Suspension... |
05-03-2013, 11:53 PM | #948 |
Rep 89
05-04-2013, 09:09 AM | #949 | |
Rep 2,148
Drives: F87 M2 BSM MT
05-04-2013, 09:47 AM | #950 |
Rep 387
05-09-2013, 06:42 AM | #952 |
Rep 1
2 ways to close side mirrors - Comfort access and FOB
Not sure if anybody mentioned this earlier n not sure if US n Europian specs work like this but here in Dubai when u long hold the 3 lines on the comfort access door handle, the mirrors auto close after locking the doors by couple of seconds. Naturally, mirrors auto open when car is unlocked either by comfort access or FOB. stuff!
And: Long pressing unlock on FOB also opens all windows n unfolds side mirrors. Long pressing lock on FOB also closes all windows n closes/folds side mirrors. Hope that was useful |
05-09-2013, 07:41 AM | #953 | |
Rep 808
I had an e350 rental car this last weekend and at the speeds my caravan was going, those darn things were smacking the heck out of the windshield. I think it's a combo of keeping them out of the airstream for a barely-measurable gas efficiency reason (I'm sure it saves a gallon of gas every 10k miles. The additional components of it probably cost more than the gas it saves), for blade longevity, and it looks better than a competitor's alternative. (They tried to tuck it, but doesn't go as far as it should IMO... makes it look like garbage) |
05-09-2013, 01:57 PM | #954 | |
Rep 2,710
Drives: MB E350 4MATIC Estate
05-26-2013, 12:52 AM | #955 | |
Rep 22
05-27-2013, 07:19 PM | #956 |
Rep 3,619
Can someone try this, I just tried it in an X5 but that one has the electronic parking brake. If I start the car with the electronic hand brake on and the door open, the car will allow me to drive it after I release the hand brake and start driving while the door is open. I am away from home and do not have the F30 till tomorrow. Wondering if this works with the manual hand brake but it would be great if this can work on the F30 too.
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
06-05-2013, 01:02 PM | #957 |
Rep 3,619
I will respond to my own post above. Yes you can disable the feature that stops you from driving if your door is open. As stated above before you put the car in drive (auto trans), make sure the handbrake is applied. Once you put it in drive, remove the hand brake and you are good to go.
06-05-2013, 01:17 PM | #958 | |
Rep 1,997
06-05-2013, 01:46 PM | #959 | ||
Rep 3,619
06-05-2013, 06:27 PM | #960 |
Rep 2,101
This does work as I once got back into my car to move it a little further back in a parking spot and was able to do so with the door open.
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
06-05-2013, 06:55 PM | #961 | |
Rep 3,619
What you guys are essentially saying is the car will drive irrespective of whether the door is open or closed. I am very confused here
06-05-2013, 09:22 PM | #962 | |
Rep 1,997
06-05-2013, 09:23 PM | #963 |
Rep 1,997
It's been awhile since I did it, but close all doors/lock the car, then unlock it and open the door, leave the door open and start it then put it in gear without closing the door, it should let you move.
06-05-2013, 09:33 PM | #964 | |
Rep 3,619
I will try it in the morning
06-06-2013, 07:19 AM | #965 | |
Rep 3,619
06-08-2013, 01:04 AM | #966 |
Rep 160
I've had two bits of plastic floating around in my boot/trunk since I picked my car up. Thanks to this thread, I finally realised where they go! They're the bag hooks! I stuck them into the holes and can now hang bags up in my boot. Awesome.
07-09-2013, 10:54 AM | #967 |
Member
26
Rep 127
Drives: 2023 F90
Is it possible to change the comfort access to unlock all doors instead of just to the one door that is touched?
07-09-2013, 10:59 AM | #968 | |
Rep 1,892
