BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > "Cruise Control Can Not be Activated" Error After Cluster Replacement
      12-17-2021, 04:13 PM   #1
Aceattack52
Drives: 2013 328i
Earlier today I posted this on another section of the forums. After getting no responses I started looking around and the coding section seems to be a better fit. I'm a little out of my league here- you guys are way smarter than I am and hopefully someone can help me. Here is my original post:
Hey guys,
I recently had some problems with the basic cluster in my 2013 328i. I replaced the cluster with a 6WA cluster and had Code My Bimmer (they did a great job) code the new cluster to the car.
After the cluster replacement, everything works great except for the cruise control. Turning on cruise control works but when I press the button on the steering wheel to set the speed, it comes up with "cruise control can not be activated". Cruise control worked fine right before the cluster replacement.
I let Code My Bimmer know and they told me the integration level needs to be upgraded since the integration level of the cluster is higher (newer) than the I-level in the car. This makes sense to me but I don't know where to start. Can you guys give me some direction on how to upgrade the integration level? Maybe the cruise control problem can be solved another way? Thanks!
I have:
-ENET cable
-40amp battery charger
-Rheingold 4.10.15.15600
-WinKFP 5.3.1 (not sure how to use)
      12-17-2021, 07:18 PM   #2
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Hi,
You need to flash your car.
But you should try by flashing with esys.
Winkfp is not what you need for flashing F-series.
You can first begin with flasing your NBT, ICM, DSC and FEM_BODY
      12-18-2021, 12:07 AM   #3
Adrian_CRG
Romania
25
Drives: BMW 640xd
Problem is caused by ilevel difference between gateway and KOMBI.
You need to flash both KOMBI and FEM_GW to same ilevel but is recommended to flash complete car to latest ilevel.
Winkfp is for flashing E series cars, you will need Esys with full psdzdata to flash car.
Current cars: 2016 F13 640XD ; 2017 F36 420XD
Past cars: 2010 E93 320i ; 2008 E60 530XD ; 2006 E90 320D
