      06-16-2013, 03:16 PM   #3829
shawnsheridan
shawnsheridan's Avatar
Originally Posted by EclipseDS View Post
@Shawn,
I tested 3.18 with 48.1 on F10 M5. While I can connect and all, I can't activate FA to try and code. I suppose I need newer PSDZ and possibly E-Sys 3.22.5, right? Build date is 0712. Thanks.
What is the error code when trying to activate FA?
      06-16-2013, 03:26 PM   #3830
EclipseDS
Drives: Black Sapphire 328i
There was none. It just wouldn't activate. Would 48.1 still work on 0712 M5?
      06-16-2013, 03:39 PM   #3831
shawnsheridan
The production date is irrelevant. All that matters is what the last version of ISTA/P was that was used to program the car.
Your I-Step current will dictate which PSdZData version you need, which in turn will dictate which E-Sys version you need.
http://www.f30post.com/forums/showpo...postcount=1403
      06-16-2013, 04:41 PM   #3832
EclipseDS
ah, I checked it and didn't take a note. If I recall it correctly, it is F010-12-11-513. I probably mixed up 11 and 12 but I'm pretty sure about the 513 part, if that's of any help.
BTW, I have E-sys 3.22.5. Can you send me info on PSDZ 49.4? Thanks.
      06-16-2013, 06:17 PM   #3833
shawnsheridan
PM sent.
      06-16-2013, 06:44 PM   #3834
Twheeler
Drives: 2013 F30 320i Eff Dyn
Hello guys,
I'm new to coding. I've ordered an Obd to Ethernet cable, can somebody let me know where I can get the e-sys software to start interrogating my car? It's a 320i efficient dynamics 2013 model.
Many thanks.
T
      06-16-2013, 06:47 PM   #3835
shawnsheridan
Originally Posted by Twheeler View Post
Hello guys,
Many thanks.
T
You cannot receive PM's with just 1 Post. Post an email address or increase your post count.
      06-17-2013, 02:54 AM   #3836
westisldkiwi
Drives: 328i M-Sport Estoril Blue
Coding bluetooth option
Ordered F30 328i M-Sports. Still have a chance to change options. Now not sure if I should have added "extended connectivity of Bluetooth/USB with Voice Control". Have Nav Professional, HUD options. Can this be coded?
      06-17-2013, 08:19 AM   #3837
Twheeler
Oops, didnt realise this. I'm at tms@hotmail.co.uk. The cable has just arrived too, so I'm like a kid in a sweet shop at the moment.....
Terry
      06-17-2013, 09:38 AM   #3838
nyc_king
Drives: 2013 328i xDrive M Sport
What else is there to code? so far i added the speed to the instrument cluster, folded my mirrors with keyfob, closed windows with keyfob, shutoff amber sidemarkers, turned on tail lights with DRL, put temperature and pressure with TPMS, shut off the legal disclaimer, and changed the units of my sports displays.
      06-17-2013, 09:43 AM   #3839
shawnsheridan
Terry
Email sent.
      06-17-2013, 09:57 PM   #3840
aspang86
aspang86's Avatar
Drives: 2012 BMW 320i
Guys iam trying to figure out why the sports display that I got coded in my car doesn't work. I have a 2012 BMW 320i without the navi screen. The gauges are showing on my screen however they are just reading 0. I saw someone on youtube with the same basic i-drive screen have the gauges functioning. Any thoughts or suggestions? Thanks.
      06-17-2013, 10:38 PM   #3841
kon
Singapore
Drives: F30 310i > G20 310i
Originally Posted by ykau View Post
Hello Shawn!! Just PoP in and say "Hello" (-:
you should hang around here more.... waaaaay friendlier than "the other one"
      06-17-2013, 10:42 PM   #3842
kon
Singapore
How much does it cost to add the option?
The option that you'll really want is the iPod BMW Apps... because retrofitting this is a pain as it involve hardware... If you have this from factory, you are pretty safe!
Voice control, you have Nav, so are you sure it's not standard?!
      06-17-2013, 10:57 PM   #3843
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
what codes did you use to get it to show you sport display?
      06-17-2013, 11:22 PM   #3844
Frogman
Drives: 2012 F30 328i
I've also tried coding this on 3 other non-NAV F30's (N20, N26, and N55 engines) with no luck.
As you say, the screen displays, but no data (red indicators) show.
We think it has to do with some sort of dependency on having 609 (navigation). It's like the data feed from the engine isn't getting to the display without having the HU_CIC (Non-NAV has HU_ENTRY).
I don't know of anyone getting this to work on an F30. Other have it working on some (not all) F10's.
Sorry!
      06-17-2013, 11:28 PM   #3845
Frogman
HU_ENTRY / 3000 / EFF_DYN_SPORT_CID to aktiv
BUT, it only shows this background screen, neither of the indicators are show, so it's basically useless.
Has anyone been able to get the sports display to show the power/torque meters on a non-nav F30? I haven't see anyone post that they have yet.
      06-17-2013, 11:37 PM   #3846
Chris@codemybimmer
i think the difference in in the euro spec's
business navigation, which has the cic unit with a 6.5" screen
so i guess that will alow them to read that missing information that ENTRY cannot read
      06-17-2013, 11:49 PM   #3847
aspang86
aspang86's Avatar
HU_ENTRY-> 3000 -> EFF_DYN_SPORT_CID set to Aktiv
HU_ENTRY -> 3000 -> EFF_DYN_SPORT_UNIT set to Aktiv
      06-17-2013, 11:54 PM   #3848
Frogman
HU_ENTRY (or HU_CIC) -> 3000 -> EFF_DYN_SPORT_UNIT enables setting the power/torque units in the settings menu.
I've coded many cars with EFF_DYN_SPORT_UNIT because for some reason the cars are coming into the US (even non-ED) with metric units and by default and they are not changeable without enabling this code.
      06-18-2013, 09:17 AM   #3849
aspang86
aspang86's Avatar
That sucks! I wanted to see if the gauges would register the extra power I am making with the BMS 1.
      06-19-2013, 08:45 AM   #3850
snovi
Drives: 2015 F80 M3 - San Marino Blue
2015 BMW M3  [0.00]
Just got my cable in today for my 335 Shawn, could you pass along the latest e-sys + token info for me?
Much appreciated!
