07-26-2012, 08:24 AM | #419 |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
thanks for the help.. i will check that out. I remember going past it just didnt look further.
07-26-2012, 02:27 PM | #420 |
Grand Pumba
144
Rep 81
It appears some retrofit shops will code the "Office" functionality into the F30 as this appears to be a simply activation function. I haven't seen anything in the cheat sheet. Am I missing something?
07-26-2012, 02:30 PM | #421 |
Rep 1,309
Drives: YMB M3
@Stokkes..... I have it in my car but had to use the cradle to make it work.
07-26-2012, 04:02 PM | #422 |
Rep 1,309
Drives: YMB M3
has anyone figured out how to make the internet via customer mobile phone option work?
07-26-2012, 09:29 PM | #423 |
Rep 1,309
Drives: YMB M3
Just coded some new options and wanted to share with everyone.
#1. This will change the delay between the front & rear windows going up & down when using the key fob or comfort access(door handle) OPEN FEM BODY / 3053 PwMaster / KOMFORT_OEFF_HINTEN / "lower Werte to desired amount" FEM BODY / 3053 PwMaster / KOMFORT_OEFF_SHD / "lower Werte to desired amount" CLOSE FEM BODY / 3053 PwMaster / KOMFORT_SCHL_VORNE / "lower Werte to desired amount" FEM BODY / 3053 PwMaster / KOMFORT_SCHL_SHD / "lower Werte to desired amount" *** I lowered to 01 which basically makes them go up/down together with very little delay**** #2. This will shorten the time you need to hold the trunk button on the fob for it to open FEM BODY / 30D0 RemoteControl / RC_TIME_DELAY_BOOTLID / "lower Werte to desired amount" *** I lowered to 01 for instant open upon button press *** #3. Turns on the fog lights with the welcome lights (left & right have separate headings) LEFT FEM BODY / 3063 LceLampMapping2 / MAPPING_NEBELSCHW_L_PART_OF_WL / select "soft_on" or "hard_on" RIGHT FEM BODY / 3063 LceLampMapping2 / MAPPING_NEBELSCHW_R_PART_OF_WL / select "soft_on" or "hard_on" Have Fun!!! |
07-27-2012, 08:32 AM | #424 | |
Rep 81
http://x3.xbimmers.com/forums/showpo...1&postcount=45 Your phone will need to have some kind of personal hotspot feature to share it's mobile internet connection. |
07-27-2012, 09:04 AM | #425 | |
Rep 69
07-28-2012, 03:14 AM | #427 |
Rep 40,774
I can help you. PM me.
07-29-2012, 08:48 AM | #428 |
Rep 21
Error- file not found
Hi all. Getting all set to start coding and started downloading the files. I have an F30 and planned to use 46.6. I began downloading. Seems like Part 8 through 18 are coming up with File Not Found errors. Any advice?
Thanks |
07-29-2012, 09:15 AM | #430 | |
Rep 1,309
Drives: YMB M3
I thought about it but decided against because of the LED's. I have changed all of my bulbs out and i have the corona rings so i didn't think they would respond well to that. I think I'm going to add the reverse lights to the welcome as well. might as well light up the entire area! |
07-29-2012, 10:41 AM | #431 |
Rep 145
Drives: F30 320ed
My car has the bi-xexons but i didn't get the visibilty pack so i dont have the adaptive lights with cornering function. I was wondering if it could be coded.
I found in the FEM BODY > 3073LaMaster1,FC > C_AFS_ENA > Kommentar=Switch to enable AFS (adaptive Lichtverteilung) Kommentar: Wird ueber die Lichtverteilungsbotschaft an Scheinwerfer-SGs uebermittelt. Lichtverteilung 0-15. Beinhaltet sowohl alte und neue Lichtverteilungen. Die Unterscheidung ob alte/neue Architektur mit 7/15 Verteilungen erfolgt ueber die Steuerung der AFS-Lookup-Tabels. AFS -> EIN = 1 AFS -> AUS = 0 Voraussetzung: FLC und BLC I enabled this AFS as it was disabled. It says a pre-requisite is FLC and BLC. FLC was already enabled but BLC not so I enabled that. (C_BLC_ENA) I also found FEM BODY > 3073LaMaster1,FC > C_CLC_ENA > Kommentar=Switch to enable CLC (Abbiegelicht) CLC-> EIN=1 CLC-> AUS=0 Voraussetzung: BLC I enabled this CLC as it was disabled. It says also BLC is pre-requisite. So I made all these changes and has no noticeable effect (although it was day light) anyone any ideas. I figured the hardware may be there perhaps not? Also coded off the auto start stop - works a treat |
07-29-2012, 03:44 PM | #432 |
Rep 145
Drives: F30 320ed
Update: I got the corning lights to work (cornering lights via fogs for turns)
I'm not sure if the main headlight function for the curve lights is working though - does this only work above a certain speed? Need to do more testing... |
07-29-2012, 04:27 PM | #433 |
Rep 702
In my car they seem work at a standstill. An easy way to see this at night is to have the wheel turned, and then to shift into reverse. The lights will straighten up when reversing so the movement of the beam is clearly visible.
07-29-2012, 10:33 PM | #434 |
Rep 1,309
Drives: YMB M3
Raspartan is right..they will turn while stopped. I would imagine there is hardware needed to make it work. It seems that it would be very costly to BMW to include that hardware on every car with xenons without charing for it.
do you lights move up and down when the car is first started? Its part of the leveling function that they do upon start up. You would probably need to point the car towards a wall and have the light in the "on" function and not auto. Im not sure but if they don't go up and down i would bet they won't turn either. |
07-29-2012, 11:01 PM | #435 |
Rep 343
Hey can you please let us know the exact steps to get the fog lamps for cornering active like you did ? Thanks man..
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
07-30-2012, 11:45 AM | #437 |
Rep 1,892
07-30-2012, 01:24 PM | #438 | |
Rep 145
Drives: F30 320ed
Might need to compare values with someone who's got it. |
07-30-2012, 01:35 PM | #439 |
Rep 1,309
Drives: YMB M3
I have leveling and active headlights. If someome tells me where to look i will post my values to they can be compared.
07-30-2012, 01:36 PM | #440 | |
Rep 145
Drives: F30 320ed
C_CLC_ENA (switch to F30 enable from Fxx disabled) C_BLC_ENA (switch to F30 enable from Fxx disabled) this is a pre-requisite for above CLC in the notes. KL_ENABLE_LI (switch to EIN from AUS) KL_ENABLE_RE (switch to EIN from AUS) MAPPING_ABBIEGEL_L_OUTPUT (switch to nsw_l from off) MAPPING_ABBIEGEL_R_OUTPUT (switch to nsw_r from off) As usual back up your original settings and make notes of any changes. Currently only seems to work on autolights setting in car - perhaps someone can confirm if thats normal? Do you have the adaptive headlights functional? |
3 series coding, 3 series f30, 3 series f30 coding, 3 series f30 forum, 3 series forum, 3-series forum, 5 series f10 coding, ass, ass disable, auto start stop, auto start stop disable, bmw 3 series coding, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw 5 series coding, bmw auto start stop disable, bmw auto start stop disabling, bmw coding, bmw coding directions, bmw coding diy, bmw coding instructions, bmw diy, bmw diy forum, bmw f10 coding, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 coding, bmw f30 forum, coding 3 series, coding f30, coding f30 3 series, disable ass, disable auto start stop, disable bmw auto start stop, disabling auto start stop, disabling bmw auto start stop, f10 5 series coding, f10 coding, f30 3 series, f30 3 series coding, f30 3 series forum, f30 3-series, f30 3-series forum, f30 coding, f30 forum, f30 forums |
