04-28-2015, 11:16 PM | #67 |
Rep 29
Sure,
The stock ECU has checks and balances in place and will run the maximum boost pressure/ignition timing for the fuel it has. The car's knock sensors will detect pinging when it occurs and adjustments are made at the millisecond level. Utilizing the stock ECU gives the added benefit of using all the stock safety parameters and "asking" the ECU for more power. If it can't make the power safely it will bleed boost or pull timing depending on the severity of knock just like it does with the stock calibration. Our tune on an F13 M6 for example using a 91 octane tune makes an additional 50whp+ when it runs race gas. Not sure if this link works but here it is at shift sector where he beat every other tuned M5/M6 at the event: https://www.facebook.com/JoweKyuLee/...3778842186111/ If you pay attention to some of the dyno videos or dyno graphs out there for the FXX cars, you will see some dyno runs where the car doesn't rev out all the way and starts backfiring/spitting flames before hitting redline. Although it looks cool it's the ECU going into component protection mode. This can happen when the ECU sees more boost than it's asking for in the various boost control maps and when the car tries to bleed boost and is unsuccessful it will close the throttle and dive extremely rich causing the backfiring and flame spitting. This also causes the dreaded "drivetrain malfunction" code that pops up. This happens a lot on the dyno but it also happens on the street you just are less aware. In DCT cars it will upshift very early when it detects this type of problem and in a manual it will just not rev out. We make a proper tune where the car is not surprised by how much boost or ignition timing it's getting and it prevents these issues from arising and is much more consistent than utilizing a piggyback. Also if you log the car you will see that power up top suffers severely from IAT increase, the stock turbo isn't very efficient up top so if you couple a tune with down pipes and an intercooler you will be in a whole new world. Go to a reworked turbo and these will be killer cars capable of taking down the CLA45 AMG's. Hope that explanation makes sense. |
05-01-2015, 04:10 AM | #68 | |
Rep 1,436
so if your flash lets the car handles everything even with boost higher as you explained and I will not see car slower or same as stock in very high temperature (reaches 45 degree Celsius) then that's defiantly on my list more priority than the turbo upgrade
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
07-04-2015, 11:14 PM | #69 |
IG @bmwF9xG80
3813
Rep 7,593
PedM5 any updates?
60-130mph 6.5s X4M #HCP
11-05-2017, 06:46 PM | #74 |
Rep 397
This was BPC DME tune only at the time.
2016 BMW 328i M Sport 6MT (Mineral Grey over Coral Red)
*BPC DME Custom Stage 1 Tune *Evolution Racerwerks Competition Intercooler & Chargepipe *M Performance Big Brake Kit |
CalCarNut1060.50 |
11-08-2017, 06:26 PM | #75 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
jailbreaktuning@gmail.com for Matt @ HD Tuning (new name)
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
