03-18-2014, 06:18 PM | #6029 | |
Rep 1,892
No, you don't need a token to do that. You only need the token to do FDL coding. When you try to connect, does it connect via VIN? It should show your VIN in the connection area near the bottom of the window. Are you selecting the F020 (not _DIRECT) chassis? |
03-18-2014, 06:25 PM | #6030 |
Rep 40,789
You need to write fake VIN to NBT using the FSC Extended module => WriteDataByIdentifierVIN, then VO Code Head Unit, Update Services via iDrive, and then write original VIN back to NBT.
03-18-2014, 06:53 PM | #6031 |
Rep 234
Yes and nope, I had been connecting to the _Direct. Thanks. That worked.
03-18-2014, 08:52 PM | #6032 |
Rep 40,789
If you are using the _DIRECT connection, that would be your problem reading VCM.
03-19-2014, 03:41 AM | #6033 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
03-19-2014, 12:14 PM | #6034 |
Rep 12
links, again!
Hi Shawn,
Would you please pm the links to E-Sys and PSdZData. I plan to use these for a late January 2014 build F31 so if there is a trimmed down version of the data files that is appropriate that would be most welcome. Thanks for your help. Lynn |
03-19-2014, 12:33 PM | #6035 | |
Rep 40,789
There is zero point in backing them up. If they change to "Rejected", changing the VIN back will set them back to Accepted. If something goes horribly wrong and they change to "Cancelled", the original ones are toast. They can't be reused.
03-19-2014, 12:33 PM | #6036 |
Rep 40,789
PM sent.
03-19-2014, 12:36 PM | #6037 | |
Rep 122
You can also save the FSCs via E-SYS > Connect > Expert mode > FSC-Extended but as Shawn told it does not make sense. |
03-19-2014, 05:54 PM | #6039 |
Rep 40,789
Baptism by fire...
03-19-2014, 05:54 PM | #6040 |
Rep 40,789
PM sent.
03-19-2014, 05:56 PM | #6041 |
Rep 19
Thank you. I just tried your links and its telling me that it can not connect to the server. Is there any other link out there to download the psdzdata files?
03-19-2014, 06:00 PM | #6042 |
Rep 40,789
I just PM'd you the most likely solution. Let me know if it worked.
03-19-2014, 07:09 PM | #6044 |
Rep 40,789
Was? Does that mean it is connecting now?
03-19-2014, 10:54 PM | #6045 |
Rep 128
Drives: 2015 BMW x5
I've searched, but can't find the code to get the XM radio to show up in my CIC. Does anyone know how?
03-20-2014, 02:47 AM | #6047 | |
Rep 40,789
But if you get FSC Code, you will need to modify your VO to change 693_PREPARATION_SATELLITE_TUNER to 655_SATELLITE_TUNER, then Import and Activate a 6F Sat Radio FSC Enabling Code, and then VO Code the Head Unit (CIC or NBT).
03-20-2014, 02:49 AM | #6048 |
Rep 40,789
PM sent.
03-20-2014, 03:42 AM | #6049 |
Rep 40,789
I didn't think you can get SDARS (Sat Radio) in Europe, and had DAB instead?
03-20-2014, 03:00 PM | #6050 |
Rep 179
Thanks for the Links shawnsheridan.
I'm just reading and learning what I can before I get my car. So don't have any hands on experience yet. First job is Enhanced Bluetooth (I have ordered Pro Nav) and then things like VIM. A total newibie question but, I have got E-sys and Psdzdata from your links, but am I going to need to buy a token to do what I want to do above? |
