BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
      02-10-2019, 03:17 PM   #133
vojislav
Drives: 520d f11
Help me please
520d
FSC code please
vin: d713848
Europe NEXT2019-1 USB
      02-10-2019, 05:18 PM   #134
alfi77
Hungary
Drives: BMW G30
FSC code
Can I get a fsc code for NBT, please! vin: D324290 Road map EUROPE Next 2019-1
THANK YOU VERY MUCH!
      02-11-2019, 04:23 AM   #135
reischi82
Drives: F31 LCI 320xD
Originally Posted by vojislav View Post
Help me please
520d
FSC code please
vin: d713848
you should check for your production date using VIN decoder (see older posts) and than you can try finding key using "by date" in the generator
according to https://www.mdecoder.com/
d713848 => 2014-04-02
D324290 => 2013-04-05
      02-11-2019, 05:55 AM   #136
alfi77
Hungary
Drives: BMW G30
It's not working, unfortunately for me on mac
      02-11-2019, 04:13 PM   #137
vojislav
Drives: 520d f11
I tried twice over the date without success, how many times can I make a mistake?
      02-12-2019, 01:36 AM   #138
reischi82
I am not aware of a limit entering a key but if it is not working "by date" you will need someone with E-NET cable and E-SYS to store your FSC file to be able to generate a working key.
      02-12-2019, 02:00 AM   #139
vojislav
Drives: 520d f11
I borrowed from my friend BMW ENET, SWID_reader shows me the "ifh-0038 interface command not implemented" error. It's not easy to bundle everything properly
      02-12-2019, 04:21 AM   #140
reischi82
when you search for your error you get the link below - maybe this will help you. I have used E-SYS to store my FSC.
https://www.bimmerforums.com/forum/s...terface/page21
      02-12-2019, 10:12 PM   #141
ottobrill
Drives: BMW X# F25 2014
Hey dear friends,
Could anyone be kind enough and point out the way where I can find the South America 2019 NEXT maps for my X3.
I don't want to be an imposition but if anyone could also get me the FSC code for my bimmer (0g18094). I'm in Brazil and it is kind of hard to get by the Enet cable here.
Thank you guys so much
      02-15-2019, 07:40 AM   #142
balee13
Drives: BMW F36
Hi,
Could somebody help me in generating a valid FSC code for map update?
Road map EUROPE NEXT 2019-1.
VIN: VZ72215.
Problem is that even if I get the FSC from my car and decoded it with Base64, the generator gives me invalid codes. I tried also the date method with several codes, but still not working.
What did I wrong?
      02-18-2019, 06:11 AM   #143
Kkevo
Drives: F30 black sport
Thanks for help
      02-18-2019, 06:12 AM   #144
mariankalfov
Drives: BMW 530d GT
Hi, can you help me by generating a valid FSC code for CIC navigation VIN C459837
Road Map Europe East PREMIUM 2019
Тhanks in advance!
      02-22-2019, 06:39 PM   #145
Kkevo
Originally Posted by balee13 View Post
Hi,
VIN: VZ72215.
What did I wrong?
I have the same problem
But why did you decode FSC to base64?
      02-23-2019, 02:00 AM   #146
val34
France
Drives: BMW E92 330XD
Hi,
I'm also trying to have an activation code for West Europe 2019-1 maps but using the usb key solution, my vin looks like 1234567 and the generated code doesn't work. Is it possible to find it with my vin ? E208596 from 03/31/10 .
Thanks for your help, i'm a new bmw user.
      02-26-2019, 06:05 PM   #147
taseal
Drives: '15 Corvette, '15 X5,
I'm so confused... Where do I get the file that goes in "Open file" ? from the car? how?
      02-27-2019, 06:36 AM   #148
BackBlue
BackBlue's Avatar
Drives: E46, '13 E70 N63, '19 F33 440
SOLVED see below
      02-27-2019, 06:58 AM   #149
BackBlue
BackBlue's Avatar
*Duplicate
      02-28-2019, 03:20 AM   #150
BackBlue
BackBlue's Avatar
Here is how to get the "open file":
You pull "1b" file from your vehicle via a usb stick.
ZIP LINK:
https://www.e90post.com/forums/attac...5&d=1518522964
1. Unpack the ZIP file (1b.zip) to the root of an empty USB stick
2. Power on your car (ignition on is fine, you don't need to start your car) and wait until the navigation system has started completely
3. Put the USB stick in the USB port in the glove box or console, depending on vehicle.
4. Wait for around 30 seconds
5. Remove the USB stick from the port in the glove box and put it in your (windows) computer
6. Check if the file 1b.hex is present on the USB sticK, THIS IS the "OPEN FILE", save this to your computer and point the code generator to it.
Credit to memeber portalseo@e90post...and of course to Jagaer for the code generator!
      03-01-2019, 03:43 PM   #151
starwilling
Drives: BMW X1
Originally Posted by shawnsheridan View Post
No. Not possible for ROUTE nor EVO maps.
Thanks for clarifying! It is good to know though.
      03-06-2019, 08:45 AM   #152
micstar
Drives: F30 BMW 320d
The latest update of this application says it's now able to create FSC code for EVO (NEXT maps), is this true, and does it mean that it can also do ROUTE maps?
      03-06-2019, 12:21 PM   #153
pulse654321
Drives: BMW 320D
I've tried to generate a code using the date function and it isn't working. Is my only option to use a cable and decode it as I don't have access to one.
Something that I also read is that the codes won't include 0 or O and 1 or I but my codes have?
      03-06-2019, 03:15 PM   #154
BackBlue
BackBlue's Avatar
I didn't have any luck with the "by date" function either.
You do need a cable to extract the car "open file" just the 1b program loaded onto a USB stick.
My working code had the O letter in it, but no 1 or 0. I could see why they wouldn't use a zero just like in VIN#'s but not sure why a one wouldn't be used
