12-05-2016, 06:33 AM | #1 |
Rep 205
Drives: 2014 F30
N55 Downpipe Install guide?
I'm in search of a DIY guide for a downpipe install on an N55 (non-xdrive). Does such a guide exist?
12-05-2016, 03:11 PM | #3 | |
Rep 190,777
Im going to start using that link when customers ask me for an install guide
jgoens3787.50 |
12-05-2016, 04:41 PM | #4 |
Rep 316
Only thing I would add, which I'm not sure if it is in the 2addicts thread, is the part numbers for the turbo to DP gasket/clamp and the single use crush gasket that connects the DP to the midpipe. See here for the proper reference numbers: http://f30.bimmerpost.com/forums/sho....php?t=1075544
I know it is x drive related, but the part numbers for gaskets and such should be the same. |
jgoens3787.50 |
12-05-2016, 06:35 PM | #5 | |
Rep 367
12-07-2016, 11:35 AM | #7 |
Rep 67
I find it easier to drop the entire exhaust system and then connect the DP to the midpipe section. That way you can double check all around that there won't be any exhaust leaks. I then snug up all the clamps but leave them loose enough that I can rotate the DP to align everything before tightening all the way.
12-07-2016, 08:00 PM | #8 |
Rep 205
Drives: 2014 F30
Thanks for the link!
