BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Leaf Blower Effective If Not Frequently Waxed?
      02-03-2016, 01:14 PM   #1
Mjolnir63
Drives: 2016 BMW 340i
Hi Guys,
I am thinking about buying a electric leaf blower to wash my 340i, but I haven't waxed it since December of last year when I bought it. Will leaf blower be effective at all if the car isn't waxed frequently?
As a side question, exactly how is one supposed to use the Dry Me A River from THE RAG COMPANY? (http://www.amazon.com/RAG-COMPANY-Pr...dry+me+a+river )
After the final rinse of the car I would use the towels to dry the car, but there are streak marks regardless of how many times I go over the surface. Any thoughts?
Thanks in advance!
      02-03-2016, 02:50 PM   #2
snj49er
Drives: '20 M5C
If the water beads well on the paint, it's a pretty simple matter to encourage it to run off with a blower. As a final step of your rinse, try the "sheeting" method with a bare-end hose (no spray nozzle). If your paint is hydrophobic, it should look a lot like this: http://www.detailedimage.com/Auto-De...ying/#sheeting
But if the water doesn't bead, it's much more of a struggle using a blower...you'll wind up trying to dry the car more thru evaporation. At that point, you're probably better off with a towel.
      02-03-2016, 04:33 PM   #3
Fronzdan
Drives: '24 M240 xDrive
Leaf blower works fine, even if you're not getting a "just waxed" beading. As mentioned, it's a bit of a combination of evaporation and blowing water off. But it still works and works well.
      02-03-2016, 06:00 PM   #4
Mjolnir63
Thanks for the replies guys! I will get electric blower then.
      02-03-2016, 06:31 PM   #5
SDH
Drives: .
Originally Posted by psde2F30 View Post
Hi Guys,
Thanks in advance!
If you're getting streaks then you need a better towel! I use leaf blower then mop up spots with mf towel
      02-03-2016, 07:58 PM   #6
Mjolnir63
O man...I just bought them from Amazon and used them once...
Which towel do you guys use?
      02-04-2016, 02:06 AM   #7
SDH
Drives: .
Not much use to you really as this is a UK based company but I use this...
http://www.cleanyourcar.co.uk/microf.../prod_634.html
You really need to be looking at the polyester/polyamide ratio (its ingredients if you like) and the grammage (weight). I'd recommend 70% polyester, 30% polyamide with a minimum grammage of 300 g/m²
Most importantly when you wash them use a low temperature (40 °C) using a non-biological liquid detergent (avoid soap powders and detergents containing bleach or fabric softeners) and don't use any separate fabric softeners or the towel will not absorb water as it should.
EDIT...
If it helps this is what i'll be buying for my next drying towel
http://www.polishedbliss.co.uk/acata...ryer-cat5.html
I haven't used a Gyeon product yet that I wasn't impressed by
      02-04-2016, 07:51 PM   #8
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
I use those towels and don't get streaks. Main thing is to not wash in the sun, if you are.
      02-09-2016, 11:09 PM   #9
Baldmonkey22
Drives: 2016 340i
I use a leaf blower on the Windows, bumpers, wheels, door handles and mirrors to get the water out of the spots that will continue to drip, then finish with a towel.
      02-13-2016, 11:41 AM   #10
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
if you don't have good protection a leaf blower will only take you so far. however it will be worth it because you can at least get all the joor jambs and problem areas where water builds up.
invest in a nice sealant to get better and longer protection. check out sonax polymer netshield if you're interested going that route.
      02-13-2016, 12:51 PM   #11
vanbmw
vanbmw's Avatar
Drives: 2015 Black 335i
The leaf blower is still worth using when your wax/sealant is loosing its gusto! The good news is when I notice the leaf blower isn't working quite as well at getting water off then I know it is time to add a coat of sealant.
      02-19-2016, 11:50 AM   #12
Mjolnir63
I have tried the blower and was pleasantly surprised, despite not waxing the car for about 3 weeks.
Also found that quick detailer/wax can be used to help dry the car without streaks.....the more you know haha
      02-26-2016, 07:58 PM   #13
MSportTune2
Aland Islands
80
Drives: F30 MSport
After I bought the Bosch blower, the manual says not to blow directly at water as it may cause shorting!
Anyway, it is great for blowing off hard to reach areas where water accumulates like window seals, rims etc. Great as a duster as well to get rid of the dust especially on rims.
For blowing at wide area, we should make a wide nozzle and attach to the circular rubber nozzle. I think it will be more effective.
      05-09-2016, 12:18 AM   #14
power-fade
power-fade's Avatar
Drives: Ultimate Driving Machine
I use a foam cannon attachment with my pressure washer to wash car if isn't too dirty; if really dirty I use the 2 wash bucket method to wash, then dry with the metro blaster car dryer; and then clay entire car, seal the paint with sealant/polish and finish it off with light coat of carnauba wax.....all day job!!!!
The Ultimate Driving Machine
2016 340i xDrive Premium package enhanced, M performance package, 624M
