08-23-2012, 04:35 PM | #1 |
Rep 75
???235/35 R19 on the fronts
guys, any thoughts on running this set up.. of course we are talking about m5 reps 35et on the front and 38 on the rears.
so for clarity: 235/35 front vs 225/40 255/35 rear
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 10-02-2012 at 12:09 AM.. |
08-24-2012, 12:06 AM | #3 |
Rep 75
yea but with 255 on the rears... I know u have 265/30 and supersports but I was thinking 235/35 255/35..
thnks for ur input anything helps
08-26-2012, 10:34 PM | #4 |
Rep 75
need more input as far as looks wise..
235/35 r19 fronts 35Et 255/35 r19 rears 38Et
the only thing in this world that gives orders is balls. You got that? Balls. |
08-27-2012, 03:30 PM | #5 |
Güten Täg
Rep 161
245/35 (25.8") and 255/35 (26.0") are closer in size than a 235/35 (25.5").
245/35 and 255/35 are my choice, closest to stock height (25.9") I've found.
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone |
08-27-2012, 05:27 PM | #6 | |
Rep 75
Updated Pics!
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-29-2012 at 03:06 PM.. |
08-27-2012, 05:44 PM | #7 |
Güten Täg
Rep 161
Sure thing. The tool below is a great link for comparing sizes.
http://www.rimsntires.com/specs.jsp Don't get me wrong I really like the look of the 235/35, but 1/2" is a BIG difference.
08-29-2012, 03:38 PM | #8 | |
Rep 75
sneak peak top view
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-29-2012 at 07:07 PM.. |
08-29-2012, 04:18 PM | #10 |
Rep 5,113
why not 235/40 fr and 265/35 rr?
08-29-2012, 04:33 PM | #11 |
Rep 75
yea i got more pics im uploading now bare with me, theyre not so much of the whole car
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-29-2012 at 07:13 PM.. |
08-29-2012, 05:11 PM | #12 |
Rep 75
i held back on the 40 profile JUST to be even with the rears and less squared look.. 35 front and back thought it would look better on the rim itself too imo.
i could have ran 265/35 on the rears but i was trying to keep the tire width within close range. 225/40, 255/35 OEM specs>theres about 1 3/16 inch difference.. width on the rim setup has inch apart 8.5-9.5 clearly. so i just wanted to match those figures as well. correct me if im wrong, 235/255 matches that inch difference and i was happy with the comparison of the tires (off the car-top to bottom view) as you can see here. OVERALL, it was personal preference.. although 245/265 dnt sound bad either..
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-29-2012 at 07:11 PM.. |
08-29-2012, 05:43 PM | #13 |
Rep 75
235/35 f 255/35 r
the tires are great and the setup i went with as i have explained earlier is my preference. Need lowering asap! . pardon my flipflop and the stray pup
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-29-2012 at 07:45 PM.. |
08-29-2012, 07:51 PM | #15 |
Rep 75
fronts
more pics
08-29-2012, 07:55 PM | #16 |
Rep 75
side view
08-29-2012, 09:50 PM | #18 |
Rep 75
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 10-02-2012 at 12:14 AM.. |
08-30-2012, 01:13 AM | #19 |
Rep 204
What's the advantage of running the undersized/wider front instead of factory's recommended 225/40?
08-30-2012, 01:46 AM | #20 |
Rep 75
what do you think unless you really dont know ill answer
08-30-2012, 02:01 AM | #21 |
Rep 204
08-30-2012, 04:16 AM | #22 |
Rep 75
well in general running a thinner tire gives you less tire sway when cornering and improves handling overall. wider tires will cover more ground when cornering or take off for the rear, which grip the road better and also improve handling.
soo the advantage is better handling.
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-30-2012 at 05:34 AM.. |
