12-10-2021, 05:23 PM | #1277 | |
Rep 1,590
As far as Sirius working (subscription) after physical retrofit...how is that possible? I did not have that before. Just curious, because I only had 693 from the factory and the retrofit NBT-HU has 655 and I did not even code anything yet, just connected the emulator. Then after coding to 655 I lost the subscription again. |
12-10-2021, 05:25 PM | #1278 | |
Rep 40,884
fe7565552.50 |
12-10-2021, 05:30 PM | #1279 |
Rep 1,590
Thank you for the quick reply. Yes, for the donor NBT-HU I am using a donor VIN that was suggested by your contact (albeit I had my own donor VIN from the actual unit I installed) and I used the ZeitKriterium he advised as well that matches the 609 option date.
12-10-2021, 05:32 PM | #1280 |
Rep 40,884
When first retrofitted, NBT was coded and valid for Sat Radio. If you VO Coded it with other VIN or did not have 655 in FA, it would cease working.
fe7565552.50 |
12-10-2021, 05:39 PM | #1281 |
Rep 1,590
again Duh...I blew a Sirius subscription that dropped in my lap... The donor VIN for the NBT has 655 and also the actual NBT has 655 too but I guess I wiped out the FSC code for Sirius. At least the 609 navigation + NBT unit's 2015 maps and voice still works. I hope I am not going to wipe that out too.
12-10-2021, 05:44 PM | #1282 | |
Rep 40,884
fe7565552.50 |
12-10-2021, 05:58 PM | #1283 | |
Rep 1,590
- my original VIN - the donor-NBT-HU VIN (not used at all). - third-party donor-NBT-HU VIN used to code the NBT (given by your contact). The strange thing is that Sirius started working when I physically installed the donor-NBT-HU + emulator and my car still had all the factory FA codes including 693 and no 655. When coded I removed 693 and added 655 and also used the third-party donor-NBT VIN for the NBT-HU ECU....and that's when the Sirius stopped working again |
12-10-2021, 06:08 PM | #1284 | |
Rep 40,884
SirrusXM is an annual subscription service. Even if it was working initially, it would have expired soon enough. Once all is working, just get a new subscription from SirrusXM. It's not that expensive.
12-10-2021, 06:11 PM | #1285 | |
Rep 1,590
12-10-2021, 06:20 PM | #1286 |
Rep 40,884
12-12-2021, 09:44 AM | #1287 |
Rep 1,590
Shawn, managed to get EBT working. The main problems were a conglomeration of "user-errors":
- the iPhone not being read while Android works -> default "Apple_Sec_Chip" (spelling) setting, fixed via Bimmercode in Expert mode. - missing options to enable menu items like Telephone 1 & 2 and Office, messages, etc -> with my new 10.25" screen vs my old 6.5", in split-screen mode was not aware that pressing "Options" on iController will bring up an additional menu - user profile cannot be set problem -> "Options" menu was not apparent in split-screen mode Again, thank you for your help! Not a big thing, but unfortunately, Sirius did not come back with the working subscription that was enabled on the donor NBT_HU after I VO-programmed it with a third-party VIN and Zeitkriterium for 609 and 6NS. Before I started all the VO coding I backed up all my CAFD files. Do you think I could fish it out and "inject it" back in the NBT-HU ECU? |
12-12-2021, 09:59 AM | #1288 | |
Rep 40,884
Is 6F Sat Radio FSC Code Status = Accepted? You use 3rd party VIN or ther Donor VIN? If 3rd party, how do you know this VIN has active Ssat Radio subscription? Again, I would quit worrying about this. Get NBT all working, then just get a new SirrusXM subscription. It's not expensive.
12-13-2021, 10:33 PM | #1289 | |
Rep 1,590
https://f30.bimmerpost.com/forums/sh...5#post28358175 and ended up using a USB hub that seems to have solved it. Maybe a good idea to wire up the USB outlets where the power cable gets 5V externally and not from the NBT HU. Will see if it remains working for the next few days. Looks like there is a combination of issues that could lead to this problem with older BMWs HUs processing a USB hand-shake for iPhones. May be because of the low current capacity of the USBs vs the newer iPhones power-needs, maybe due to enabling EBT, and enabling video, etc on the USB ports. As others mentioned it in that thread this may be too much for some antiquated BMW setups even with the latest software. Last edited by fe7565; 12-15-2021 at 05:12 PM.. |
03-07-2023, 03:43 AM | #1290 |
Rep 19
NBT with steering buttons not working to answer call's
Hello,
I recently add a MFSW to my F20 that does not bring from factory any buttons on steering wheel. I code the FA with the code 249 and 544. Now the volume up and down works like a charm, but when I receive a call I cannot answer it from the steering wheel. What am I missing? I do know that for the CC work I need to change my cluster. Best regards, Bruno Rosa |
05-06-2023, 06:20 PM | #1292 |
Rep 40,884
Yes. Combox not needed for coding other ECU's.
Fru5tum0.00 |
06-29-2023, 11:08 AM | #1294 |
Rep 40,884
Combox does not contain any FSC Codes.
06-29-2023, 11:51 AM | #1295 |
Rep 5
This is what I wanted to hear, excuse my misinformation, thank you
If you send PM, I can send back to you, I am trying to troubleshoot this system on E chassis if you’re familiar. nav is completely greyed out post combox retrofit |
