05-24-2014, 10:38 PM | #1 |
Rep 89
Error when trying to code KOMBI
Can anyone help??
Getting an error only with KOMBI, everything works fine... Using Esys 3.24.3. Coding anything else works fine. Error Code: Transaktions-Report: Aktion: Codierdaten lesen KOMBI [60] [F720116] readCPS o.k. cafd_000009c8-006_000_030 Fehler: NCD read from ECU "ECUId:KOMBI_0x60" for CAF "cafd_000009c8-006_000_030" failed! [C069] Error processing XML data [1660] |
05-25-2014, 07:15 PM | #2 |
Rep 40,720
What are you using for your Target Connection?
06-01-2014, 08:16 AM | #3 |
Rep 637
Same error just trying to read KOMBI CAFD
I have just got my coding cable and was doing some backups to ensure everything works before purchasing my token.
I too am getting exactly the same error message (albeit with a different VIN) I have the following software as provided by the links you PM'd me: E-Sys 3.24.3 psdzdata lite 52.3 No token as yet I can read FA, VCM and can read all the CAFD's apart from the one under KOMBI. I have a 2014MY (NBT with iDrive Touch) F30 manufactured in July 2013 My Target is: TargetSelector: Project=F020_14_03_503; VehicleInfo=F020 Connection via VIN: WBA...._DIAGADR10 My I-Step (for all 3 boxes) is F020-13-07-501 Any advice or further checks I can do to identify the problem. --- update, just looked at the files in psdzdata folder for the cafd number and spotted that all files have pretty much the same time stamp apart from the one relevant to this CAFD read which is failing: C:\data\psdzdata\swe\cafd>dir *9c8* Volume in drive C is System Volume Serial Number is 1EC2-4B8F Directory of C:\data\psdzdata\swe\cafd 27/03/2014 20:26 694,017 cafd_000009c8.caf.004_001_012 27/03/2014 20:26 694,149 cafd_000009c8.caf.004_001_013 27/03/2014 20:26 691,423 cafd_000009c8.caf.004_002_007 27/03/2014 20:26 697,231 cafd_000009c8.caf.004_002_023 27/03/2014 20:26 699,759 cafd_000009c8.caf.004_002_024 27/03/2014 20:27 772,867 cafd_000009c8.caf.005_000_028 27/03/2014 20:27 773,197 cafd_000009c8.caf.005_000_029 27/03/2014 20:27 773,237 cafd_000009c8.caf.005_000_030 27/03/2014 20:27 774,405 cafd_000009c8.caf.005_000_051 27/03/2014 20:28 1,081,372 cafd_000009c8.caf.006_000_027 27/04/2014 21:59 1,080,686 cafd_000009c8.caf.006_000_030 27/03/2014 20:28 1,081,082 cafd_000009c8.caf.006_000_031 27/03/2014 20:28 55,281 cafd_000009c8.caf.006_000_047 13 File(s) 9,868,706 bytes Last edited by PaulT_M5; 06-01-2014 at 08:26 AM.. Reason: Added extra info regarding files |
06-01-2014, 08:18 AM | #4 |
Rep 40,720
Let me connect with Team Viewer and look at it.
06-01-2014, 09:10 AM | #6 |
Rep 40,720
Not sure why really, but injecting newer CAFD version into Kombi solved the problem.
Onizukachan1082.00 |
06-01-2014, 09:17 AM | #8 |
Rep 40,720
No problem. Free help isn't exactly a "service", though.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 06-01-2014 at 07:27 PM.. |
ReMiii4021.50 |
06-11-2014, 03:07 AM | #9 |
Rep 21
Hi chaps
I'm getting the same error. What exactly do we mean by injecting a newer version into KOMBI? does it involve changing the file in swe\cafd named cafd_000009c8-006_000_030? or do I need to get a newer version of the one I am trying to code? I have tried selecting code on the KOMBI ECU. I've tried read code and deleting fld and adding a new one. All get the same error. Thanks for your time. |
06-11-2014, 03:14 AM | #10 |
Rep 21
Found this from the man himself ShawnSheridan on bfest. Amazing what searching does eh!? Sorry chaps...
You need to try and inject new CAFD into NBT and then Code it: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on HU_NBT => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level => Select OK => Right-Click on HU_NBT (the ECU itself not the underlying CAFD) => Select CODE. Gonna try this and get back to you all. |
06-11-2014, 11:07 AM | #11 |
Rep 21
No dice...
Any ideas? I don't think i am doing the right thing though when it says select cafd from latest istep. I see many folders and lots of numbers. I picked the one with a higher number than the one i have. This was against KOMBI by the way, not HU_NBT as this copy says. Is this right? arghh Apologies for my grammar, I'm balancing the lappy on my steering wheel. |
06-11-2014, 12:18 PM | #12 | |
Rep 40,720
06-11-2014, 12:31 PM | #13 | |
Rep 1,892
I reverted back to 2.52.2 and was able to read / code his KOMBI without error. Later, I compared all of the 52.2 vs 52.3 CAFD files and found that the cafd_000009c8-006_000_030 file is different between the 2 versions. it was the only file that was different. I did a binary compare of the 52.2 vs 52.3 cafd_000009c8-006_000_030 files and found that although both files contain exactly the same number of bytes, the 52.3 version is all NUL (0x00) bytes!! Oops! There's no useful data in there at all! So, I'm back to using 52.3, but I just copied the 52.2 version of cafd_000009c8-006_000_030 into the 52.3 directory. To me, this technique is easier than trying to inject a new CAFD into the KOMBI. |
06-11-2014, 12:52 PM | #14 |
Rep 40,720
If you happen to have your previous PSdZData version lying around (most don't), you are right that it is easier to just replace cafd_000009c8.caf.006_000_030.
If you do not have previous PSdZData version lying around , it is much easier to just inject a new CAFD into ECU than find a download location for previous PSdZData version and download a 5.6 Gb file and extract it to get one CAFD from it. To make it real easy, here is cafd_000009c8.caf.006_000_030: cafd_000009c8.caf.rar.pdf Remove .pdf from file name and Extract CAFD, and copy to ...\psdzdata\swe\cafd folder overwriting existing one.
07-23-2014, 12:33 PM | #15 |
Rep 10
hi shawn,
while today I am retrofit(CC) my f20 , after VO Coding, I try to code kombi , ICM, Fem. I recieved error at KOMBI section. e-sys 3.25.3 pszdata 2.53.0.5 Then I couldn't fdl coding or read coding data e.t.c . I try to fix with ''Detect Caf for swe'' no result :/ my error report as you ve seen: http://postimg.org/image/6a00hmj1v/ what should I do ? |
07-23-2014, 05:37 PM | #16 |
Rep 40,720
CIC Retrofit should have no impact on Kombi coding.
What happens when you try and VO Code Kombi with E-Sys 3.23.4 or 3.24.3 instead of 3.25.3?
07-24-2014, 04:07 AM | #17 | |
Rep 10
I dont have any admiration for using 3.25.3 If I recieve better performance, I can use 3.23.4 or 3.24.3. I just one question; Can I use current patch and token for them ? |
07-24-2014, 04:54 PM | #18 | |
Rep 40,720
Did you modify your FA for CC Retrofit? If so, are you able to code Kombi with factory original FA? And did you first try what I wrote above in Post #14? http://f30.bimmerpost.com/forums/sho...5&postcount=14
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-24-2014 at 08:50 PM.. |
07-25-2014, 01:29 AM | #19 | |
Rep 10
Ok, I will downgrade to 3.24.3, Can I use same patch or token ? I've completed code KOMBI. I ve coded with ''Detect CAF SWE'' I ve choosen .502 instead of .506 . But while another ECUs coding succesfully, why did I forced to apply this steps for KOMBI? |
07-25-2014, 01:44 AM | #20 |
Rep 40,720
Becuase .506 CAFD not compatible with ECU SWFL. ECU would need to be flashed to use newer CAFD.
No, Token solution is entirely different for 3.25.3 than older E-Sys 3.24.x versions.
07-25-2014, 02:13 AM | #21 |
Rep 40,720
After looking at this some more, the cafd_000009c8.caf.006_000_030 file is simply corrupt. It won't even open in E-Sys CAFD Viewer, yet cafd_000009c8.caf.006_000_031 opens just fine.
The solution here is to inject a different CAFD file into KOMBI: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on KOMBI ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level that is not cafd_000009c8.caf.006_000_030 => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
