01-18-2017, 10:54 PM | #1 |
Rep 953
Map 1 vs Map 5
Hey guys, I just got my car to finally be FBO. Have the injen intake, ER: cp, dp, fmic, and jb4 with an exhaust. So with these mods, what map should I be using? Don't have access to 93 octane so map 2 is a no go (tried doing map 2 logs, car didn't like it)
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
01-19-2017, 11:47 AM | #2 | |
Rep 239
Do you calibrate caliberate your jb4? Whenever I switch maps or refill on gas I'll floor the pedal in 3rd from about 2500rpms to redline. After the 2nd or 3rd time doing this you will notice the turbo kick in much harder. Also, post your logs if you can. Map 5 is cool, but I much prefer maps 1 and 2. More linear and predictable. Also map 1 feels faster than 5, and 2 feels faster than 1. Last edited by BMWtight2me; 01-19-2017 at 12:19 PM.. |
01-19-2017, 01:45 PM | #3 |
Rep 190,777
Map 5 is for 320 application not 328
Use map 1 Full list of maps Map 0: JB4 disabled. Map 1: PWG models absolute target 21psi peak, EWG models additive 4psi peak over stock. Map 2: PWG models absolute target 22psi peak, EWG models additive 6psi peak over stock. Map 3: Progressive Methanol Injection. Requires BMS methanol kit or BMS FSB for meth pump control. Map 4: Stock performance, JB4 on Map 5: Absolute targeting map with a peak boost 17psi. Suitable for 320 & 520 applications. Map 6: User definable absolute target map. Suggested for troubleshooting by professionals only. Map 7: Race gas absolute target map. Peak boost 23psi. This is a fairly aggressive map and increases engine damage risk. Use with caution.
01-19-2017, 02:15 PM | #4 | ||
Rep 953
01-19-2017, 04:07 PM | #5 | |
Rep 953
