11-18-2022, 12:35 PM | #309 | |
Rep 40,964
And stop doing what you are doing to corrupt it...
jfilipe0.00 |
11-18-2022, 12:48 PM | #310 |
Rep 3
I really don't know how this happened, I just followed a tutorial video on how to leave the start/stop button in the last position. When I finished, a message appeared saying that something had failed. I don't know what went wrong and I really wanted to find out.
Regarding the corrupted cafd, how can I install it again? Before making any changes, can I create a "backup" of the existing files? |
11-18-2022, 01:07 PM | #311 | |
Rep 40,964
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
11-20-2022, 07:34 PM | #312 | ||
Rep 3
As for the corrupting the file, I don't know why it happened. : |
09-13-2023, 03:30 PM | #313 |
Rep 28
Hi,
Ive previously coded my G31 video in motion all was working all good until an update over the air from BMW was installed the VIM has stop working,tried to re codes the VIM but I get the CAFD file is missing also help needed thanks. |
09-13-2023, 03:56 PM | #314 |
Rep 40,964
Update your psdzdata. PM sent.
09-14-2023, 01:57 PM | #316 |
Rep 40,964
Need BimmerUtility for FDL Editing.
09-14-2023, 02:02 PM | #318 |
Rep 40,964
09-14-2023, 02:25 PM | #320 |
Rep 40,964
v.5 uses same CAFD Mapping Database as v.3.7, which is from Dec 2019.
09-14-2023, 03:13 PM | #321 |
Rep 28
Ive just tried using FDL editor on Launcher Pro V offline loading up the Cafd file saved earlier when connected to car and the missing descriptions all show up and the options to edit was availbe too,if this is possible can I save it in the modified state and code back to car?
09-14-2023, 03:18 PM | #322 | |
Rep 40,964
09-14-2023, 03:32 PM | #323 |
Rep 28
One thing bothers me why did the NCD file when connected to car didnt show up the descriptions since it was the same file I saved earlier when trying to code the VIM and I was able to view the descriptions offline,maybe I made an error somewhere possibly?
09-14-2023, 03:33 PM | #324 |
Rep 40,964
No idea. Defies logic.
09-27-2023, 12:07 PM | #326 |
Rep 1
I have a problem on my f31 , i am trying to code apple carplay on it and it says this error :
CAFD_00001EF6_006_057_003 Fehler: File for "cafd_00001ef6-006_057_003" not found! [C012] |
09-27-2023, 12:10 PM | #327 |
Rep 40,964
03-20-2024, 02:22 PM | #328 |
Rep 3
Hi Shawnsheridan, I would also like to receive the latest PSdZData files as I am missing the cafd_00001ef6-006_055_013 file. However, I just signed up this forum, so not sure if my DM function works already. If not, I'll try it a week later. Thanks in advance.
03-20-2024, 05:04 PM | #329 |
Rep 40,964
PM sent.
04-28-2024, 07:10 AM | #330 |
Rep 1
cafd files missing
hi bimmers,
i'm getting the same error of most people C012 when trying to code ecu's of my F31 320d 2015. it appears cafd files are missing or outdated. aliexpress softwares....it cames with the cable. https://f30.bimmerpost.com/forums/im...ilies/iono.gif i'm able to change FA, write FP but cant code modules... can i get some help? best regards |
