01-28-2013, 08:26 AM | #2355 |
Rep 40,664
01-28-2013, 09:42 AM | #2356 |
Rep 1,044
BitTorrent transfers
Earlier, I suggested that we should use BitTorrent to share the E-Sys and PSdZData files. This should make it easier on shawnsheridan by lessening reliance on an ISP and should make transfers both more reliable and faster.
Attached to this post are four .torrent files representing the four sets of files I was given access to. You should download the files and remove the .pdf extension, then use them with a good BitTorrent client, either uTorrent or qBitTorrent. I STRONGLY recommend that you use these torrents and DO NOT rely on the http download links you may get from other members. First, it's clumsy to download all the files individually and second I discovered that the http transfers would sometimes not transfer the whole file. It took days to get all the files downloaded correctly. (I have tested the .rars and .exes to ensure they are OK.) BitTorrent solves both these problems and will reduce the amount of noise in this thread from "please send me links" and "pm sent" replies. Bottom line: if you are technical enough to code your BMW, you should be able to download these files, rename them and input them into a BitTorrent client. One more point: as a courtesy to others, PLEASE SEED THESE FILES for the duration. I will seed these long enough for them to get some traction, but if it turns out I am alone supplying bandwidth, I will stop seeding them. With enough long-term seeders, downloading these files should be both fast and reliable.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
01-28-2013, 02:16 PM | #2357 | |
Rep 39
01-28-2013, 03:27 PM | #2358 | |
Rep 18
If the hardware in the car allows, I'd like to still enable: - Live or Internet - Voice control (i have button on steering, but seems not functioning) - Album art from USB I have the following options in SALAPA-Elements: 1CA, 205, 216, 230, 249, 255, 258, 2H3, 2PA, 320, 3DZ, 403, 420, 423, 431, 441, 465, 481, 493, 494, 4AE, 4CE, 4DM, 508, 520, 521, 534, 544, 548, 563, 5DC, 606, 698, 6AA, 6AB, 6NH, 6WA, 7S2, 7VB, 853, 880, 8KA, 8S3, 8SM, 8V1 Car ECUs: ACSM, DME, DSC, EGS, EKPM2, EPS, FEM_BODY, FEM_GW, FZD, GWS, HU_CHAMP2, ICM, IHKA, KOMBI, REM, ZBE2 Any suggestion how to code them? I was changing a few values for Live and Album art, but no success yet. Thanks. |
01-28-2013, 04:13 PM | #2359 | ||
Rep 39
Are you able to physically check underneath the floorboard in the trunk and look for a combox (you simply lift up the floor and pull out the cover in the trunk)? it looks like this http://i180.photobucket.com/albums/x...iri/Combox.jpg Directions to add Album art, Bluetooth audio streaming and white apple USB cable capabilities are here if you have the combox: http://www.f30post.com/forums/showpo...postcount=2041 and http://www.f30post.com/forums/showpo...postcount=2043 |
01-28-2013, 04:21 PM | #2360 | |
Rep 18
I have no combox in the trunk, but as far as I recall, some of the members were able to code album art with similar car config, I just don't seem to find the steps/coded values. |
01-28-2013, 04:49 PM | #2361 | |
Rep 1,044
The forum sysadmin would have to move this post -- and the thread is already a sticky. I don't know of another way to let people know, but when people come here and ask for the files, the best thing to do would be to reply with a link to the post that has the .torrent files in it. That way, when this thread grows to 200 pages, there's likely to be a recent reference to the post in the last couple of pages.
MY18 X3 30i:
01-28-2013, 07:39 PM | #2363 |
Rep 24
I'm have E-sys v 3.22.5 and don't seem to have an EDIABAS folder, i'm a little clueless as to why it didn't come packaged with the E-sys v 3.22.5?
and how do i get it? |
01-29-2013, 03:53 AM | #2364 |
Rep 40,664
Because the assumption is you started with 3.18.4, which included EDIABAS, and that you were up an running already so that all that was needed was the updated E-Sys.
01-29-2013, 07:53 AM | #2365 | |
Rep 490
01-29-2013, 12:06 PM | #2366 | |
Rep 1,044
Thanks for helping out. We're about 48 hours into this and so far, I haven't seen any other seeders. It may be early, but it looks like people are just downloading then stopping. This isn't "the BitTorrent way." This is a community: if you download the files, you should give back some bandwidth in the form of seeding.
MY18 X3 30i:
01-29-2013, 02:01 PM | #2367 | |
Rep 1,544
Voice control is I think not possible cos it needs the presence of combox. |
01-29-2013, 04:49 PM | #2368 | |
Rep 39
Are people actually downloading from the torrent? Is there a download count? |
01-29-2013, 06:53 PM | #2369 | |
Rep 1,044
MY18 X3 30i:
01-29-2013, 07:15 PM | #2370 | |
Rep 490
01-29-2013, 09:31 PM | #2372 | ||
Rep 94
01-29-2013, 11:14 PM | #2373 |
Rep 7
Hello.
I've coded a FEM_BODY. Then, the door is now locked automatically start running. I do not have code there. What would I do I undo. E-sys3.18.4 48.2 Last edited by hirokouji; 01-29-2013 at 11:28 PM.. |
01-29-2013, 11:26 PM | #2374 | |
Rep 1,892
Go to Settings -> Door Locks and clear the "Lock after start to drive". Some other settings may have changed too. Sometimes when I code, I first save the profiles to a USB stick, then code, then restore the profiles. Also, sometimes my mirror positions get reset. |
01-30-2013, 08:27 AM | #2375 | |
Rep 7
Are there any coding to set the default item of "Lock after start to drive" way? |
