      11-30-2012, 10:32 PM   #1321
kon
Singapore
Drives: F30 310i > G20 310i
thanks shawn!!!
      12-01-2012, 12:21 AM   #1322
Rob///M5
Rob///M5's Avatar
76
Drives: 2013 M5 SSII
2013 BMW M5  [10.00]
M HUD question
Apologies if this has been explained and I couldn't find it...
If you code turn signals on in the HUD, will they also display when the HUD is in M-Mode view? I have a 2013 F10 M5.
      12-01-2012, 01:20 AM   #1323
SuperTee
Blubb.
Switzerland
Drives: X6M (F86)
Hi
I've got a new F11 (built on 10. Octobre 2012), what data do I need to code this thing? Could someone send me a link please?
As I see, the turn signals in HUD are not possible with the new navi?
Tee
      12-01-2012, 02:29 AM   #1324
kitster
Drives: G31 M Sport
Hi,
Also interested in coding my car, I'm about to take delivery of a F31 (Nov Build). If someone could send me a link?
On another note, if I make a change will my dealer be able to detect this?
Thanks.
      12-01-2012, 07:44 AM   #1325
shawnsheridan
shawnsheridan's Avatar
HUD Turn signals are not working for some reason on MY 2013 F10's with new HU_NBT (iDrive).
      12-01-2012, 07:54 AM   #1326
shawnsheridan
Originally Posted by SuperTee View Post
Hi
Tee
Originally Posted by kitster View Post
Hi,
Thanks.
Maybe look here:
Huge thanks to Telefax for sharing this and providing the files.
I've never created a torrent before, this is my first one, so hopefully it works.
The torrent file can be downloaded from here: http://www.sendspace.com/file/ngwhjf
I'm leaving my computer on with it seeding so hopefully we can get the ball rolling for everyone. Let me know how it works. Thanks!
Generally, normal coding will not be detected. If your car goes in for service, and needs programming, the Dealer will just hook up to the car, and program it and wipe out your coding. If you do some advanced things like alter your VO and write it to the car, then the Dealer's ISTA/P will likely recognize it, and depending on what exactly was done, it may or may not program the car.
      12-01-2012, 11:51 AM   #1327
M52013UDM
M52013UDM's Avatar
Drives: 2013 M5 SS
shawnsheridan,
Your coding info is GREAT! Please send me a working torrent link. I have a F10 M5 and F30 335i xDrive that I would love to code. Still need to acquire a cable and wish there is some way to capture all of these tips and a how to get started. Any tips would be most welcomed.
My sincere appreciation for all of your efforts.
      12-01-2012, 03:31 PM   #1328
shawnsheridan
Originally Posted by M52013UDM View Post
shawnsheridan,
PM Sent.
      12-01-2012, 03:45 PM   #1329
dos1973
Originally Posted by ilhan1103 View Post
OK so you want the instrument cluster lights on all the time, no matter if your 'outsidelights' are on or not.
Should be possible but I haven't seen anything like it yet. Maybe someone else?
This is what I'm searching for....
@shawnsheridan: looks like you're the Coding master.
Any hints for a noob
      12-01-2012, 03:49 PM   #1330
shawnsheridan
That is why I refrained from commenting, because in fact I do not know how to code that. I looked a while back for it in my F10, and never could find it.
      12-01-2012, 05:18 PM   #1331
akeresztes
Drives: 2013 335xi (F31)
Try this.
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
This worked perfectly, I didn't have any real errors. This forum has been amazing help with figuring out coding and getting help - shawn especially has been really helpful.
One question - has anyone coded the auto high beam assistant yet? I do have the driver assistance package (rear camera, park distance control, blind spot detection, side&top camera) but don't have SLI, high beam assistant, lane departure warning. Seems like SLI needs an FSC code, but was wondering if high beam assistant was possible. Looking at the F10 thread it seems like it just need coding the following changes below:
FRM/3050/FLA_VERBAUT/aktiv
FRM/3050/FLA_AUTO_AKTIV/automatisch
HU_CIC/3000/HIGH_BEAM_ASSISTANT/aktiv
KAFAS/3015/FLA_ON_OFF/aktiv
However, I couldn't find KAFAS module in my module list though, and I'm wondering if I'm just missing the appropriate hardware. I also saw some mentions about VO coding/changing FA for SLI but not sure I entirely followed all of it.
If anyone has gotten this working, any advice/help would be great.
      12-01-2012, 05:49 PM   #1332
shawnsheridan
Did you see this Post:
I'm not 100% sure it's the same camera. I saw a BMW 7 Series LCI at the SF Auto Show the other day. It did not have a driver assistance package (LDW, etc.), just AHB. It was a separate camera mounted at the base of the mirror - not the "KAFAS" camera referenced above.
This is the standalone HBA camera:
This is the KAFAS camera [representation only], that can do HBA, collision avoidance, LDW, SLI, etc. It's wedge-shaped and mounted above the mirror:
Crazy enough, I've also seen cars with both with some early models.
It seems there may be a newer AHB Only camera, that does not use KAFAS camera.
      12-01-2012, 05:52 PM   #1333
Glock 32
Drives: 2013 F10 M5
Originally Posted by Yobyot View Post
Has anyone noticed that after they make a change as outlined in svache's original cheat sheet that when the re-read the data into E-Sys those changes are marked as "INVALID" or "UNKNOWN".
IOW, if you go through the entire coding process and then reload that item, even though it accepted your input and uploaded it to the ECU, the hardware deems it invalid.
I had this happen with SV_Activate_Speed_Limit and SV_Deactivate_Speed_Limit. Both were accepted -- and they actually did what I expected.
But I hated having the side view cameras on at any speed (it's comic -- you should try it at 95mph). When I went to set them back to their defaults, I noticed they were invalid.
Curious about this, myself and I do not see a response. Are any changes we make using e-sys flagged with an "unknown" or "invalid" even if replaced with our original (backed up) CAFD meaning we will always leave a trail even if we put eveything back using the backup CAFD files (e.g. incase of warranty issue)?
Perhaps he simply changed the value back and did not restore the original CAFD? In othe words, I assume if we restore using the orignal CAFD files, there will be NO trail?
      12-01-2012, 07:52 PM   #1334
shawnsheridan
This is not normal. Can someone post a picture of an "INVALID" or "UNKNOWN" entry?
      12-01-2012, 08:39 PM   #1335
Glock 32
Drives: 2013 F10 M5
Sorry, new to coding... Probably a dumb question that I think I answered myself.
Here is a post with a pic that member posted and now I am thinking that the "unknown" was due to him changing the werte value instead of the drop down?
http://www.f30post.com/forums/showpo...&postcount=945
Regardless, and in theory, if you restore all the original CAFD from backup is there likely still some sort of trail (I assume there always is with software, but hoping nothing this obvious or noticeable)?
      12-01-2012, 09:45 PM   #1336
shawnsheridan
Yes, I think in that instance, incompatible Werte Values were used.
There may be some way to tell, but again with normal FDL coding nothing is obvious, especially after the coding is removed and the module is returned to the original state. Now if you alter your VO Options, and / or change your Production Date and write it to the car, and do not reverse that, that will easily be discovered. If you flash the firmware on an ECU, which can't be reversed, that may or may not be noticed.
      12-02-2012, 05:03 AM   #1337
SuperTee
Blubb.
Switzerland
Drives: X6M (F86)
Unfortunately no one seems to be seeding. Just upload it to bloonga.com
If you use PARTYTIME as bonus code, you get the premium account for free (1 year)
      12-02-2012, 08:42 AM   #1338
shawnsheridan
Err...their Premium Account has a Maximum of 10Gb, which isn't even large enough to host the PSdZData alone, lest anything else.
Plus the volume limit of 98 Gb / 3 days will be an issue. Every day since RapidShare instituted a 30 Gb Daily Traffic limit, my account has hit the limit and has been shut down for the day.
If anyone has a hosting solution to host at least 100 Gb and without limits (speed or traffic / volume), PM me.
      12-02-2012, 07:47 PM   #1339
kon
Singapore
I think torrent is feasible, I've been seeding my last download... until for unknown reason all the tracker stopped working
      12-02-2012, 08:06 PM   #1340
shawnsheridan
bloonga.com has made some favorable adjustments. I expect we will see the necessary files there maybe as early as tomorrow.
      12-02-2012, 11:21 PM   #1341
scottg61376
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
Shawn, could you send me the link for the software download? Ordered my cable yesterday.
      12-02-2012, 11:39 PM   #1342
shawnsheridan
Sorry, but with only 1 Post, I can't PM you. Either post your email, or wait until you have enough posts and send me a PM.
