BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 M Sport steering wheel retrofit
      07-20-2014, 01:39 AM   #1
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
I just put down an offer for a brand new F30 M Sport steering wheel which includes the airbag and from my research, it retrofit is pretty much plug and play.
Does anyone know if I'll have any problems with compatibility or fitment on a North American spec'd F30? The steering wheel is coming from the UK and I'm not sure if left hand or right hand drive makes a difference.
I checked the part number 32 30 7 848 338 and it seems like it is used in all markets including the US.
Also, this steering wheel comes with the paddle shifters. Will it be easy to get these working?
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      07-20-2014, 09:25 AM   #2
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
You noted that you're ordering a wheel from the UK that comes with the airbag. There's a problem. The North American one has the airbag part number 32307845798 while the European one has part number 32307845797. Think it has to do with the Single and Dual Stage ones.
In terms of the paddle shifters, you need to order a new connecting line (wire) for the steering wheel and may also need to add an additional wire somewhere. Though some F30s may already be prewired. There's a thread on it.
      07-20-2014, 09:38 AM   #3
steve@codemybimmer
Hong Kong
665
Good call. I cancelled the offer since you pointed that out. The steering wheel itself seems to be the same worldwide but it didn't make any mention of the airbag.
I'm going to have to see if I can get the airbag somewhere else with that part number.
      07-21-2014, 02:17 PM   #4
steve@codemybimmer
Hong Kong
665
Just bought one that has the correct part numbers. Thanks Timbits!
Hopefully it'll arrive next week and I can see how it looks with my saddle brown interior.
      07-30-2014, 09:36 AM   #5
steve@codemybimmer
Hong Kong
665
Here it is !
      07-30-2014, 09:39 PM   #6
SIDG335
Drives: 2015 335i xDrive M Sport 8AT
How much did you end up paying for it? Wondering what it could go for. Thinking of selling mine when my car comes in and picking up the Carbon/Alcantara steering wheel.
      07-30-2014, 10:55 PM   #7
steve@codemybimmer
Hong Kong
665
It was $1500 USD shipped to Canada. The first one I saw was only $900 but it wasn't the correct airbag.
Thanks to Timbits93, he gave me the part numbers and I ended up getting the correct one.
If yours is in good condition, you might be able to get rid of yours for $1000 at least.
      07-31-2014, 08:19 AM   #8
SIDG335
Yeah it would be brand new as it would be removed before delivery. My only hesitation is whether the Alcantara wheel would wear with daily use.
      08-07-2014, 08:48 AM   #9
speed608
Malawi
28
Drives: F30 320d
Hi Aritaurus, does this retrofit require any coding after installation or is it just Plug & Play.
      08-15-2014, 02:13 AM   #10
iastute
Drives:
Did you also have to get the additional wire for the paddles to work? Eager to know as I will be following your footsteps...
TIA!
      08-19-2014, 12:07 PM   #11
Bvt13
Drives: 2016 AW M4
2016 M4  [0.00]
Interested in this as well. Would love to hear the steps required to make this functional.
      08-19-2014, 01:34 PM   #12
nyczyar
Drives: F30 335i
Are all m steering wheel heat compatible?
      08-19-2014, 03:43 PM   #13
steve@codemybimmer
Hong Kong
665
TIA!
My friend helped me run the extra wire from one of the connectors on the steering ring over to FEM_BODY.
After that, you just need to change 205 to 2TB on your FA and VO code FEM_BODY, GWS, ICM, KOMBI, EPS and EGS with E-Sys.
Not sure if we're allowed to post links from other forums here but there's a post with the pinout and instructions. I'll shoot you a PM if you want to have a look.
      08-19-2014, 03:45 PM   #14
steve@codemybimmer
Hong Kong
665
I never had the heated steering wheel so I had nothing to lose. You can always get the heated version and I'd assume it would be plug and play. All the connectors are exactly the same to the non-M Sport steering wheel so minus the paddles, you can get everything working without the need to code anything.
Just make sure you get the proper airbag as mentioned by Timbits93 earlier.
      08-20-2014, 01:39 PM   #15
nyczyar
Drives: F30 335i
Oh I see. What about the shift paddlers? My car already have them, will it be plug and play?
      08-20-2014, 07:04 PM   #16
steve@codemybimmer
Hong Kong
665
Yep, just take out the airbag, unscrew the steering wheel and undo all the connectors, bolt the new steering wheel on and plug everything back in. No coding or wire cutting required.
      08-21-2014, 12:14 PM   #17
nyczyar
Drives: F30 335i
Oh I see, so is it possible to get a steering wheel without paddlers and just use my own instead?
      08-21-2014, 12:22 PM   #18
steve@codemybimmer
Hong Kong
665
I honestly haven't seen anyone retrofit just the paddles without changing out the steering wheel but if you just get the M sport one that has the paddles then it's plug and play.
      01-13-2015, 07:32 PM   #19
acebrigade
acebrigade's Avatar
Drives: 2014 320i
you used the original hex bolt from your car? it looks like they're different on the M tech
      01-13-2015, 08:36 PM   #20
Sladester100
Sladester100's Avatar
Drives: F30 320d & G29 M40i First Edtn
I remember reading somewhere with a change of airbag (from standard sport to M-Sport for instanace as you've done) you need to have the car re-coded for that... Cant remember which post but it was on here somewhere :-\
F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
G29 M40i First EditionFrozen Orange
      01-14-2015, 12:10 PM   #21
steve@codemybimmer
Hong Kong
665
The only coded I did was what was needed to get the paddles working. The Air Bag should be plug and play as I did scan my ACSM module after and it didn't come up with any errors.
On my FEM_BODY module however, I do get a "Steering Wheel - wrong version installed error" which can only be read if you have a code reader or ISTA.
      01-14-2015, 12:12 PM   #22
steve@codemybimmer
Hong Kong
665
Nope, it's the same hex bolt.
