02-25-2013, 03:51 PM | #353 | |
Rep 1,997
Drive it the fun way and that's pretty normal (well if it's 50% hwy, still a bit low). But my first tank or two I got in the low 20's, but that was because I was having a bit too much fun with the new car. I usually make a fairly conscious effort to baby it because it makes such a difference in gas mileage and am usually around 25mpg with mostly city driving. I have some weird deal with seeing how good mpg I can get... But when I stomp on it for fun, it's amazing how much it drinks. One 2 mins spirited run will drop the mpg a good 2 mpg for the whole tank. |
02-25-2013, 04:02 PM | #354 | |
Rep 1,297
02-25-2013, 04:32 PM | #355 | |
Rep 1,997
The fun you have while driving is inversely proportional to the mpg in this car. The bigger my smile the lower the mpg. But most of my driving is to and from work and thinking I just want to go take a nap during those drives (and better mpg). When I'm joy riding, I only look at the mpg for amusement. Guess you pay to play in all things! |
02-26-2013, 12:58 AM | #356 | |
Rep 7,047
When optioned and equipped equally the weight difference is only about 100lbs, nothing like "hundreds" of pounds. More like 1 hundred pounds. Yes, the 335i has a more powerful engine, but, if one is not using or calling on that power, then they are not burning that fuel either. Given that the AT in either model has the same gearing, the biggest difference will come down to how aggressive one is with acceleration. If a 328i AT accels hard from every red light in the city while a 335i AT is accelerating slowly, the 335i will get better MPG. If both vehicles have equivalent sized drivers, and both drivers drive in the same day to day manner, meaning not aggressive all the time, then both cars will get MPG very close to each other. If it takes 150hp/150lb ft of torque to accel from a light at the same rate, then either engine will need to burn the fuel required to produce that power. That means they are burning about the same amount of fuel. The N20 isn't going to burn a lot less fuel than the N55 to produce the same 150lb ft of torque. There is no free lunch here. To produce a given amount of power either of these engines will burn about the same fuel, as they are both pretty efficient. The bigger difference will come when the N55 driver wants to accel faster and stronger than the N20 driver. To do that the N55 engine will then burn more fuel as it can produce more power. All these 30+MPG average in the city claims are simply BS. If they are real, then you've got a mile long line of honking cars behind you and an even longer line of people passing you trying get where they are going with reasonable acceleration. 30mpg avg in the city your car would look like a turtle accelerating where only you and maybe 3 other cars will get through the green light before it turns red. The ONLY true and accurate method to get average MPG is to do a manual calculation, and a running average over tankfuls. Fill your tank until the pump stops on it's own, do NOT add more. Reset miles driven. Drive normally as you do. When you get down to about 1/4 tank or less, fill up and STOP filling when the pump stops. Now, take the miles driven and divide by how many gallons you just put in. That's your real avg MPG. Repeat to get a more accurate MPG reading. |
02-28-2013, 11:11 AM | #357 |
Rep 1,447
I was under the impression that bmw driver didn't care that much about mpg when I first started that topic but due the popularity of it I'm thinking different. I mostly started it in order to get some input.
03-11-2013, 08:04 PM | #359 | |
Rep 1,997
Both are efficient engines pushing about the same weight around so it makes sense. 100lbs on a 3500lbs ish car is almost negligible in most normal driving situations as far as mpg is concerned. Now if you were about pushing them to their limits and everything else is equal, weight will make a difference (when 1/10ths of a second count a lot) I'll happily drive my 335i all day long as it gets great mileage and when I push the skinny pedal it goes. |
03-11-2013, 08:20 PM | #360 | |
Seismoguy
Rep 180
I should have read the forums here more meticulously and picked up the extra 60 hp and prestigious split tailpipe. |
03-11-2013, 08:36 PM | #362 |
Rep 710
In my view if 328 and 335 produced the same exact output, their fuels consumption should be fairly equal. As one of the posters said, there is no free lunch. 328 has a 4 cyl 2 litre engine with about 18 psi of turbo boost. 335 has a 6 cyl 3 litre engine with around 8-10 psi turbo boost. More boost = more power = more fuel burn
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
03-11-2013, 08:53 PM | #363 | |
Rep 662
03-11-2013, 09:19 PM | #364 |
Rep 204
I just got 32.28 mpg on my last tank of gas. The car says I got 33.7. Which is really closer to real world than I thought the gauge would be.
2013 328i sport line. 446 miles, most of which were interstate. 1260 on odometer. |
03-11-2013, 09:34 PM | #365 |
Seismoguy
Rep 180
Thanks, I'm partly being facetious, as the 328ix is great, and if a 335 clacked less and rumbled and zoomed more, I'd never get it away from my wife. Although maybe I need a second car.
03-11-2013, 09:42 PM | #366 |
Rep 28
I just did a round trip in my 335xi from just south of San Francisco to Tahoe for a day of skiing and then back to the same starting point. Some details:
Total miles: 418.6 Average speed: 67.5 mph (this includes the stop and go traffic, city driving, coffee stop, subsequent pee stop, fuel stop. Most of the highway driving was ~75-80) Driving mode: almost all Eco pro except for a few moments of full acceleration in sport Traffic: about 2 miles of heavy stop and go, the rest no real traffic. All except about 15 miles was highway. Elevation: started and ended at just about sea level. Dinner pass is about 7000 feet and the ski resort parking is about 6500. Total mileage on the car/engine: 1790 at end of trip. Mileage: 34.5 mpg over the entire round trip. I'm very impressed. Just for comparison, my last tank with mostly city driving was about 21 mpg. (Note all numbers from idrive rather than from the fuel pump so might be a little optimistic, depending on how curate the car is) Last edited by 4wheelspin; 03-11-2013 at 09:48 PM.. |
03-11-2013, 09:47 PM | #367 | |
Rep 1,997
On the return trip, with about 40 miles of back country roads and the rest interstate, where I may or may not have followed a pack of cars above 90mph and topped 100mph a couple times in a 20 min span, my mpg hurt a bit and I "only" got a tick over 30 mpg. (yes it holds true, the harder you push the pedal the more gas it drinks). I should also note, I did a 'test' intending to determine if 89 octane got less than 93 and yes I got lower mpg with the 89 but I also drove quite a bit harder, so I failed my own test. A 328 is a great buy for various reasons, but choosing it over a 335 primarily for mpg probably isn't a well informed choice. Last edited by tdizzle; 03-11-2013 at 10:09 PM.. |
03-11-2013, 09:52 PM | #368 | |
Rep 1,997
One day I'll try using ecopro more than a couple miles to see if it makes a difference. I use comfort 99% of the time and sport+ when I have the opportunity/desire. |
03-12-2013, 12:15 AM | #369 | |
Rep 30
03-12-2013, 09:39 AM | #370 | |
Rep 1,997
03-12-2013, 12:33 PM | #371 | |
Rep 309
03-12-2013, 12:48 PM | #372 | |
Rep 3,780
Boost is not the only thing that indicates consumption. A lot of it is the demand of the fuel injectors. On my E36/7 I have gone from 19lb injectors to 42lb injectors. I can match my non boosted MPG, but if I am maxing out the injectors, well there goes that one. When not on boost, the N55 is feeding much larger displacement which offsets its lower boost compared to the N20. Like I said previously, I have a loop on the way to work where I test economy. Its fairly consistent, and I get 39.9mpg in the N20 6mt and 35.5mpg in an 8spd N55. Granted, it would be interesting to see both engines consumption at WOT, as they might not be that far apart. But most of the time these cars are driven at part throttle or coasting which means the N55 is always 3.0L and regardless of boost, the N20 is 2.0L.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
03-12-2013, 05:46 PM | #373 |
Rep 176
Drives: G20 M340i
Trust me its accurate, I do feather the pedal quite a lot though. And I usually use Eco Pro, also I've got nearly 14,000 miles! My entire commute is also in the city so I rarely use the highway. I never reset the computer either, but its usually reset at the dealer.
'19 X3 30i Black Sapphire W/ Mocha
(Current) '21 M340i Portimao Blue W/ Black/Blue (Current) |
03-12-2013, 07:36 PM | #374 | |
Rep 710
