BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 335i msport and 328i msport front calipers
      01-04-2013, 11:03 PM   #1
325smg
Hong Kong
Drives: 325i
Hi! Any folks know whether the 335i msport and the 328i msport shares the same front calipers? If so, does that mean we can retrofit the 335i msport or the m performance 370mm front rotors to the 328i msport?
Thanks!
Colman
      01-05-2013, 06:59 AM   #2
dcg71
72
Drives: F15 X5
No they don't, the rotors are different, hence the calipers are different. 328i M sport front are 13.4" vs 14.6" for the 335i. The 328i m sport brakes are the same size as the stock 335i brakes - 13.4".
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      01-05-2013, 10:31 AM   #3
325smg
Hong Kong
Drives: 325i
I just read from the forum that the European spec msport, no matter its a 328i msport or a 335i msport, they share the same caliper, which they are identical to the m performance ones; while the US spec 328i msport used the standard 335i front caliper that are painted in blue, anyone know anything about this? If that is the case, the European spec 328i msport can retrofit the m performance front brake rotors, while the 328i US spec msport cannot? Arg..... Very complicated!!
Colman
      01-05-2013, 11:06 AM   #4
clarence
Drives: F30 328i M-Sport
EU-spec M-sport with optional M-sport brakes (option 2NH), then it's same for 328i M-sport & 335i M-sport & also M-performance.
US-spec M-sports are not yet available with option 2NH from factory. So yes, u can just swap the discs with the M-performance if u have a EU-spec M-sport that has option 2NH.
      01-05-2013, 11:08 AM   #5
clarence
No, for option 2NH it's the same as M-performance except no slotted discs & blue calipers.
      01-05-2013, 03:31 PM   #6
dcg71
72
Drives: F15 X5
Ok, 2NH part numbers seem to be the same for both 328i and 335i.
There are 2 different M performance front rotor sizes though - 340mm (34106797602)
and 370mm (34106797603).
      01-05-2013, 07:54 PM   #7
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
bear in mind, do a swap like this would also require CODING, i'm unsure if anyone can code for this brake change currently, let alone brake bias...
SOLD: 2012 335i Mineral Gray
      01-06-2013, 03:03 AM   #8
clarence
340mm is for 320i & below w/2NH. 370mm is for 328i & above with 2NH.
      01-06-2013, 03:04 AM   #9
clarence
If u already have 2NH then u don't need to do any coding, cos it's already coded from the factory.
      01-06-2013, 05:25 AM   #10
dcg71
72
Drives: F15 X5
RealOEM lists both for my 335i with 370mm for 2NH.
      01-06-2013, 12:55 PM   #11
shivaswrath
Drives: 2012 335i
so I could sell my 335i calipers to a 328i owner? sweet!
      01-06-2013, 01:30 PM   #12
clarence
It's 370mm for 328i, 330d & 335i.
      01-10-2013, 08:35 PM   #13
drewauby5
Drives: '13 335i Msport EBII
are the brake pads for the 2013 335i non msport and msport the same as they are both 4 piston fixed design and the only difference is the size of the rotors??? I ask because I want to replace stock OEM pads on my msport with ceramics..Thanks
      01-10-2013, 10:47 PM   #14
clarence
I must clarify one thing before we move on. For US-spec M-sports, the brakes are of the same size as non-M-sport models, the only difference is the pad materials (M-sport uses standard EU-spec pads which bites more aggressively but have more dust). In ur case the pads for any 335i will fit.
      01-11-2013, 06:09 AM   #15
drewauby5
Pads
Thanks for the knowledge!!!
