10-13-2013, 06:37 AM | #4797 |
Rep 9
Hello I have a problem when I coding FEM_BODY
"cafd_00000794-004_122_077 Fehler: File for "cafd_00000794-004_122_077" not found! [C012] " Can anyone please PM me this file Thanks |
10-13-2013, 09:05 AM | #4798 | |
Rep 31
I tryed to change VO with 4U2 with date 0712 (original date was 0411) but the VO not accept 0712 the errors after FP calculation is "Not all elements on the FA were found in the FA2FP : com.bmw.esys.domain.psdz.PsdzException: No FP could be generated from FA "". [C002] at com.bmw.esys.domain.psdz.Psdz.generateFP(Psdz.java :655) at com.bmw.esys.domain.fa.FpLogic.generateFp(FpLogic. java:77) at com.bmw.esys.gui.fa.FpController.generateFp(FpCont roller.java:114) at com.bmw.esys.gui.fa.FpController.execute(FpControl ler.java:146) at com.bmw.esys.gui.AbstractController$ExtensionSuppo rt.executeExtensions(AbstractController.java:117) at com.bmw.esys.gui.AbstractController$ExtensionSuppo rt.executeExtensions(AbstractController.java:98) at com.bmw.esys.gui.AbstractController.executeExtensi ons(AbstractController.java:201) at com.bmw.esys.gui.fa.FalController.activateFa(FalCo ntroller.java:144) at com.bmw.esys.gui.fa.FalView$ActivateFaAction.doAct ionPerformed(FalView.java:109) at com.bmw.esys.gui.AbstractView$AbstractGuiProgressA ction$1.init(AbstractView.java:389) at com.bmw.esys.gui.component.DialogProgress$2.constr uct(DialogProgress.java:136) at com.bmw.esys.gui.component.SwingWorker$2.run(Swing Worker.java:145) at java.lang.Thread.run(Unknown Source) Caused by: Not all elements of the FA were found in the FA2FP: Zeitkriterium 0712 Timestamp: Sun Oct 13 12:39:45 BST 2013 SessionId: default ErrorCategory: SYSTEM_ERROR ID: 72 Class: com.bmw.psdz.api.data.FP ExecutionContext={category=DATA, ecuid=(UNKNOWN,?)} at com.bmw.psdz.api.data.FP.fillByFA(FP.java:461) at com.bmw.psdz.uc.LogicImpl.generateFP(LogicImpl.jav a:584) at com.bmw.esys.domain.psdz.Psdz.generateFP(Psdz.java :653) ... 12 more Any suggestion ? Thanks |
10-13-2013, 11:40 AM | #4799 | |
Rep 40,791
10-13-2013, 12:19 PM | #4800 | |
Rep 40,791
https://mega.nz/#!plgVhIaB!_4_115Oth...waVYj_AJRrnZfc
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 04-22-2017 at 09:53 AM.. |
10-13-2013, 03:48 PM | #4801 |
Rep 383
Haven't coded my 2012 328i in a while (build date 12/2011)... I have e-sys 3.18.4... Any reason to use a new version? I just brought my car in for its first regular service, they did A TON of recalls on it, and a firmware upgrade. I dunno if that will mess with my ability to code w/o a token anymore... Anyway, any reason to use a new version of e-sys? Thanks!
update: Just tried coding and when I read in the SVT box, I get the following error msg: HU_CIC [63] [F256502] readCPS o.k. cafd_000000f9-007_006_059 Fehler: File for "cafd_000000f9-007_006_059" not found! [C012] PLEASE HELP - Thank you! Last edited by legaleye3000; 10-13-2013 at 04:04 PM.. |
10-13-2013, 06:48 PM | #4802 | |
Rep 40,791
10-15-2013, 02:48 PM | #4805 |
Rep 40,791
Did you install the Patch (2 Patched .jar files) and set E-Sys Options to point to your .EST Token?
10-15-2013, 02:49 PM | #4806 |
Rep 40,791
PM sent.
10-15-2013, 05:19 PM | #4807 |
Rep 524
10-15-2013, 05:24 PM | #4808 |
Rep 40,791
PM sent.
10-15-2013, 08:04 PM | #4810 |
Rep 40,791
PM sent.
10-16-2013, 12:04 AM | #4811 |
Rep 23
there was another problem. When I disabled the start-stop and pressed a code FDL, after recording on the block has issued two errors.
and now gives an error when you try to click on the read coding Data. Here's a Transaktions-Report: Aktion: Codierdaten lesen FEM_BODY [40] [yayayayayayaya] readCPS o.k. cafd_ffffffff-255_255_255 Fehler: File for "cafd_ffffffff-255_255_255" not found! [C012] what could it be? |
10-16-2013, 12:27 AM | #4812 | |
Rep 40,791
10-16-2013, 12:57 AM | #4813 |
Rep 23
10-16-2013, 01:05 AM | #4814 |
Rep 40,791
You need to inject CAFD into FEM_BODY and VO Code the ECU:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD from the latest I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE.
10-16-2013, 01:09 AM | #4815 | |
Rep 23
10-16-2013, 06:49 PM | #4816 | |
Rep 205
Sorry to resurrect this question but I'm struggling trying to code my mirrors to fold inward via remote even though I don't have comfort access on my f30.
I was under the impression I was able to get this to work even if I don't have comfort access but I can't seem to find the KOMFORTSCHLIESSUNG_FB folder to edit. My guess is that it only shows up for cars with Comfort Access but I want to just confirm I should stop trying to code this. Quote:
'13 328xi M-Sport
Black Sapphire Metallic, M Sport, Technology, Lighting Package, DHP, Harmon Kardon, Sport Auto, Heated Front Seats |
10-16-2013, 07:32 PM | #4817 | |
Rep 40,791
10-16-2013, 07:39 PM | #4818 | ||
Rep 205
'13 328xi M-Sport
