02-13-2023, 04:29 AM | #1 |
Rep 5
330E engine does not turn off at low speeds
hi guys, i got a 2016 330e last year with 40k kms and everything was great. Usually when I drive in traffic, the engine will shut off to use the hybrid. But recently, when I drive around in traffic, the engine stays on and in use.
Hence when I arrive home, my hybrid battery is always full. Is this common? Thanks in advanced! |
02-13-2023, 06:08 AM | #2 | |
Rep 15,858
02-13-2023, 06:39 AM | #4 |
Rep 83
02-13-2023, 06:42 AM | #5 | |
Rep 83
I've fixed the issue both times by just clearing the error codes. You can do that with a code reader that plugs into your OBD2 port, or with ISTA if you have that. |
02-13-2023, 06:45 AM | #6 |
Rep 83
Sometimes when the outside temperature is too low (below 0 °C or so), the car also keeps the engine running because the hybrid battery is too cold. But seeing you're located in Malaysia I don't think that's the problem here
02-13-2023, 06:56 AM | #7 | ||
Rep 15,858
02-13-2023, 08:07 AM | #8 | |
Rep 83
My manual also states that a certain charge state of the high-voltage battery can be maintained or increased with SAVE BATTERY, but it doen't mention anything about setting a target value, like in the image you attached. That's a feature that wasn't implemented until the G20/21, although you'd expect that that's something that could be easily implemented in the F30 with a simple software update... |
HighlandPete6658.50 |
02-13-2023, 08:19 AM | #9 | |
Rep 5
02-13-2023, 08:34 AM | #10 | |
Rep 15,858
Only guessing here, but could that be the issue? A fault, or defaulting to that mode? |
02-13-2023, 09:43 AM | #11 | |
Rep 83
The fact that OP arrives home with a full battery is probably because the car meets one of the conditions to turn the engine on pretty early on in his journey. fakepc could you confirm that when you turn the car on, it starts off in electric mode? If your car turns the engine on after you've pressed the start button, but your battery is still relatively full, you have a somewhat different problem than I have. |
02-14-2023, 08:49 AM | #12 | |
Rep 5
I think we have a similar problem.. my car is always on auto hybrid mode and my car starts in electric. When I exceed the max electric speed limit or anything that turns on the engine, after those conditions arent met (eg i go back to under the max electric speed limit) the engine should turn off and go back to electric but it doesn’t. Might be because i went outstation for 2 days and did not charge my car for 2 days, when i came home and charged it full this happened. Today when I drove to work as usual it seemed to be fine. |
julian20420.50 |
02-14-2023, 09:50 AM | #13 |
Rep 83
Looks like we have exactly the same problem then. So your car started to work normally again by itself? You didn't have to clear any fault codes or anything?
Maybe there's some error that will trigger the engine start-stop to be disabled, and if you leave it for long enough, something will reset and the car will 'realise' that there's nothing wrong and go back to normal. Perhaps I didn't wait long enough for that. I cleared the codes after 2 days and that immediately fixed the issue for me. |
02-18-2023, 10:23 PM | #14 |
Rep 257
Try it in ECO mode instead of Comfort. You can code it to default on start up to ECO.
Now that I did that, my ICE never starts unless I want it to. Only on very cold days, or when the traction battery is low, does the ICE start automatically. Unless I want it too.
2021 i3s AC Schnitzer BMW CCA #67486 |
