BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > E-SYS - "Missing SWEs in PSdZData Directory. [C201]
      04-16-2019, 03:22 AM   #1
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
I'm looking to code a 6WA to my 2014 F30 by following this guide
https://f20.1addicts.com/forums/atta...8&d=1465929213
The 6WA has been virginalised, connected to the car and when on the very last step when I select "Select Software Availability" in E-SYS i recieve the error
Code:
I'm using E-SYS 3.27.1 and PSdZData v.4.16.32_PSdZData_Lite with thanks to shawnsheridan
I've tried moving the contents of
Code:
C:\Data\psdzdata\swe
to
Code:
C:\Data\SWE
but I still have the same error.
Any ideas why this is happening?
Thanks.
      04-16-2019, 03:31 AM   #2
atzebmw
Drives: Tesla Model 3
SWE for flashing are only available in Full psdzdata.
Here the Full psdzdata
https://mega.nz/#F!4lxj2aDQ!MEfV6e0KcYlBu6VAmmJniw
      04-18-2019, 12:24 AM   #3
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
Thanks for the line, took a while to download and extract but got there in the end.
I'm still missing a few files for the flash.
Code:
Missing SWEs in the PSdZData directory. [C201]
BKOMBI_0x60
	btld_00000e4e-007_051_002
	swfl_00000e4f-007_055_100
	swfl_00000e50-007_055_008
	swfl_00000e51-007_055_007
	swfl_00000e52-007_055_002
Would anyone know if there is a workaround or where I could get these specific files?
Thanks.
      04-18-2019, 02:55 AM   #4
atzebmw
Code:
BKOMBI_0x60
Thanks.
These files are very old from about 2013 and psdzdata 3.47.
I think you're doing something wrong.
      04-18-2019, 03:10 AM   #5
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
That makes sense as the pdf I'm using is from around that time.
Would anyone know the up to date way to code 6WA KOMBI?
      04-18-2019, 03:18 AM   #6
atzebmw
Maybe this guide is better....
https://www.bimmerfest.com/forums/at...6&d=1417265707
      04-19-2019, 09:32 AM   #7
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
Hummmm I can't seem to get this to work, I'm hitting the below errors.
If anyone out there would like to offer your expertise and connect via teamviewer I'll more then happily buy you a beer.
Code:
TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
Fatal error while executing tal!
[] - [Exception - UNKNOWN] FA must not be null when trying to execute a TAL containing coding transactions
Asynchrone programming failed! [C049]
FA must not be null when trying to execute a TAL containing coding transactions [1358]
[] - [Exception - BKOMBI - 60] negative response error:
 code: TIMEOUT P2/T2 occurred
 description: P2 timeout on Service RDBI_FTP has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: BKOMBI_60_ETHERNET
 severity: ERROR
ExecutionID=2019/04/19-07:12:41.662
[BKOMBI - 60] - [Exception - BKOMBI - 60] negative response error:
 description: P2 timeout on Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: BKOMBI_60_ETHERNET
 severity: ERROR
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "1min 33s". [C206]
      04-19-2019, 09:40 AM   #8
atzebmw
I'm no expert for flashing ecus, but the error message is " FA must not be null...".
Is there something wrong with the FA (VO)?
Is the 6WA included in the FA?
Was the FA otherwise edited?
And also you can try to reactivate the VCM-Update in the settings.
This sometimes helped for me.
      04-19-2019, 09:42 AM   #9
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
The 6WA wasn't in the FA, I edited to include 6WA before saving. Could this have thrown it off?
      04-19-2019, 09:53 AM   #10
atzebmw
Your question has brought me to an idea.
You changed the FA, but did you also write the FA to the car?
      04-19-2019, 09:54 AM   #11
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
No I haven't written the edited FA to the car, is that required?
      04-19-2019, 10:52 AM   #12
Rich84Ts
Re-Builder
Rich84Ts's Avatar
17
Drives: 320d
OK I'm getting somewhere, I've written the FA to the car with the addition of 6WA.
The Kombi 60 has appeared in the ECU's to be flashed, I'm only selecting "blFlash" / "swDeploy" / "cdDeploy" in KOMBI 60 and I'm not flashing any other CPUs.
When I hit start I can hear all sorts happening in the car and the NBT screen goes blue, promising signs.
after about 3 minutes i hit this error in the log
Code:
[KOMBI - 60] - [Exception - KOMBI - 60] SVK-Ist does not match expected SGBMIDs for ecu ECUId:KOMBI_0x60. Excpected (relevant process classes only): [hwap_00000141-255_255_255, hwap_000010f9-255_255_255, hwel_000009c4-002_107_000, hwel_00000b07-001_109_000], Actual (relevant process classes only): [hwel_000009c4-002_091_049, hwel_00000b07-001_091_012, hwap_000010f9-255_255_255, hwap_00000141-255_255_255], Missing SGBMID(s): [hwel_000009c4-002_107_000, hwel_00000b07-001_109_000], Surplus SGBMID(s): [hwel_000009c4-002_091_049, hwel_00000b07-001_091_012]
TAL execution finished. Duration: "3min 11s". [C206]
Any ideas welcome...
      04-19-2019, 11:02 AM   #13
atzebmw
https://www.bimmerfest.com/forums/sh...d.php?t=809040
      01-23-2023, 03:06 PM   #14
adekborys69
Drives: BMW f30
Code:
BKOMBI_0x60
Thanks.
How did you solve that problem? have exactly same issue and cant code cluster because swe's are missing and cant find them to download , have 2012 f30 and cluster is 2014 thansk for reply
      01-24-2023, 01:08 AM   #15
TheNine90
Drives: bmw
You have to use psdzdata full for flashing.
      01-25-2023, 11:10 AM   #16
adekborys69
Drives: BMW f30
unfortunatelly i have full psdzdata , i think i need to update my i level to match kombi as cant code it and cant flash aswell
      01-25-2023, 12:03 PM   #17
TheNine90
Drives: bmw
What do you mean? You swe files are you missing?
      01-25-2023, 12:09 PM   #18
adekborys69
Drives: BMW f30
im thinking about hu champ , zge and all other modules
      01-25-2023, 12:59 PM   #19
TheNine90
Drives: bmw
Get psdzdata full then you can flash the modules that have an update.
      08-29-2023, 07:13 AM   #20
iliannavy
Drives: bmw f10
Hello.Where I can find these files below.
flsl_000026a3-001_043_020
btld_00007653-023_048_001
btld_000068ac-002_000_002
      08-31-2023, 02:06 AM   #21
TheNine90
Drives: bmw
I cant find any version of the files. It likely the tal has an issue.
      04-13-2024, 03:04 PM   #22
Dafireman12
Dafireman12's Avatar
Drives: BMW i3
Any luck locating these files?
