10-25-2015, 06:08 PM | #23 |
Rep 1,374
Drives: Audi R8 v10 Spyder
I'll let you know when it arrives in the next couple of days
10-25-2015, 09:38 PM | #24 |
Rep 3,089
I am excited to hear your impressions.
10-29-2015, 09:22 PM | #25 |
Rep 1,374
Installing it tomorrow hopefully. It's solidly built with a bit of weight to it. I'll measure the dimensions & weight later.
Here's a copy of the instruction.Created a translated version beneath.
10-30-2015, 11:57 AM | #27 |
Rep 3,089
I doubt it because its position is the same as the stock one so if your exhaust was hitting that it would also hit this one too.
10-31-2015, 12:34 AM | #28 |
Rep 1,374
Got it installed first thing this morning. First impression is less body roll entering a corner at speed, surprisingly it took away the rumble from the start stop.
I have a 3" full exhaust and the clearance is fine for mine. Might try it for a week before giving my thoughts on it. OEM Piece
10-31-2015, 09:52 AM | #29 |
2006 TIME Person Of The Year
9720
Rep 6,445
I installed the F80 brace on my F30, but have since went further and purchased the brace from the F32. The coupe's brace ties in two additional contact points and is pretty inexpensive.
10-31-2015, 10:42 AM | #30 |
Rep 3,089
Did you experience any improvement in handling with the F32 brace? If so, I wonder if adding the CPM brace would further improve things.
11-04-2015, 04:21 AM | #31 |
Rep 9,709
Are those two extra rods to reduce the yaw movement of the subframe during cornering? Are they solidly mounted? Have you noticed any difference?
11-04-2015, 11:55 AM | #32 | |
Fool
1857
Rep 3,542
11-04-2015, 01:09 PM | #33 | ||
9720
Rep 6,445
11-04-2015, 02:11 PM | #35 |
Rep 3,089
glennQNYC did you notice any improvement after you installed the new brace?
11-04-2015, 05:57 PM | #36 | |
9720
Rep 6,445
11-05-2015, 04:33 AM | #37 |
Fool
1857
Rep 3,542
Looks like the F31 and F32 have different part nos for this:
33316861811 is shared with F31, F34 GT and F36: http://www.realoem.com/bmw/enUS/partxref?q=33316861811 33316797444 is shared with F32, F33 and F36: http://www.realoem.com/bmw/enUS/partxref?q=33316797444 Interestingly, the F31 part appears to weigh a bit more than the F32 part but I doubt there's much difference though if both parts fit the F36 |
11-05-2015, 11:03 AM | #38 |
Rep 4,516
I have installed the F80 plate and similar cross brace for F2x series.
I have quaife LSD and JB4 with ~ 400bhp/460lbft and the rear brace positively locates rear subframe to the underbody. More power and QLSD putting more reactions into the rear subframe bushes meant occasionally worming under hard acceleration. With underbody chassis bracing the rear is now much more stable and any and all of the aforementioned wobbles have gone and the car is now even more composed especially over bumpy roads, typical of what we have here in the UK.
Current '22 X3M LCI.. |
11-05-2015, 09:08 PM | #40 |
Rep 159
11-06-2015, 03:06 AM | #41 | |
Rep 4,516
The stock F2x bolts are 3/4" long and the stock F8x bolts are 1" long
11-08-2015, 03:44 PM | #42 |
BMW Fanatic
331
Rep 1,076
Can this be done to X-Drive cars as well? Or is this a strictly RWD upgrade?
Edit: Never mind my question, I just checked a picture of my X-Drive's under-body and the panels look the same.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
11-08-2015, 03:54 PM | #43 |
BMW Fanatic
331
Rep 1,076
Stock 435i X-Drive brace:
11-10-2015, 07:06 AM | #44 |
Rep 186
Hi Glenn, would you be able to post the part numbers for the 2 additional braces?
