BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Reverse camera OEM style retrofit for $199 shipped - DIY Details
      09-11-2019, 05:08 PM   #1
330istocknot
Drives: 330chino
Hello,
I recently purchased a f30 328I Sportline without reverse camera.
After doing some research i found a company that has a retrofit for $199. A bit skeptical but i gave it a go, as i have extremely tinted windows and could not see behind me.
This is the kit:
The kit took me about 3 hours to install, and i have to say, i am extrwemly happy.
it comes with a reverse camera that clicks in by the hood latch, looks OEM as heck!
UPDATE: Video of how the rear view camera works in daylight.
Here is a video that shows how bright it is at night:
The reverse camera works with the stock idrive, and also has dynamic parking lines when you move steering wheel.
Here is the link: http://www.carnaviplayer.com/rearvie...-series-p-1222
If you do buy it make sure you use coupon code:free-shipping for 3 day free DHL shipping to USA.
If anyone is interested, i can make a tutorial of it, but it was well worth it!
****BEFORE YOU BUYN READ THIS****
You have to select which version you have: CIC, NBT or EVO.
**IF YOU HAVE CIC YOU WILL HAVE TO MANUALLY CHECK THE PINS TO SE IF ITS A 4PIN OR 6 PIN CONNECTOR.**
Go on your main menu, and compare the red highlight, one is more red, the other is more orange. Both EVO version apply to just evo.
For example, my car has a 6.5 inch screen and i had the NBT menu. so i chose the following:
This is important, as the connector for the screen is different.
HERE IS A VIDEO FROM CARNAVI SHOWING HOW TO REMOVE THE AIR VENTS AND CLIMATE CONTROL TO GET ACCESS TO THE MODULES:
THIS VIDEO SHOWS THE ORDER AND PLACEMENT OF EACH CABLE.
DISCLAIMER: DO NOT FORGET TO REMOVE THE FIBER OPTIC CABLES FROM YOUR ORIGINAL HARNESS AND INSTALL ON THE NEW HARNESS LIKE THIS:
***TROUBLESHOOTING***
If your guidelines are not centered, here is how to adjust alignment"
Originally Posted by OC_F32 View Post
Yes. The guide lines can be moved pretty easily.
-Put the car in reverse
-hold down iDrive knob
-turn knob to move the lines closer/further away from car
-push and hold knob left to right to move lines from one side to the other
Appreciate 9
jh_f301307.00
DarkF3054.00
sthor1022.50
Urbz8.00
EDWYER1674.00
WillSkill172.00
OC_F32118.50
      09-12-2019, 01:25 PM   #2
paul e
Drives: 340i xDrive 6MT
Looks good but be aware:
If your car is Manual transmission, then this product is NOT compatible with your car.
      09-12-2019, 02:00 PM   #3
EDWYER
Yoda of mods
EDWYER's Avatar
1674
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Nice.
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      09-12-2019, 05:31 PM   #4
Elvisfan
Drives: 2018 430ix convertible MGM
Originally Posted by 330istocknot View Post
Hello,
This is the kit:
If you do buy it make sure you use coupon code: free-shipping for 3 day free DHL shipping to USA.
So your rear view mirror is virtually useless? Doesn’t sound very safe to me. Did you buy the car knowing you couldn’t see? Or did you do it?
      09-12-2019, 07:19 PM   #5
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
I don't get it.. rear view mirror is virtually useless? Can you explain this.
      09-12-2019, 08:58 PM   #6
Elvisfan
OP states windows are extremely tinted and can’t see behind him. That’s the reason for the camera. Read the OP’s post.
rudigrr21.00
AndrewC198910931.00
      09-12-2019, 11:19 PM   #7
330istocknot
Drives: 330chino
I purchased my vehicle during the day, and i knew the rear was tinted, but didnt know it was going to affect me this much at night.
The reverse camera has since them helped me out a lot.
Rear view mirror is not useless all the time, just in extremely dark locations.
Pauloxxi339.00
AndrewC198910931.00
      09-13-2019, 06:24 AM   #8
Somebloke
Yes, please......
Thirtye23.00
OC_F32118.50
      09-13-2019, 07:37 AM   #9
jh_f30
jh_f30's Avatar
1307
Drives: 2013 335i Sportline Auto RWD
Great find! I've been wanting the Bimmertech retrofit kit, but it was price prohibitive. Did install require any coding?
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      09-13-2019, 09:50 AM   #10
sthor10
sthor10's Avatar
Drives: BMW F30 328
Waiting to purchase until I see the tutorial, so please do one!
      09-13-2019, 10:05 AM   #11
Gen13 F36
Gen13 F36's Avatar
Who don't have a backup camera? I really thought all F3x came with one.😏
      09-13-2019, 10:59 AM   #12
jh_f30
jh_f30's Avatar
1307
If you do a little research, you'll see that BMW actually didn't make backup cameras standard until 2018, because that's when a federal mandate that all new cars MUST have a backup camera went into effect. Until then, it was optional.
      09-13-2019, 11:00 AM   #13
motofiend
Drives: 2014 Alpine White 328i
Our 2014 328i w/ M-Sport Package didn't come with one. We bought it used, I think it is the only thing our car doesn't have.
      09-14-2019, 09:27 PM   #14
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Hello,
This is the kit:
Thanks, man. Would totally appreciate a tutorial. I just ordered with the code "free-shipping" for $20 off. Likely install next weekend if it arrives on time. I'm interested in running the video cable from the deck to the head unit. Seems like that's where most of the heavily lifting will be.
      09-14-2019, 10:40 PM   #15
jojo7
Drives: F320i
subbed
      09-14-2019, 10:51 PM   #16
SilkySmoooth
Drives: '13 335i MSPORT Estoril Blue
Will this work if I have a standard iDrive? 2013 F30 N55 Msport with NO Nav?
      09-14-2019, 11:18 PM   #17
Elvisfan
It was part of the drivers assistant package on my 16.
      09-16-2019, 11:39 AM   #18
330istocknot
Drives: 330chino
No coding required, it was all plug and play. No error codes and it looks exactly like the retrofit from bimmertech or OEM, even the dynamic lines work the same.
      09-16-2019, 11:53 AM   #19
EDWYER
Yoda of mods
EDWYER's Avatar
1674
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Yes. You need to see if yours in 4 or 6 pin CIC.
      09-16-2019, 01:16 PM   #20
asiansticker
Drives: 2015 328xi
Does the comfort access function still work with this unit?
      09-16-2019, 01:18 PM   #21
OC_F32
OC_F32's Avatar
119
Drives: 2015 428i
Yes. This should not affect comfort access.
      09-16-2019, 03:17 PM   #22
jbb2388
Drives: 2016 F30 340iX
Any shots of the display w the camera activated? Very interested. Only reason I havne;t pulled the trigger on the bimmertech is the $700 price tag
