      10-21-2013, 11:45 AM   #4863
shawnsheridan
shawnsheridan's Avatar
Originally Posted by Rasengan View Post
ouch...this comes from my CA:
surely there must be a way to re-enable PlugIn and Video through code?
I am not convinced this statement is correct. We need someone with iDrive 4.2 and factory 6NF and 6NR to confirm this.
      10-21-2013, 11:46 AM   #4864
shawnsheridan
Originally Posted by gnuke View Post
Hi Shawn,
Sorry to add to the never ending list of peeps in need, but can I get a link to the latest and greatest versions/lists/etc.
Thanks for everything you've contributed,
G
PM sent.
      10-22-2013, 04:50 PM   #4865
edgerider
Drives: f10
There is nothing to prevent you from sharing the patch / token, although Akiss invested much time in developing it, and deserves to be compensated for his work. What he is charging for it is certainly reasonably, especially to one who can afford a Fxx BMW.
Hi Shawn,
so the E-Sys is coming from BMW, but the token was developed by Akiss, but what prevents E-Sys to work as it is, and how it works within BMW then? if it was leaked from BMW/dealer, how do they solve that hassle?
EDIT:
I've managed to get 3.23.4 and 50.4, are they good enough to tweak a 2010 F10, or shall I dig for some other versions?
what is the way to get the proper token? i see it is being sold all over the bmw-forums, not necessarily by Akiss I suppose, so I am a bit suspicious to acquire it that way.
I see you PM'ed a few people with links perhaps, my PM will be active in 24 hours after this post is made
thanks for your inputs!
EDIT: ok I located http://www.f30post.com/forums/showpo...postcount=2356 and currently am getting the files from seeders.
      10-23-2013, 12:19 AM   #4866
Dataready
Dataready's Avatar
Drives: 2023 X5
Hey Shawn can you please PM me a link for the latest E-sys, PSdZData, and patch/token please ? Many thanks in advance
      10-23-2013, 05:23 AM   #4867
shawnsheridan
Originally Posted by edgerider View Post
Hi Shawn,
1) E-Sys used by BMW at factory also requires an .EST Token, and BMW issues their own .EST Tokens out. This is no different, except non-OEM tokens also require E-Sys be patched to accept the .EST Token since it lacks the required encryption signature.
2) If you have 3.23.4 and 50.4, then you have all you need.
3) A just programmed 2010 F10 may have newer software on the car than a 2013 F10, so the build date is completely irrelevant. All that matters is that the PSdZData used to code the car is >= the last version of ISTA/P used to program the car. Without reading a car, it is impossible to know what that is, but if you are using the latest PSdZData, then you do not need to worry about it.
4) If you already have 3.23.4 and 50.4, I have no idea why you are also downloading the older versions from the Torrent Links.
PM sent.
      10-23-2013, 05:24 AM   #4868
shawnsheridan
PM sent.
      10-23-2013, 05:48 AM   #4869
edgerider
Drives: f10
PM sent.
grand merci Shawn, understood almost everything.
4) because I've found your other posts, like those below and got an impression, that with 3.18.4 I might go for free(excluding the ENET cable):
You don't need to buy it...E-Sys 3.18.4 with EST token is all over the place...you wouldn't have to look hard to find it.
Of course you can buy 3.20 or 3.22 if you insist, but it won't do any more than what 3.18.4 does.
E-Sys 3.18.4, aka "free" version, will only work as follows:
F30 with PSdZData up to 48.2
All other Fxx chassis with PSdZData up to 48.3
Beyond that, an updated Patch / Token must be obtained, at which point you might just as well move to E-Sys 3.22.5 or newer.
E-Sys can be easily found. 3.18.4 with Token is all over the place (good through 48.2 PSdZData), and 3.22.5 (good through current 49.4 PSdZData) without Token is as well, but the Token can be obtained for as little as 50€ / $65.
so if a f10 vehicle has been programmed with the data files up to 48.2, one can use 3.18.4 to tweak it further without the need to obtain the actual token, correct?
I also read somewhere, that current version of e-sys doesn't need a token anymore, like 3.22 onwards, maybe misread that though.
      10-23-2013, 05:56 AM   #4870
shawnsheridan
An F20 / F30 with <= 48.2 on it, and all other Fxx chassis with <= 48.3 on them, can be used with "free" E-Sys 3.18.4, but understand even that version requires a Token, it just happens to have been included in the release, and it does not require it also be patched.
All E-Sys versions require an .EST Token, and when any version, including 3.18.4, is used with newer PSdZdata files, it also requires the patch.
      10-23-2013, 12:04 PM   #4871
motajo
Drives: 316D F30
Hello Shawn
I would like to change a few settings on my F30 (2012 316D). Can you tell me where are the links to download the software? (e-sys 3.2? an pszdata 50.4???)
Thank you.
(Excuse me for my english)
      10-23-2013, 06:50 PM   #4872
08bmw128i
Drives: 2018 X5M
HI shawn,
can I have the latest updates to the software?
      10-23-2013, 09:14 PM   #4873
shawnsheridan
Originally Posted by motajo View Post
Hello Shawn
Thank you.
Originally Posted by 08bmw128i View Post
HI shawn,
PM's sent.
      10-24-2013, 04:56 AM   #4874
at81
Drives: BMW F30
Sorry Shawn for the never-ending request... would you mind to kindly share all the latest files that work with 2013 F30 please? I just got my car for like 2 weeks or so.
Thank you!
      10-24-2013, 05:08 AM   #4875
shawnsheridan
Thank you!
PM sent.
      10-24-2013, 09:09 AM   #4876
ramonE90-NL
Netherlands
35
Drives: bmw F30 320iA
Is it possible to code the inside trunkbutton on the F31 so it closes when pressed?
      10-24-2013, 11:29 AM   #4877
motajo
Drives: 316D F30
PM's sent.
Thank´s.
      10-24-2013, 01:35 PM   #4878
dinnef30
Drives: F11 528i
      10-24-2013, 01:58 PM   #4879
shawnsheridan
PM sent.
      10-24-2013, 03:16 PM   #4880
greuntesop
Drives: bmw f30
Hi,
I'm pretty (completely actually) new to this coding wizardry. I've browsed through the documentation and this thread, but I still have some stupid questions left.
So there are basically 2 things I would like to do with my F30 from 09/2013.
* Code the extended bluetooth functionality (6NS). I have the basic one (6NH) that came with professional system. I've understood so far this should be possible by 'VO code' this option, basically making the car believe this option came with the standard. What I don't get is the reference to VO coding the HU_NBT. My car is equipped with the NBT system, so it should be there. Also, i've read somewhere you don't need a token to do this. Which token are they taking about here?
* The speed limit info (8TH). I have the adaptive high beam xenon lights, so if i'm not mistaken, the camera should be there to capture the images. So is this the same deal: VO code this option and that's it or is there more to it?
Thanks.
      10-24-2013, 03:41 PM   #4881
shawnsheridan
Originally Posted by greuntesop View Post
Hi,
Thanks.
1) Yes. You can change VO and VO Code 6NS with E-Sys, and without a Patch / Token.
2) You have adaptive headlights or Automatic High Beams? Adaptive Head Lights use sensors to measure speed, steering angle and yaw. HBA (High Beam Assistant uses a camera, but in some cases it is a dedicated HBA only Camera, and some cases, depending on other options, it uses the same KAFAS2 Camera as SLI (Speed Limit Info) does. SLI though may also require an FSC Enabling Code be Imported and Activated in the head unit, and if so, even if the car has the hardware, this will be difficult to get, and very expensive if it can be got.
      10-24-2013, 04:26 PM   #4882
ellweber
Drives: F31
Yet another link request!
Hi Shawn,
Please add me to your next batch of link PMs.
Thanks,
ellweber
      10-24-2013, 04:27 PM   #4883
shawnsheridan
Originally Posted by ellweber View Post
Hi Shawn,
Thanks,
ellweber
PM's for what exactly? There are many different needs I am responding to.
      10-24-2013, 04:30 PM   #4884
ellweber
Drives: F31
Sorry if I was ambiguous! E-sys v3.23.4, PSdZData v50.4, and patch/token sources.
Thank you
