04-16-2013, 01:34 PM | #1 |
Rep 1,185
Squeaky/rubbing noise coming from the steering wheel.
At low speeds, in any mode, if I turn the wheel slowly there is a rubbing/squeaky noise coming from the steering wheel. I have no clue when it started but it pisses me off. Worth taking to the dealer?
04-16-2013, 01:49 PM | #2 |
BMW 4 Life...
148
Rep 3,360
Of course man.
Take it ASAP and get them to fix it...
04-16-2013, 02:42 PM | #3 | |
Rep 580
*NO LONGER ON ORDER* '12 328i Mineral Grey Metallic w/black leather/aluminum&black gloss trim/ZSL/ZPP/Xenons |
04-16-2013, 09:15 PM | #4 |
Rep 674
Good luck with that...I have that most of the time as well, not so much a squeak as it is a rubbing noise. Took the car in for service and the damn thing stopped while there. They couldnt replicate it but they lubricated the area around the steering wheel/column since that is where I told them the sound was coming from. On the way home, they were right, it wasnt doing it. Great problem solved. Two weeks later started back up. If its the same as you guys, its fairly faint. If you have the music off or extremely low, then you hear it, if the music is up then harder to hear. Minor annoyance which really only seems to bother me or be noticed when i have friends, family or customers in the car and we are just talking with no stereo on. Then you hear it loud and clear If the dealer finds it exactly, please post so we all get it corrected...
04-16-2013, 09:51 PM | #5 |
Rep 286
Its the rubber seal behind the steering wheel, had the same thing and the dealer will fix it. If it becomes a grinding noise its the steering wheel bearing and there are a few threads about it if you search. Hope this helps!
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa |
04-16-2013, 09:55 PM | #6 | |
Rep 331
Drives: 2012 335i Sedan Sport Line
04-16-2013, 09:55 PM | #7 | ||
Rep 331
04-17-2013, 08:26 AM | #8 |
Rep 4,323
I have had this - they ended up lubricating it and then replacing the entire steering column. It's odd...
04-21-2013, 12:50 PM | #9 |
Rep 674
Column squeak
Thanks for the info, now can direct them on exactly what it is.
08-03-2014, 10:46 PM | #10 |
Rep 2
08-03-2014, 10:55 PM | #11 | |
Rep 1,831
Drives: 335i MSport + MPS/MPPK
08-04-2014, 12:48 AM | #12 |
Rep 128
Mine does the same thing. Yeah, it's pretty annoying. Definitely see what the dealer can do.
08-05-2014, 11:36 AM | #13 |
Rep 1,185
07-03-2015, 12:17 AM | #14 |
Rep 160
Mine start to make Squeaky/rubbing noise when turning the steering wheel lately at low speed. It was a 2012 328i Sport just hit 20000km. well passed warrenty. So, damn..
04-30-2016, 11:40 AM | #15 |
Rep 943
Drives: 2012 328i Modern Line
Anyone know what kind of lubricant they use to fix this? Car is at dealer and it sounds like it's not covered by CPO. I was told it requires special lube which has to come from Germany.
04-30-2016, 12:09 PM | #16 |
Rep 674
They finally fixed it on my 2012 328i, but I dont recall what it was. lube was only part of it though. HOwever, have since also bought a 2012 335 and it has the same issue. They just replaced some parts which reduced it significantly but just got it back and there is still some of it happening so need to take it back in. My car is a CPO so will find out and post when I get the results.
04-30-2016, 12:21 PM | #17 | |
Rep 943
:wave:
04-30-2016, 06:28 PM | #18 |
Rep 943
Well dealer said there was a service bulletin for this but declined to let me have a copy of the instructions. The bulletin is SIB-32-04-13, is there any way to look up the corrective action?
:wave:
05-01-2016, 01:57 PM | #19 |
BMW forever!
1375
Rep 2,417
Had the same issue. Steering was make the same type of noise plus grinding as well. Got it fixed and had a couple of TSBs done. Now its great!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
01-20-2017, 10:34 AM | #20 |
Rep 3
Reviving an old thread...
Having the same issue on my 2013 F30 and dealer couldn't replicate the problem. I found this online about the SIB mentioned above. But lubrication will only work for so long before the plastic starts to squeak again. Anyone that had their steering wheel replaced have a service OPCODE or description details of their repair order ? I would like to take as much details that I can to the dealer. NHTSA Item Number: 10054914 Service Bulletin #: SIB-32-04-13 Replacement #: Vehicle/Equipment Make: BMW Vehicle/Eqipment Model: BMW Model Year: n/a Mfg Component Code: 011000 STEERING:WHEEL AND HANDLE BAR Date of Bulletin: 2014-01-01 Date Added: 2014-03-11 Summary: BMW: WHEN TURNING STEERING WHEEL, RIGHT OR LEFT, SQUEAKING NOISES IS COMING FROM STEERING SPINDLE AND SPINDLE GAITER HAS BEEN LUBRICATED, INSUFFICIENTLY. MODEL F30. *PE |
