BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M-Adaptive (EDC) Delete, Bilstein B8 questions
      03-15-2024, 07:45 PM   #1
Phyrexia
Resident Pedant
Drives: '15 335i 8AT
Hello all.
I'm replacing the OEM EDC struts in my 2015 F30 with Bilstein B8s. Should I retain the m-adaptive sway bar links or should I replace them with the non-adaptive? The M-Adaptive cars have a different part number for the right side, 31306792212, in addition to the part on both sides of a non-EDC car, 31306792211.
Also, I assume nothing special needs to be done with the one side of the car that has the "backwards" sway bar link mount on the strut? Does the slight angle change of the mount not change anything? I guess since it's just a swaybar, the answer is no.
Danke.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
      03-15-2024, 11:55 PM   #2
FaRKle!
If the L/R B8 struts have the same PN then you'll need to change the end link. If you get the xDrive B8 struts (will work for the RWD car), which have different L/R PNs, then your existing end links will work.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
Phyrexia502.50
johnung4528.00
      03-17-2024, 09:48 AM   #3
Phyrexia
Resident Pedant
The shop told me they couldn't install the B8s because "they were both lefts" but I think it's really just that I need a new endlink on one side.
Thank you for the clarification, Farkle.
