09-19-2015, 08:26 AM | #1 |
Rep 20
HI-FI audio upgrade to surpass harmon/kardon?
edit- this should be moved to the audio section....
I tried searching but couldn't find much beyond Bavarian Sound Works stage 1 upgrade. I'm looking at two used 335i sedans. One with nav and hi-fi, the other has the h/k system, but no nav. It's much further away too. So, if I get the one with nav that's local- can I upgrade the audio to be at least as good as the hk system? I usually add a 5 channel amp, 8" or 10" woofer, and some decent co-axials (JL, polk, etc) to all my previous cars/trucks and I'm happy. I don't need symphony quality, but I want to rock out without clipping and hear the sub-bass lines in heavy music. Thanks. |
09-19-2015, 09:13 AM | #2 |
Rep 4,021
Drives: F32 Coupé
I've just done the Bavsound Stage 1 and the Bimmertech Amp.
This not only replaces all the cabin speakers (except the underseat woofers) but also ups the output to all cabin speakers by a factor of about 4X and gives you a full DSP. It also gives you a proper line out to run a monoblock amp for a proper sub in the boot. IMO there is no better way to do it. It's all completely plug'n'play and reversible if/when you need to. Even without the boot sub it shits all over the HK. And I'm speaking from experience. |
09-19-2015, 11:14 AM | #3 | |
Rep 20
Thank you. Exactly the info I needed. |
09-19-2015, 01:30 PM | #4 | |
Gettin It Figured Out
1820
Rep 2,669
09-19-2015, 07:00 PM | #5 |
1st BMW
Rep 54
I install a custom system in every car I have owned. I am a musician and very particular about sound quality. Stock systems are, for me, a bad situation, but, I did make sure that I got HK in my car because with the 7 band EQ, I can make the best of a "bad situation" until I upgrade. I think that HK is too highly regarded. Is it the name? probably. Car makers do that. Even Hyundai offers a Infiniti branded system, but guess what? It sounds terrible. So, don't base your car choice on the HK. But if you were to order a new car, then $875. for HK is a no brainer.
09-19-2015, 09:03 PM | #6 | |
Rep 377
09-19-2015, 09:51 PM | #7 |
Rep 3,225
The B&O upgrade in the 5 series out here is a $12.5K option! I love music but there was no way known I was going to get that in my new car. I'll stick with the shitty HK system
09-20-2015, 12:48 AM | #8 |
1st BMW
Rep 54
Yeah, I heard that! My last system was custom for $8K, and I have not heard a factory system that comes close. $12.5k? whew!
09-20-2015, 05:02 AM | #9 | |
Rep 4,021
Drives: F32 Coupé
09-20-2015, 08:11 AM | #10 |
Rep 16,054
I wouldn't. I find the stock system perfectly adequate, and I'm an acoustical engineer, I design sound systems for a living. There's perhaps no worse listening environment than a car, and no matter how much money you throw into it the sound will never be better than what the environment will allow it to be. If I was to add another $12.5k into the equation it wouldn't be to put a better sound system into a 3 series, it would be to step up to a 5 series.
Westsider4513.50 |
09-20-2015, 08:43 AM | #11 |
Rep 814
It's more involved to upgrade HK. I would not recommend it if there is any chance you're going to go aftermarket.
I'm speaking from experience. The Mobridge piece required for an HK upgrade lists for $765. |
09-20-2015, 04:07 PM | #12 |
1st BMW
Rep 54
Yes, and becoming common in newer cars. The sound system is an integral part of all systems of the car. Thats why dsp's accept speaker level input. Audiocontrol has more solutions now also. My considerations at this point is to either take signals from factory amp to dsp and additional amp(s),
or install separate system for portable flac player. I have experience in both options, each having their pros and cons |
09-20-2015, 07:49 PM | #13 |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
It sounds like there are some decent upgrade options for the standard HiFi system. I too just purchased a used 2014 but made HK a pre-requisite. I'm glad I did...it's a notable upgrade in audio quality and output (especially for the cost, which is almost negligible on a used car).
However, in your case, with these two particular choices, I'd go with the Nav equipped car because you DO have options to upgrade the sound system but NO practice options to add Nav (or just as importantly the large screen).
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
09-21-2015, 06:45 AM | #14 | |
Rep 1,267
09-21-2015, 06:57 AM | #15 |
Rep 814
The mids and tweeters are relatively easy to upgrade. I have Dynaudio and love them. I've also heard and liked Focal in our cars.
Improving the bass is more of a challenge. But there are options... |
09-21-2015, 10:46 AM | #16 | |
Rep 306
09-22-2015, 09:25 AM | #17 |
Rep 43
Are there any videos out there that compare the standard HiFi to the Bavsound Stage 1? I would love to hear the before and after. While I know it would be hard to replicate the sound on a 2 channel recording device, it's still nice to use as a gauge.
09-22-2015, 09:48 AM | #18 | |
Rep 12,996
http://f80.bimmerpost.com/forums/sho....php?t=1167516
