BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Xdrive...will launching at 6k rpm harm drivetrain?
      07-03-2013, 08:42 AM   #23
dinonz
Drives: 2016 M3 MWM ZCP
Originally Posted by Andy0323 View Post
That's a very nonsensical assumption. I'm sure all drivers who launch their cars regardless of drivetrain layout love their cars.
Awd launches puts less drivetrain stress than 2wd launches due to torque transfer/splitting to 4 wheels opposed to 2.
Evos are an exception due to very small gearlands from the transverse tranny layout. That's why the 5 speed is the choice for tuners. Still, hell of a lot of fun.
Well, my uncle's AWD is an EVO and he still will not treat it like that. But I guess you know more than his rally team though... so it's ok.
      07-04-2013, 01:34 AM   #24
Steve33
Steve33's Avatar
Drives: 2018 SQ5
You are backwards
AWD puts more stress on the drivetrain for that exact reason. It'll find the weakest link and break that part... then the next weakest, and the next, etc. Can't wait for the "Destroyed my drivetrain, will the dealership know I've been dumping my clutch?" thread.
This may be the reason he's had 10 MT's... because they keep breaking
      07-04-2013, 09:15 AM   #25
avantix
avantix's Avatar
Drives: 2019 M4CS Lime Rock Grey
Originally Posted by Steve33 View Post
You are backwards
A wise man once told me to never argue with an idiot. He'll bring you down to his level and beat you with experience.
      07-05-2013, 03:02 AM   #26
Andy0323
Drives: F30 328i
LOL. I don't, but there should be an objective and logical reason why launching an awd causes more drivetrain stress than a 2wd, which is what I don't get (see example below). Why don't you ask your uncle or his chief mechanic for some insight instead of blurting "oh my uncle is a rally driver and he says not to do it"? I'd rather learn than read asinine comments that do not contribute anything towards the sake of this thread. Cool uncle though.
You are backwards
That doesn't explain why awd launches puts forth more drivetrain stress than a 2wd launch. Any drivetrain regardless of layout can break via the chain reaction of the weakest links. Are you insinuating that awd drivetrain parts have weaker pieces than 2wd? I don't think that's always the case.
As mentioned above, I want to learn, so objective and logical reasoning is key here. Let's use a 335i and 335ix as an example. Lets say both cars have 300 ft/lbs of torque, use the same drivetrain pieces (similar transmissions but same gear sizes/lands, same halfshafts, same driveshaft, same bearings, same differentials, etc etc). Now the awd version will have additional halfshafts at the front, but lets say they are the same pieces as the rear halfshafts in material and tensile strength.
For the sake of simplicity, let's ignore drivetrain loss. As each car launches, the 335i's torque splits into 2 (150 ft/lbs per rear wheel), and the 335ix's torque splits into 4 (75 ft/lbs per wheel). Now assuming that all drivetrain parts have similar tensile strength/torque threshold, I don't see why and how 75 ft/lbs per wheel puts forth more stress than 150 ft/lbs per rear wheel?
If the car is tuned to, say.... 600 ft/lbs, the 335i splits 300 ft/lbs per wheel, while the 335ix splits 150 ft/lbs per wheel. How is launching the car with 150 ft/lbs per wheel worse than 300 ft/lbs per wheel?
Lastly, as a stress test for the 600 ft/lbs monster, if each halfshaft has a tensile strength/torque threshold to withstand 300 ft/lbs, wouldn't the 335i's drivetrain be in worse condition (from torque stress) than the 335ix?
BTW... are you dinonz uncle?
And happy 4th (shit... too late), oh well.
      07-05-2013, 08:54 AM   #27
dinonz
Basically Andy, it comes down to stiction. In a 2WD (lets assume square setup in identical cars other than 2WD vs 4WD/AWD for this) you have half the stiction because you have half the contact area of driving wheels on the road. When you get to 6000 RPM and dump the clutch, once the clutch has full engaged you pretty much have maximum torque being transmitted through the drivetrain. What generally happens in a 2WD is this torque overcomes the stiction, the tyres break traction and the torque is released as it were through tyre spin.
If you do the same in a 4WD/AWD the torque might not be enough to overcome the stiction of the tyres, so all that torque is transmitted to the ground as forward motion. The problem is that at the moment of dropping the clutch, you have an engine at 6000 RPM and wheels at 0 RPM and neither one wants to change that rapidly, so somewhere in the middle something has to give. Severe stress will be placed on all parts of the drivetrain as it gets twisted, and 99% chance the part that "gives" will be the clutch which will probably slip a bit to take up the strain, but only once the transmission and every CV/Universal joint have been wound up as tight as they can take without breaking. Until one day they do break.
As they say, a chain is only as good as it's weakest link, and the weakest link in a 2WD is the tyre contact with the road. On a 4WD/AWD though, that's not the case, thus something else somewhere in the chain will eventually give up.
That better Andy? It's difficult to explain on a forum - be easier with a white-board, but that's the general idea.
      07-05-2013, 11:05 AM   #28
Steve33
Steve33's Avatar
Drives: 2018 SQ5
This reply below is perfect. I don't know him
+1
      07-05-2013, 11:13 AM   #29
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
I would suggest doing this to your dealers Loaner car when you get your car into service :P
      07-05-2013, 10:13 PM   #30
avantix
avantix's Avatar
Dinonz......that's exactly what I was looking for. Very well explained sir and it makes sense. I was also under the impression that since the torque was dispersed over 4 wheels instead of just 2 there would be less strain on drivetrain.
      07-05-2013, 10:38 PM   #31
Andy0323
Drives: F30 328i
That makes sense. Thanks for the insight. Here's a beer for you.
      07-05-2013, 11:05 PM   #32
Presario
Presario's Avatar
Drives: 2018 X3 M40i, 2016 435 GC
One of the best explanations I've read about the topic. Thanks Dinonz!
      07-06-2013, 06:15 AM   #33
avantix
avantix's Avatar
+1
      07-15-2013, 12:20 AM   #34
Steve33
Steve33's Avatar
Drives: 2018 SQ5
This is from an AWD that had been doing launches...
      07-16-2013, 01:04 AM   #35
Agamemnon
Drives: 2016 m3 ss2 zcp full leather
A picture is worth a thousand words. The above post is the best argument on this thread!
      07-20-2013, 06:54 PM   #36
ppatel223
Drives: F10 I3.0
Originally Posted by avantix View Post
So I'm really enjoying the xdrive experience in that I don't just sit there burning through first and second gears like my old RWD 335i. I routinely drop the clutch at 6k rpm and boy does this car take off like a bat out of hell. Question is will it likely break anything in the long run?
Think of it this way. Take a hammer, place the hammer on your head gently, this should not hurt. Now apply some pressure on hammer against your head, should hurt little. But now, swing a hammer at your head at about 20 mph, you should get concussion or some bleeding. If you are still with me, apply this analogy to your car.
      07-20-2013, 07:32 PM   #37
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
Depends if there's anything of worth in there LOL.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      08-29-2013, 12:48 AM   #38
t335xi
Drives: 2013 335xi Sedan Sprt Line ppk
Definitely face palm. Op is being a bit of a ass too..Don't ask for advice if you don't want a real answer.
