02-15-2018, 03:27 PM | #1 |
Rep 196
245/40R19 & 275/35R19, too big??
Installing on 19X8.5 and 19x9.5, width is good but I would like a little more sidewall for comfort on new england roads. Anyone running this size?
02-15-2018, 07:04 PM | #2 | |
Rep 6,731
What are the offsets of your 19" wheels front and rear? - Max
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
02-15-2018, 07:34 PM | #3 | ||
Rep 196
19x8.5 ET32, 245/40R19 Rear 19x9.5 ET40, 275/35R19 I?ve checked the width clearance compared to my stock 403 rims with 12mm front and 15mm rear spacers. I?m confident width of new setup is fine but unsure what diameter increase may do up front when turning. |
02-16-2018, 11:38 AM | #5 |
Rep 547
I have 19x8.5 ET35 245/40/19 front 19x10 ET44 275/35/19 rear and I got those sizes for the same reason as you. I wanted more comfort and protection with the taller rubber for the horrible NYC roads.
Rears are perfectly fine I have no issues at all. Fronts do rub slightly on full lock but other than that no issues. Pretty happy with this setup as it lowers the massive wheel gap on xDrive.
Current: 2020 M340xi Previous: 2016 340xi |
02-16-2018, 12:52 PM | #6 | |
Rep 495
02-16-2018, 02:48 PM | #7 |
Rep 1,353
Im running 245/40 front and 265/35 rear Conti Extreme Comtact DWS06 on a stock 19’s 442’s lowered with H&R Supersport springs only with 12mm front and 15mm rear spacers. No problem at all.
CTDrifter84.50 |
02-16-2018, 03:03 PM | #8 | |
Rep 4,314
do 245/40/19(26.7") most beefy, fix speedo error, however the outer shoulder may rub fenderwell liner at full lock depending on offset, ride height, tire brand/model or 255/35/19(26"), oem rear size all around(square) or 235/40/19(26.4"), slightly taller than oem, a bit narrow on treadwidth. somewhat fix oem speedo error. http://f30.bimmerpost.com/forums/sho...=245%2F40%2F18 http://f30.bimmerpost.com/forums/sho...35%2F19+square Last edited by alohasurftoad; 06-07-2021 at 08:15 AM.. |
Rokoz293.00 |
02-17-2018, 05:45 AM | #9 | |
Rep 196
Got a pic? Do the tires poke at all or are they flush with body? |
02-17-2018, 07:29 AM | #10 |
Rep 154
265/35r19 is a perfect rear size and does not need a fender roll.
