BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Taking my 335 @ less than 900 miles
      12-28-2012, 10:33 AM   #1
chrisv_335EBII
Drives: 335i 6sp EBII
My car has a few annoying problems that need to be corrected.
  1. Noisy Chair - Drives me insane over bumps
  2. Noisy Breaks - Drives me insane whenever slowing down. Dealer on phone told me this is normal. I will not accept breaks that scream everytime I use my breaks
  3. Comfort Access doesn't work 50% of the time. Its mainly when I try and use it for the 1st time every day
  4. Cannot get Bluetooth Audio to work. I have an Iphone4. It worked during my testdrive. My phone is paired and it shows Bluetooth Audio is enabled but it doesn't show up under Media area on Idrive. I suspect I'm doing something wrong but I'll let the dealer school me...
I have a few other rattles but sadly I cant hear them over the noisy chair. Once that is fixed I'll start addressing those myself.
      12-28-2012, 10:36 AM   #2
Yay-Z
Shifting to Top Gear
Yay-Z's Avatar
Drives: F10 M5/E70 X5
With regards to number 3:
Make sure the fob is not in the same pocket as your phone as it tends to cause interference.
Number 4:
Select phone and choose options, make sure audio is enabled.
2015 F10 M5 CP
2013 E70 X5
      12-28-2012, 10:41 AM   #3
tdizzle
Drives: 2017 F80 ZCP
I'm curious to what happens with comfort access? I had issues with mine at first, but it was user error. I was putting my hands/fingers in the wrong area to lock/unlock or doing it too fast/often and it didn't like it. I suspect you've figured out the proper way to operate it if you've had the car more than a few days (it took me a couple days to realize what I was doing wrong).
      12-28-2012, 10:51 AM   #4
chrisv_335EBII
I've had the car for 3 weeks now. I've tried everyday of opening the door. My neighbor even asked me last week if I'm okay because I looked like a crazy person trying to open the door. It mainly happens in the morning leaving for work. It has not worked once in the morning. It works about 50% of the time leaving at the end of the day. I have had no problems locking it using comfort access.
      12-28-2012, 10:53 AM   #5
chrisv_335EBII
Number 4:
I keep my phone in another pocket or in my hand normally. I never put them in same pocket.
I just ran outside. I confirmed Bluetooth Audio is enabled. However, my phone is still not showing up under media. I know it worked when I 1st got the car.
      12-28-2012, 10:58 AM   #6
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
I found this to be true with the E9x keys when in my pocket with iphone. I tried the F30 key with phone in same pocket and it works flawlessly everytime. i was impressed and figured they corrected the phone pocket interference issue with the F30.
      12-28-2012, 11:19 AM   #7
hockeyno93
Drives: '13 328i Xdrive Sportline
Does the comfort access work if you have gloves on?
2013 328i XDrive // Sportline // Mineral Gray // Sport Auto // Tech // Premium // Cold // Lighting
      12-28-2012, 01:58 PM   #8
tdizzle
What I meant to say, was how are you trying to operate it? When you walk up to the car, do you grasp the door handled as if you're opening the door but hesitate for it to recognize you and unlock before you pulll? Or are you doing like I did at first and pressing the button on top of the handle that locks the car, hoping that it also unlocks?
For some silly reason when I first got the car I thought that you had to press the button to unlock it and lock it, when all I really had to do was touch the inside of the handle as if I was going to open the door.
      12-28-2012, 02:39 PM   #9
chrisv_335EBII
Ive tried the following.
  1. Grasp handle and pull fast
  2. Grasp handle and pull slow
  3. Grasp handle and hesitate
  4. Touch the stripped pieces at top
  5. I've tried with and without gloves
  6. I've tried screaming at the car
  7. I've tried singing to my car....
I went to lunch today and when I left the office it worked. However, when I came out of the restaurant and tried it the same way as before it did not work. It shouldn't be this complicated.
      12-28-2012, 03:17 PM   #10
Il Fenomeno 415
In top form...
Drives: '13 335i xDrive coming...
This is exactly why I chose to not order comfort access. The concept is fine, but completely uneccessary. I hope everyones CA issues get resolved but after reading this post I'm glad I didn't get CA. I'd be very angry if it didn't work too. After all it's there for comfort right?
Sometimes choosing these options that aren't needed create frustrating time consuming problems. Good luck
      12-28-2012, 03:27 PM   #11
sr5959
Drives: 428GC M-Sport
It works fine for me 99% of the time, except when I need it most! i.e. the only time it doesn't work is if it's raining so hard I run to the car and pull the door handle very fast. You need to slide your fingers in the gap and just give it a fraction of a second to unlock.
      12-28-2012, 03:36 PM   #12
tdizzle
It works for me 100% of the time if I do this (i.e., the proper way to use it). It's one of my favorite features of the car. You never have to take your keys out of your pocket. It would be a bit annoying to have a push start car that required you to take your keys out of your pocket solely to unlock it.
Sorry some people have issues, I'm sure there is some sensor issue of sorts and it is fixable by the dealer.
      12-28-2012, 03:46 PM   #13
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
I've never had an issue with the comfort access. The trunk is a bit iffy, but I can usually get it working pretty easily now.
The unlock sensor should unlock as soon as you touch it - it's on the inside of the handle. The strips/ridges on the top of the handle are where you press to lock it, make sure you aren't touching both.
Out of curiosity do you have very dry skin? I have no issues with the sensors even with gloves on, but technologically speaking some people, especially older people with dry skin are prone to having more issues. My mother has a oven with capacitive controls and literally can't use it in winter. She'll push and prod the buttons with all her might and her fingers just don't have the "juice" to trigger the sensor, and I've never had an issue.
Try to make sure you're only touching the inside area and to make sure the key is close enough. Perhaps try to take the key out of your pocket and see if it lets you open it easier - it's possible something is causing interference so that your hand isn't the problem it's the key. (Though my wife leaves her key in the purse and it never has an issue)
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      12-28-2012, 03:57 PM   #14
BMWinGE
no issues from mine either. have you checked the passenger side door? does it do the same? what about your trunk? does it open with your foot? just wondering if its only your door handle that has a problem or centralized.
      12-29-2012, 12:12 AM   #15
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
If its not working its 100% user error.
CA is very finicky.
Don't use your thumb to open it (open palm open, takes 1 second)...and use one finger to lock on the raised ridged area...
SOLD: 2012 335i Mineral Gray
      12-29-2012, 12:16 AM   #16
justinnum1
Drives: 2018 330i Msport 6mt
the brakes are normal bro...relax.
they will be fine after 1200 miles
      12-29-2012, 12:24 AM   #17
Carnook
Drives: iX
CA works for me 110% of the time. How can it work more than 100% you may ask? Because when I'm washing the car and I spray the handle it locks the car. It turns off the tunes I was playing
      12-29-2012, 12:57 PM   #18
tdizzle
Totally concur, I can't have the key near the car while washing it or it'll lock/unlock the doors and sometimes open the trunk if the water hose somehow works its way under the trunk sensors. Kinda funny.
      12-31-2012, 07:45 AM   #19
chrisv_335EBII
My car sounding like I'm rapping a 12 year old girl is not normal....
I dropped her of at BMW of Annapolis this morning. Its funny when I stopped in the service lane I saw everyone head turn to my car as my breaks screamed.
I do hope it gets fixed because its really annoying. However, the noisy chair is much worse. The M-sport suspension makes it so every bump makes my chair squeak 10 times.
Odd note ~ I received a 2011 328 loaner. I'm impressed with the engine. I did not enjoy the feel of the 2013 328. The I6 just feels silky smooth compared the the 4 banger. I finally understand what E90 owners complain about when comparing steering feel. The E90 steering is heavy. I like the electronic steering better. My steering feels similar at highway speed but in the parking lot mine is a lot easier and nice to use.
      12-31-2012, 07:46 AM   #20
chrisv_335EBII
I tested it Sunday. The passenger door works fine. The trunk works as well.
      12-31-2012, 07:53 AM   #21
BMWinGE
not an expert on this system but would think that means you've isolated it to your driver door. hopefully its just a bad sensor in your door handle.
      12-31-2012, 08:34 AM   #22
pkimM3r
pkimM3r's Avatar
205
Lately my ca lets my passenger unlock the car when im not even next to the car. A couple times it didnt even let me open the door when standing right next to the driver side door. Wth?!
The noisy seats must really suck. Havent heard of anyone else with it on here.
