09-30-2016, 06:07 PM | #1453 | |
2006 TIME Person Of The Year
9720
Rep 6,445
10-04-2016, 09:56 AM | #1455 | |
Rep 216
10-07-2016, 08:36 PM | #1456 |
Rep 2,197
lo_xyooj57.00 |
12-17-2016, 12:02 PM | #1459 |
Rep 4,449
Drives: '23 X1 28i xDrive
Here's one I've never seen before. I was driving in a funeral procession with my 4-way hazard lights on, but when I hit the turn signal, the car stopped flashing all 4 signal lights, and actually went into turn signal mode. Genius!
12-17-2016, 09:37 PM | #1460 | |
Rep 521
tex26702412.50 |
12-18-2016, 12:22 AM | #1461 | ||
Rep 462
1-GF 2-Mom 3.Sister 4.Dad 5-8 is radio stations
@Menis_F32 2015 435I Msport EWG - Muffler Delete, JB4, E30/40, VRSF Catless DP, Resonator Delete, BMS Intake, H&R Super Sport Springs, VRSF CP, Phoneix FMIC, BM3 STG2 OTS 91 - JB4 BEF
12-18-2016, 08:33 AM | #1462 |
Rep 4,210
But be aware that on my 330e PHEV (and I assume all BMW PHEVs) the gas door is locked unless you press the button on the dash because the tank is pressurized.
01-03-2017, 12:26 PM | #1465 | |
Rep 4,210
My solution was tinted but not polarized sun glasses. Keep a pair in the car. In my case I wear progressive sun glasses and tinted, glare free, high index were not available (at least as far as I could find); but I found that Airwear colors work...but they are polycarbonate rather than high index. If you don't need RX, just look for a good pair of tinted sun glasses. |
01-03-2017, 12:42 PM | #1466 |
Rep 4,210
The only problem with that is if you live in a hot climate, like I do, when you want to leave the sun roof cracked open to let heat escape. So I like manually controlling the sun roof.
01-03-2017, 12:45 PM | #1467 | |
Rep 4,877
You can drive with your head sideways (90 degrees). Then it will be fine. |
01-04-2017, 01:29 AM | #1468 |
Rep 18
I don't believe the windshield is polarized. On the other hand a HUD is produced by reflecting a projection off the windshield. All reflected light is polarized! Unfortunately it's polarization angle is rotated 90 degrees to most polarized sunglasses. That's why rotating your head over rotates your polarized glasses into the polarization plane of the reflected HUD light and why it gets brighter.
I use polarized glass prescription sunglasses so I specifically didn't order the HUD option when I bought my BMW 4 last year. There doesn't appear to be an option to get polarized sunglasses with their polarization rotated 90 degrees. But then maybe if there were they might not work to reduce sun glare, and possibly you also wouldn't be able read digital watches. |
01-04-2017, 09:13 AM | #1469 | |
Rep 521
I don't wear polarized sunglasses partly because tint interacts oddly with polarized sunglasses (something about the adhesive seems to give all windows a rainbow tint when using polarized sunglasses). |
01-04-2017, 09:48 AM | #1470 |
Rep 4,877
01-04-2017, 10:41 AM | #1471 |
Rep 740
01-04-2017, 12:27 PM | #1472 |
Rep 521
The manual definitely states that the windshield glass is special on cars with the HUD. I didn't assume polarization, I just assumed it had a special coating or special material for the laminate that reflects better. You're correct about viewing angle being why the passenger can't see it.. the HUD LCD is actually recessed far enough that there's only a narrow cone of area you can view it from in the driver's seat and behind.
tex26702412.50 |
01-05-2017, 01:24 AM | #1473 |
Rep 18
01-05-2017, 05:19 PM | #1474 | |
Rep 4,877
