07-13-2014, 06:57 AM | #45 |
Rep 131
Garage List 2018 BMW i3 Rex [0.00]
2016 BMW F20 M135i ... [0.00] 1999 BMW Z3/E36 - 1.9i [0.00] 2004 BMW Z4/E85 - 2.5i [5.00] |
These are my coding settings:
FEM_BODY 3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_IS_LED -> aktiv : LED Foglights front right 3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_R_UE_SPG_SCHUTZ -> dimmed : LED Foglights front right 3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_IS_LED -> aktiv : LED Foglights front left 3061 NSW_L_UE_SPG_SCHUTZ -> dimmed : LED Foglights front left 3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left 3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left 3062 MAPPING_abbiegel_L_output -> nsw_l : Foglight when turning 3062 Mapping_abbiegel_R_output -> nsw_r : Foglight when turning 3073 KL_ENABLE_RE -> KL_Ein : Foglight when turning 3066 KL_ENABLE_LI -> KL_Ein : Foglight when turning 3073 C_CLC_ENA -> enable : Foglight when turning 3073 C_BLC_ENA -> enable : Foglight when turning 3063 Mapping Nevelschw L Part of WL soft-on nicht_aktiv : Foglight left as welcome 3063 Mapping Nevelschw R Part of WL soft-on nicht_aktiv : Foglight right as welcome |
12-12-2014, 01:49 AM | #46 |
BMW Fanatic
331
Rep 1,076
Would you know if the place you purchased from ships internationally?
Thanks
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
12-12-2014, 01:55 AM | #47 |
BMW Fanatic
331
Rep 1,076
I have a F32 435i X-Drive, but unfortunately my dealer did not get the adaptive LED-lights, and I am stuck with a halogen fog light, and unfortunately my dealer wouldn't order me the LED's and if he did would charge me $500+. Where can I find the OEM BMW fog lights online, and what model fits? (I've found ones for X3 & X5, but I'm not sure if they fit) Any help would be deeply appreciated.
12-12-2014, 02:22 PM | #48 | |
Rep 235
Drives: 2014 F31
http://www.ecstuning.com/BMW-F32-435...hts/ES2711818/ And this: http://www.ecstuning.com/BMW-F32-435...hts/ES2711497/ |
05-05-2015, 02:48 PM | #49 |
BMW Fanatic
331
Rep 1,076
Quick question,
what do the % options modify? Thanks
05-05-2015, 04:43 PM | #51 |
BMW Fanatic
331
Rep 1,076
I have a 528i with them. They are 30~40% brighter than halogen IMO. However, I got a 3200lm H8 kit for my F32 from Horizon in order to help me out in spotting nasty potholes. Cost me 2 tires so far. Plus, the BMW leds are kind of pricy if your on a small budget. Around $400 for 2 lights doesn't seem justified, would rather buy a performance part with that money.
05-11-2015, 07:52 AM | #52 | |
BMW Fanatic
331
Rep 1,076
05-11-2015, 09:20 AM | #53 |
Rep 15
Hi!
Greetings from St.Pete here's link to Drive2's guy, who have installed LED fog liights 1 month ago http://www.drive2.ru/r/bmw/1067795/ |
06-29-2015, 10:43 AM | #54 |
Rep 69
Hi there guys. I was wondering if any one can help.
I have followed the coding instructions and the flickering has stop. But I still have the foglight error on the dash and when I turn the steering the cornering light nothing happens? It will be great if some one can help me out. Thanks |
07-17-2015, 04:26 PM | #55 |
Rep 235
Drives: 2014 F31
I just installed the a pair of F32 LED fog lights on my 2014 F31. If i leave the PWM to the default 13.7V, the fog lights will flicker after about a minute. Changing that to 100% stopped the flickering. I don't know the difference in voltage between the two settings.
07-17-2015, 06:15 PM | #56 | |
BMW Fanatic
331
Rep 1,076
07-19-2015, 01:51 AM | #57 |
Rep 235
Drives: 2014 F31
What do you mean by LED driver? The LED fog lights i installed are made by BMW for F32 and they replaced the entire factory fog light housings, so it's not just replacing the incandescent bulbs with LED ones.
07-19-2015, 10:54 AM | #58 |
BMW Fanatic
331
Rep 1,076
Oh my bad. Then I guess that explains why they flicker. I just replaced the bulb, and the replacement LED has the driver which regulates the voltage from 12-32V.
04-25-2016, 11:23 AM | #59 | |
Rep 86
I've also seen these in some posts.
NSW_L_DUALSP_aktiv NSW_R_DUALSP_aktiv What do they code on/off? Quote:
03-21-2017, 02:41 PM | #61 |
Rep 92
I got a pair of F32 LED fog lights that I want to fit into my F22 (some work needed because of M-bumper). Anyway, I just tested them with a laboratory power supply at voltages between 12 and 13.7 volts and they do flicker at all voltages, but least at 12.4V. The lab power supply generates a constant DC voltage level, so there can't be any PWM on the input side.
The flickering is at about 80-120Hz (I guess ... have to get a photo diode for my oscilloscope). If this is normal, BMW must use a very cheap CC source. |
03-23-2017, 05:49 PM | #62 |
Rep 92
And here are my results...
The lights have a 200Hz PWM with some random 30-100Hz peaks that cause some kind of short term flickering I will contact BMW to find out if this is normal. If so, I will go for some bulb replacements as well or 3D print my own fog lights. Last edited by bmw_fascinated; 04-08-2017 at 06:33 AM.. |
02-10-2018, 11:45 PM | #63 | |
Rep 10,473
What did you find out? |
03-03-2018, 07:26 AM | #64 |
Rep 92
I never was able to reach someone of the engineering department. All email requests ended like: Give us your address so the local dealer can check your car.
After I had driven a Mercedes with LED headlight that appeared to me like stroboscopes, i believe all the manufactures do not bother this issue since only a few people complain and they can save a few bucks on every light... My solution are the Philips H8 LED fog lights. Had to code it the same way as the original LED lights and with a little cap on top no one ever recognized them as not BMW parts. |
04-13-2018, 04:20 AM | #65 | |
Rep 2
mirror side marker
Hello there , I want to keep the signal lights on the exterior mirror of the F30 constantly on. Can you help with encoding? :yardım et: :yardım et: |
07-29-2018, 11:49 AM | #66 |
Rep 65
Hi, I did retrofit OEM LCI led fog lights and was doing some research for the coding. I don't have esys and use bimmercode instead, so I can't code VO for led fog lights.
When looking at the coding for other factory led's in the car (like halo's, rear led strips, third brake light and mirror turn signal), they have some identical coding, that differ from the coding of halogen bulbs. I think the right coding for factory led fog's should be: 3061 NSW_R_CCM -> vor 7/12 or ab7/12. Mine is set to (before)vor 7/12(month/year) and I think it should be (after)ab 7/12 3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv 3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv 3061 NSW_R_IS_LED -> aktiv 3061 NSW_R_UE_SPG_SCHUTZ -> nicht aktiv - all current leds are set to nicht aktiv and all incandescent to aktiv. So change to nicht aktiv 3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% 3062 MAPPING_ABBIEGEL_R_FIXED_PWM -> fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed 3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% 3063 MAPPING_NEBELSCHW_R_FIXED_PWM ->fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed * 3061 NSW_L_CCM -> vor 7/12 or ab 7/12. Mine is set to (before)vor 7/12(month/year) and I think it should be (after)ab 7/12 3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv 3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv 3061 NSW_L_IS_LED -> aktiv 3061 NSW_L_UE_SPG_SCHUTZ -> nicht aktiv -- all current leds are set to nicht activ and all incandescent to aktiv. So change to nicht aktiv 3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% 3062 MAPPING_ABBIEGEL_L_FIXED_PWM -> fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed 3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% 3063 MAPPING_NEBELSCHW_L_FIXED_PWM ->fixed - all current leds are set to fixed and all incandescent to pwm. So change to fixed kurzschluss - don't change default value (aktiv). dualsp - don't change default value (nicht aktiv). |
