BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Subframe Bushing Replacement - Poly or Rubber
      03-18-2024, 09:04 PM   #1
MSPz4
Drives: 2003 BMW z4 3.0i
I’m in the final stages of what has essentially become a restoration job on my 2013 328i Xdrive, and now working on the rear suspension. I have the rear subframe dropped, and will be replacing the subframe and differential mount bushings.
This car will never see the track, it’s my daily driver. I want to minimize any NVH where possible, but would like to improve the handling characteristics. I’ve replaced the rear trailing arms with OEM lemforder, but have upgraded the sway bar to Eibach, and paired with Eibach Pro springs and Koni Special Active shocks.
I’m considering going with poly 95a AKG subframe bushings, and sticking with stock rubber diff bushings.
Will the poly bushings in the subframe alone add much NVH, and is it advisable to mismatch the subframe and diff bushings?
Or should I go with stock rubber all around if this car is dedicated to the street?
Appreciate any recommendations.
      03-19-2024, 03:03 AM   #2
Watsey
Drives: F31 330D sDrive M Sport
I researched and deliberated this for ages with my F31.
The car was already running Ohlins Road & Track, Eiback ARBs, camber plates, poly in the LCAs, and monoballs in the wishbones.
I opted for Whiteline bushes for the subframe and diff and am very pleased with them.
The subframe bushes have made a significant improvement to controlling the rear of the car, especially reducing the roll of the chassis relative to the subframe.
The effect of the diff bushes is less obvious.
The F3X is not a quiet car but I haven’t noticed any increase in NVH.
      03-19-2024, 07:00 AM   #3
Polo08816
Drives: 2014 335i M Sport
I have solid aluminum rear subframe "bushings" now. No noticeable increase in NVH as well. But the rear feels far more planted.
      03-19-2024, 07:58 AM   #4
rlesko
Drives: F30 335i
2012 335i  [0.00]
Would like to clarify, you installed whiteline bushings or inserts?
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
      03-19-2024, 12:59 PM   #5
Watsey
Bushings : https://ukwhitelineperformance.com/c...17-bushing-kit
Diff bushes : https://ukwhitelineperformance.com/c...19-bushing-kit
Very happy with both of them.
rlesko232.50
