12-17-2021, 04:13 PM | #1 |
Rep 17
"Cruise Control Can Not be Activated" Error After Cluster Replacement
Earlier today I posted this on another section of the forums. After getting no responses I started looking around and the coding section seems to be a better fit. I'm a little out of my league here- you guys are way smarter than I am and hopefully someone can help me. Here is my original post:
Hey guys, I recently had some problems with the basic cluster in my 2013 328i. I replaced the cluster with a 6WA cluster and had Code My Bimmer (they did a great job) code the new cluster to the car. After the cluster replacement, everything works great except for the cruise control. Turning on cruise control works but when I press the button on the steering wheel to set the speed, it comes up with "cruise control can not be activated". Cruise control worked fine right before the cluster replacement. I let Code My Bimmer know and they told me the integration level needs to be upgraded since the integration level of the cluster is higher (newer) than the I-level in the car. This makes sense to me but I don't know where to start. Can you guys give me some direction on how to upgrade the integration level? Maybe the cruise control problem can be solved another way? Thanks! I have: -ENET cable -40amp battery charger -Rheingold 4.10.15.15600 -WinKFP 5.3.1 (not sure how to use) |
12-17-2021, 07:18 PM | #2 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Hi,
You need to flash your car. But you should try by flashing with esys. Winkfp is not what you need for flashing F-series. You can first begin with flasing your NBT, ICM, DSC and FEM_BODY |
12-18-2021, 12:07 AM | #3 |
Rep 31
Problem is caused by ilevel difference between gateway and KOMBI.
You need to flash both KOMBI and FEM_GW to same ilevel but is recommended to flash complete car to latest ilevel. Winkfp is for flashing E series cars, you will need Esys with full psdzdata to flash car.
Current cars: 2016 F13 640XD ; 2017 F36 420XD
Past cars: 2010 E93 320i ; 2008 E60 530XD ; 2006 E90 320D |
