BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > **working Enahcned Bluetooth Code For Bimmercode***
proTUNING Freaks
      03-23-2018, 11:44 AM   #1
Youngjnr
Drives: BMW E90 + BMW F30
just putting this here because of the nightmare i had trying to get EBT with office album art Etc. this code is for those who have like HU_champ2 aka in bimmercode HU_CICHB with a combox this what you need to get enhanced Bluetooth via bimmercode i tried another method by another user but it just stopped my Bluetooth altogether so to save someone else the headache here is the code you need.
HU_CICHB > AUDIO_TUNER_TRAFFIC 3002 > AUDIO_OFFSET = aktiv
HU_CICHB > HMI 3000 > CDMM_AUX_HU = nicht_aktiv
HU_CICHB > HMI 3000 > CDMM_USB_COVER_ART = aktiv
HU_CICHB > HMI 3000 > SECONDARY_HFP = aktiv
HU_CICHB > HMI 3000 > SVS = aktiv
HU_CICHB > HMI 3000 > SYSTEM_TTS = aktiv
HU_CICHB > SYSTEM_EINSTELLUNGEN 3004 > SOFTWARE_UPDATE_ASSISTANT = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > ADRESSBOOK = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > API_TYPE = combox
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > BT_PHONE_INSTANCE_ID = wert_2
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_BLUETOOTH_AUDIO = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_AUDIO_DOUBLE = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_AUDIO_SINGLE = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_COMPOSER_IPOD = enabled
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_COMPOSER_MTP = enabled
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_HMI = new
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CDMM_USB_POD_BOOK = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > CONNECTIVITY_SYSTEM_VER = ecu_sw_vid
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > DATACOM_INTERFACE = combox
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > DATACOM_TRANSFER = mamac
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > EXTERNAL_CALL_LISTS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > FUNCTIONALITY_VIEWER = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > HDD_ACCESS_VIA_ETHERNET = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MACRO_PIM = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MESSAGE_FILTER = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MIC_OVER_MOST = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MICROPHONE = no_microphone [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > MUTE_BUTTON = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > NAD_PHONE_INSTANCE_ID = wert_1
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > ONLINE_BROWSER = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_ALL_INC_CALLS_LIST = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_CONFERENCE_CALL = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_MPC = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_OBJPUSH_MENUE = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_RESPONSE_HOLD = nicht_aktiv [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_SMS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONE_TYPE = combox
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PHONEBOOK_CACHING = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PICTURE_ALBUM_ARTS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PIM_CROSS_USE = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > PIM_TTS = aktiv
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > SINGLE_OR_MULTILINK = multilink
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > TDA_TSR_INSTANCE_ID = 0x0 [Default]
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > TELEMATIC_INSTANCE_ID = instanceid_ 0x01
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > VCARD_OVER_MOST = aktiv
Combox_Media > BLUETOOTH_PARAMETER 3004 > A2DP_AVRCP_EIN_AUS = aktiv
Combox_Media > BLUETOOTH_PARAMETER 3004 > BT_EIN_AUS = aktiv
Combox_Media > GENERAL_PARAMETER 3000 > MAIN_BOARD_ALONE = ecallboard_present
Combox_Media > MULTIMEDIA_PARAMETER 3003 > API_EIN_AUS = aktiv
Combox_Media > SWUP_PARAMETER 3005 > SWUP_ENABLE_SW_UPDATES = aktiv
Combox_Media > SWUP_PARAMETER 3005 > SWUP_SOURCE_ONLINE = nicht_aktiv [Default]
Combox_Media > SWUP_PARAMETER 3005 > SWUP_SOURCE_USBMSCDD = aktiv
Combox_Media > TELEMATIK 3006 > GPS_FROM_MOST = nicht_aktiv [Default]
Combox_Media > TELEMATIK 3006 > TDA_TSM_ACTIVE = nicht_aktiv [Default]
      04-18-2018, 09:14 PM   #2
kaiotonussi_2
Drives: 320i F30 Sport GP
Hi! Youngjnr . To this work, do i need to change in the FA from 6NH to 6NS?? Or by making this modifications EBT will work fine?
      04-19-2018, 09:33 AM   #3
Youngjnr
Yes this all that's needed to enable ebt no need to change fa
      04-21-2018, 10:14 AM   #4
rak299
Drives: 2021 M3 6MT
Was this done via android or ios?
      04-21-2018, 10:52 AM   #5
Youngjnr
Android: Samsung galaxy s9
rak299600.50
      04-21-2018, 12:10 PM   #6
Salty B.
Drives: 2014 335i 6MT MSport
Thanks, after messing around with Bimmercode and various forum posts these settings worked, but ONLY after I had the car forget the phone and the phone forget the car, and even then it only worked once. But the next day, it started working reliably. So happy not to plug in the USB anymore which was pretty unreliable. My car does not have Navigation or Tech package.
I did enable album art display over USB but that didn't work. Also these changes changed the audio playback screen for USB to match that of BT so now I can push down the iDrive knob to skip tracks vs using the phone and/or the switch on the dash which is kind of a reach.
Used BCode on iOS.
Update: I needed to charge my phone so I plugged it into the USB thinking the BT audio would continue doing its thing. Nope. I got a message in the iDrive screen that BT Audio was being disabled and I couldn't get it back, so I did a code restore from the last good config. We'll see if that works tomorrow.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE
2001 E53 M54 5MT peeling green/black, well-optioned
      05-15-2018, 07:00 PM   #7
gee38l
Australia
Drives: 2013 320D Modern Line
So it seems i have the same headunit but without the combox does anyone know how to get this to work, I had a play and managed to get the options for blutooth audio to show but when you try and use it doesnt work.
      05-23-2018, 01:48 AM   #8
RoopD
Drives: F30 Alpine Weiss
In which ECU are these settings?
RoopD
      06-03-2018, 09:55 AM   #9
Dobbin
Drives: 2013 F31
I’ve just followed these instructions on my 2013 F31, which seems so far to have worked.
I can’t see any album art, but looks like Bluetooth audio works. My car does have navigation.
The only worry I have, is that if you go back in to BimmerCode, outside of expert mode, it shows a head unit coding error. Is that normal?
      06-09-2018, 07:20 PM   #10
marell1000
Drives: F30 320 - yr 2013
Smile It worked!!!
First I have to thank you guys very very much for this post and detailed instructions!
I was trying for 2 weeks and today I followed this instructions and it finally worked on my F30 year 2013.
I used:
1- bimmercode app..
2- My iPad
3- a vpeak Bluetooth conector. Link below:
Veepeak OBDCheck BLE Bluetooth 4.0 OBD2 Scanner Auto Diagnostic Tool for iOS & Android, Car Check Engine Light Trouble Code Reader Supports Year 1996 and Newer Vehicles in the US https://www.amazon.com/dp/B073XKQQQW..._L0ghBbD02R5ZK
I also coded a lot of other little things with bimmercode app “simple” mode. I highly recommend it.
      07-13-2018, 06:52 PM   #11
MacsRule
MacsRule's Avatar
Drives: 2012 335i
If you have HU CICHB with Commbox, these directions are 100% legit. Just finished coding it and it works like a charm! Thanks Youngjnr.
I also had connection problems when having to check off so many different things. I got around it by coding about 5 or 6 at a time. That way, for some reason, I never lost connection.
      08-15-2018, 11:11 AM   #12
Smithys F31
Drives: 63 BMW 320D Touring
EBT Still no joy - BMW say it cant be done, ever. Are they correct?
Hi All, brand new here but have been following with interest.
So...
Not long ago I got a ex lease 320D Touring which I am loving. 63 plate. And I got a little excited when I thought that I could get BT to work to play spotify, but nothing happened, even via USB... Might be the phone? Nonetheless I searched about until I happened on this forum, with amazing people helping out others. So Armed with the info, Bimmercode App and hardware I thought I would give it a go.
I have tried and checked the settings posted by Youngjnr, thank you btw. Using iCar pro via Bluetooth and android via Galaxy S8.
I get the BT Audio to appear but it still refuses to connect to the phone. That Please wait... message.
It did spark into life once and I thought I was in, asked me to pair a phone, then please Wait... again. Done the forget phone stuff too.
I have also been in touch with Shawnee at BMW connected drive help and she finally said, 'due to the age of the car it is not going to happen... ever. I can't even perform an aftermarket upgrade as it has to be set in the factory. I think I was being mugged off.
As I said, I have double checked the settings and it is all as it should be. There is a Combox in the boot and the Nav is basic not Pro, cant remember the version off hand.
If anyone can assist I would be really grateful. If not, keep up the good work. I have managed to turn the radio off when I open the door and get the speed showing up and tyre pressure showing, so happy with all that.
Cheers
      08-15-2018, 11:16 AM   #13
Youngjnr
CDMM_Bluetooth_Audio
CDMM_BT_DATABASE
AUDIO_PLAYER_ON_OFF
BT_MODUL_ON_OFF
A2DP_PROFILE
check these parameters are exactly as the code I posted these was set wrong for me and please wait... occurd on my hu if there not in the code posted above make sure they are on the default setting and not aktiv also code one ecu with only a few changes at a time doing it all together can cause errors
      08-16-2018, 01:14 AM   #14
simo2007
Drives: F21 M135i
CDMM_Bluetooth_Audio*
CDMM_BT_DATABASE*
AUDIO_PLAYER_ON_OFF*
BT_MODUL_ON_OFF*
A2DP_PROFILE*
Tried to code EBT on my F21 yesterday and have been experiencing similar problems to people in this thread, Bluetooth appears in the external devices menu and when trying to pair it just says 'Please wait...' continuously.
Youngjnr, the parameters you listed (that I've quoted) aren't actually explicitly mentioned in the long list of parameters you posted further up the thread, should these be left to default or changed to aktiv?
      08-16-2018, 06:21 AM   #15
Smithys F31
CDMM_BT_DATABASE*
BT_MODUL_ON_OFF*
A2DP_PROFILE*
Just an update - Firstly I am super happy because it worked . Thank you very much Youngjnr. Went through it slowly and updated code regularly.
Just a few differences for me:
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > ONLINE_BROWSER = nicht_aktiv [Default] My default was a BMW online browser so I left it to that.
and:
HU_CICHB > TELEFON_TELEMATIK_ONLINE 3003 > TDA_TSR_INSTANCE_ID = 0x0 [Default] My default was 0x1 so I left that as was too.
Can't get the pictures but maybe if I log into the bmw browser they will show.
Just happy to get the music to work. I would not have gone to all this trouble if my phone jack hadn't broken on phone, and I do like a challenge. Though all you guys did the heavy lifting.
Many thanks, Ill email BMW connected services and let them know that it can be done. I have no warranty to worry about.
      08-16-2018, 07:19 AM   #16
simo2007
Drives: F21 M135i
Managed to get it working, I turned BT_MODUL_ON_OFF back to nicht_aktiv and everything works perfectly!
Simon8995.50
      08-28-2018, 12:45 PM   #17
bjpinub
Drives: 2014 BMW 328xi
Enhanced Bluetooth & Office for 2014 F30 6NH??
Youngjnr, I have a 2014 BMW 328i xDrive with combox and 6NH option. Will your steps enable enhanced Bluetooth, office, and voice/hands-free options like text to speech and speech recognition?
      08-29-2018, 03:12 PM   #18
Youngjnr
it will enable it (Bluetooth and office)but not text to speech
      09-29-2018, 10:47 AM   #19
stefan330
Drives: Bmw 520 f10 2012
Hi everyone,
I tried to do this because my bluetooth menu is stuck on "please wait" message and i just wanted to check if all parameters are correct. I accessed HU_CIC menu in expert mode but i can't find the combox menu and i am sure that i have combox in the trunk. Does this mean that my combox is dead?(My aux input and USB are also not working).
      10-15-2018, 03:31 PM   #20
Simon89
Simon89's Avatar
Drives: F30 330D XDrive
Thank you for posting this! I was also stuck at the 'please wait' screen and couldn't do anything else but leaving the "BT_MODUL_ON_OFF" as nicht_aktiv worked just fine for me.
13' F30 330D XDrive
      01-17-2019, 02:01 PM   #21
Phoenix704
Phoenix704's Avatar
87
Drives: 2014 328i
CDMM_BT_DATABASE*
BT_MODUL_ON_OFF*
A2DP_PROFILE*
I completed the original post on my 2014 328i Luxury with Non-Nav / HK. Confirmed combox in trunk. Bluetooth showed up as a greyed out option in the CD/Multimedia menu, but the car wouldn’t recognize the phone as a music source (music note icon next to phone in bluetooth device list).
I then made sure that all of the above peramaters were “aktiv” and bam, works like a charm.
Thanks for posting!
      01-17-2019, 05:59 PM   #22
gurpzz
Drives: 2013 BMW 328i xdrive
WORKS LIKE A CHARM!! thank you so much!
2013 BMW 328i xdrive - Imperial Blue - Modern Line
