BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Intelligent battery sensor
      06-22-2023, 07:24 PM   #1
Sookie123
Drives: BMW 2013 335ix
Hey everyone,
i scanned my DME with my scanner and it threw a Cd8f01 code LIN IBS sensor missing.
i check my battery terminal and it looks like the IBS is connected properly to the negative terminal along with the cable that runs to the rear wiring harness.
i ordered a oem replacement off of ebay and just installed it, cleared the code but it still shows IBS LIN SENSOR MISSING.
What should I try now?
      06-23-2023, 03:26 PM   #2
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
Originally Posted by Sookie123 View Post
Hey everyone,
Does ISTA+ have a diagnostic feature for the IBS?
Did you check all the wiring going to the IBS for continuity? Ohm the wires out.
      03-26-2024, 02:23 PM   #3
Sookie123
*********SOLVED*******
there is a small red cable that runs off of the red terminal. it fits onto a pronge. ensure that it is attached to your + terminal on your battery. if the IBS on the negative terminal is still functioning properly this should fix it and remove the code.
fe7565552.50
