12-03-2023, 12:13 AM | #6095 |
Rep 4
12-03-2023, 05:34 AM | #6096 |
Rep 2,369
Drives: E63 645Ci
12-03-2023, 06:48 AM | #6097 |
Rep 5
try to find yr MCU here: https://mega.nz/folder/NNxk0Z6S#876H...older/sBYCjb7R
12-03-2023, 08:28 AM | #6098 | |
Rep 4
Is there another (older) archive of MCUs available anywhere? |
12-03-2023, 10:16 AM | #6099 |
Rep 5
try one more :
https://4pda.to/forum/index.php?show...#entry92824214 and https://drive.google.com/file/d/15Mk...sd_2FvwQ1/view Last edited by Houzzed; 12-03-2023 at 10:42 AM.. |
12-05-2023, 03:48 AM | #6100 |
Rep 3
Drives: BMW 520d F10 B47
Android 10 changelogs
KSW Changelog (M501/SD625/MSM8953)
For further changelogs, see https://kamilbrk.github.io/ksw/updates and Android Automotive Headunits Discord. Android 10 Ksw-Q-Userdebug_OS_v4.2.9-ota Build date 2023-12-25 09:07:23 UTC Summary:
Changes since Ksw-Q-Userdebug_OS_v4.2.0-ota:
Ksw-Q-Userdebug_OS_v4.2.0-ota Build date 2023-09-08 04:03:22 UTC Changes since Ksw-Q-Userdebug_OS_v4.1.6-ota
Ksw-Q-Userdebug_OS_v4.1.6-ota Build date 2023-07-17 05:58:17 UTC Changes since Ksw-Q-Userdebug_OS_v4.0.7-ota
Ksw-Q-Userdebug_OS_v4.0.7-ota Build date 2023-03-23 07:34:25 UTC Changes since Ksw-Q-Userdebug_OS_v4.0.4-ota
Ksw-Q-Userdebug_OS_v4.0.4-ota Build date 2023-03-02 05:01:46 UTC Changes since Ksw-Q-Userdebug_OS_v3.9.6-ota:
Ksw-Q-Userdebug_OS_v3.9.6-ota Build date 2022-12-16 05:37:01 UTC Changes since Ksw-Q-Userdebug_OS_v3.9.4-ota:
Ksw-Q-Userdebug_OS_v3.9.4-ota Build date 2022-11-24 11:20:16 UTC Last edited by kamilbrk; 04-23-2024 at 05:21 AM.. |
12-05-2023, 04:15 AM | #6101 | |
Rep 4
Unfortunately, the first ones are for NBT/C*C and the last one (although for E39) is by dGS. I'm need an older i-Bus version from dLZH (preferably GTH), so I think anything that's like: * dLZH-E39-GT... (5er) * dLZH-E38-GT... (7er) * dLZH-E46-GT... (3er) * dLZH-E83-GT... (X3) should do. Unfortunately, C*C or NBT versions won't work for me. Is there anyone with a version like those above (or similar)? Or knowing a seller that has similar models? Or even selling the firmware (I'm getting desperate I'm trying to avoid replacing the whole thing or having to live with just the Android part) |
12-07-2023, 08:53 AM | #6102 |
Rep 294
12-11-2023, 07:19 AM | #6103 | |
Rep 51
12-12-2023, 08:49 PM | #6104 |
Rep 4,921
Anyone running a different launcher and using 4.1.6 or 4.2.0? Every since loading 4.1.6, it tends to "forget" that flowUX synesthesia is my default launcher. I set it, and after it sits for a while, it defaults to prompting on the next boot.
Tried factory resetting, but Ksw is notorious for hiding saved configs that don't get erased on the reset, so it seems something is lingering. |
12-13-2023, 09:28 AM | #6105 | |
Rep 51
12-13-2023, 06:21 PM | #6106 |
Rep 4,921
12-14-2023, 03:25 PM | #6107 |
Rep 8
few questions for y'all, have had my android 11 (supposedly) 12.3, for a year now, got it pretty dialed in, but it has a few quarks. for instance, if i turn the blinker on it will change to the main idrive screen if i'm in the android portion, not all the time, but more frequently than i please. anyone else come across this?
also how do i get my android screen to automatically connect to my phones hotspot vs me having to manually disconnect and reconnect?? lastly i can get speak to text to work, example im on waze youtube, etc, press the microphone on the screen, the google assistant or what ever it is pops up and i can see the 4 google dots moving around when i speak but nothing translates? trying to make this more hands free. seems like something is registering when i speak it just doesn't convert what i say to the screen,. thanks i advance |
12-16-2023, 02:37 AM | #6108 | |
Rep 1,048
Deftinitly something you should tell them. @ Hotspot, normally this should happen by default but it sometimes can take a minute until it is fully connected. if not, remove the wifi connection from the HU and set it again, there should also be some "auto connect" function within the wifi menu. @ Speech to text, do you have any USB DAC (soundcard) connected to ? If yes, some do have an internal MIC circuit at the Board even when there it no connector for a mic. the Android will automatically switch to this "non-existend" MIC, in this case you need to use a different DAC. If your mic is just such a bad quality you can download a recorder app at playstore to do a quality test. Then you likely need to use an external DAC with a MIC to have proper voice recognition. I did this on my HU and just connect a old iphone headset to the MIC port Also note that the external mic will not work with the HUs phone app as this is hard coded to the internal mic. you would need to cut the wires of the internal MIC in order to get it working on the Phone app. Kri |
12-20-2023, 05:34 PM | #6109 |
Rep 3
Why isn't radio integrated? Can't we store normal FM radio as a button? The radio can be started using the Idrive button. It also works for navigation. Original OEM has radio function too. Why doesn't it work here?
12-21-2023, 03:06 AM | #6110 | |
Rep 2,369
Drives: E63 645Ci
1. These units do not have AM/FM receiver to be able to handle that on their own. 2. If you want to listen to the OEM FM radio while using Android interface, then the audio switching would not work. You are either on the OEM side and have audio switched to CD or radio, or you are on the Android side and your audio is switched to AUX so you can hear whatever sound the Android is playing. You cannot have both at the same time, it's technically not possible. It would be the same as listening to CD and FM radio at the same time - it just doesn't work like that. 3. If you force disable the automatic audio switching, you can listen to your FM radio while in Android interface, but you won't be able to hear anything on the Android side, and you won't see FM radio interface to select radio stations. |
12-21-2023, 04:11 PM | #6111 |
Rep 2
Drives: BMW F20 116D LCI
Hello All.
Congratulations for all the contributions shared on this thread. They are really very usefull. I was another victim of a fake android 10 unit, and after checking the specs with CPU-Z my unit haves: - ARM Cortex A7 1.12 Ghz 4 cores - 2GB RAM - 32 GB ROM - Model 8227L_demo - Manufacturer alps - Android 8.1 Oreo ************** MCU: Z30_B0_Y8_00_210821A VERSION: BMID6_OS_1.36 I am looking for an alternative launcher (with the look and feel of iDrive), where I can do more customisations, as for example, be able to change the automatic gear symbols to manual or even change the rpms of by vehicle from gasoline to diesel once that with the current standard configuration the speed indicator is always higher that the real speed. Alternatively I would be very happy with a tool that allow me to connect to my unit and do this kind of customisations, once that the current version it dosen't allow me to change these settings. I will be much appreciated with all the information that you could share that would be compatible with this processor. Thank you Regards |
12-21-2023, 06:56 PM | #6112 |
Rep 3
Hello Rederik,
first of all thank you very much for your answer. I understand now. But! We can start and listen internet radio (radio app), right? Can't we replace any menu buttons for the radio app? My radio has a SIM card, so I have internet and can listen easily via a radio app. I just want this app to be visible in the front in the main screen and then I can just start it. Other ways take a very long and arduous time. We can also choose which app should start with the music app. Can't we do that with a button that we might not use or want? A radio function belongs in a car. I hope you understood my point. Thank you! |
12-22-2023, 05:56 AM | #6113 | |
Rep 2,369
Drives: E63 645Ci
12-25-2023, 11:45 AM | #6114 | |
Rep 48
12-27-2023, 01:37 AM | #6115 |
Rep 11
Can't upgrade to v4.16 or 4.20 from 4.07
Hello, I have had a Ugode Android Screen Apple Carplay GPS 8.8'' Display For BMW 1/2 Series F20 F23 EVO for about a week. I have found the system to be pretty good apart from an echo during calls. I've been trying to upgrade the software using a pendrive but the system never initiates the update despite the drive being visible. Can someone give me some ideas on what I can do? Thanks
12-27-2023, 07:23 PM | #6116 | |
Rep 4,921
If you see that, select it, and it does nothing, then it's usually an issue with the pen drive. I use an older 8GB stick, and that works perfect. The newer, larger ones I have are not recognized. |
