BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F30 Drivetrain Malfunction - Related to BMS Stage 1 Tuning?
      04-03-2013, 01:08 PM   #1
FrozenDarkness
I noticed that I started getting drivetrain malfunction warnings when I floor the car. Once it hits around 6000 RPM, I get that notification and it gets into limp mode. I've read around about this problem and it seems like everybody has a different conclusion about it (BMW remains mum and says it's a solenoid issue). However I'm freaked out as I've been using stage 1 for a couple weeks now and have to bring the car in.
I obviously will remove the piggy back and have faith that the dealership won't find anything. My biggest concern is that my N20, first production build (2011 November) just doesn't have what it takes to use the BMS Level 1 or that I seriously fucked up the drivetrain somehow.
http://www.f30post.com/forums/showthread.php?t=776020
was the thread i found
except i wasn't going from automatic to manual when this happend, i was just flooring the car.
      04-03-2013, 03:02 PM   #2
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Very hard to know if its the tune. We have seen such malfunctions on cars driven off the showroom floor. Just the luck of it sometimes.
Will be interesting to see what the dealer comes back with.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      04-03-2013, 05:04 PM   #3
unintelligible
Computer Janitor
unintelligible's Avatar
Drives: '12 F30 328i
Have to ask the obvious here... have you removed the tune, and if so, is the check control message still occurring? Seems like it would be easy to test. If it only happens with the tune installed, you might be out of luck unless the dealership finds a bad injector or something.
2012 328i Sport Line 6MT (Turned In)
2015 Ford Mustang GT Premium (Current)
      04-03-2013, 06:12 PM   #4
FrozenDarkness
ya testing this tonight. gave the dealer a heads up as well, they told me that "the car could be reprogrammed to allow you to floor the car. the car wasn't originally programmed with this in mind"
we'll see man, we'll see.
      04-03-2013, 06:36 PM   #5
Jamesons Viggen
What? That sounds like BS to me.
Never heard of a car that was not intended to go WOT and needed programming to properly allow for it.
      04-03-2013, 07:30 PM   #6
ixse
Drives: 2015 boxster s
Lol another clueless dealer bs.. wasn't programmed for wot.. lol gotta be one of the best I've heard so far. Do not let that dealer touch your car..
      04-03-2013, 08:24 PM   #7
David328M-Sport
Australia
101
Guesswork only causes undue stress. Don't guess, gather the facts in a clear headed manner. What if this / what if that???? What if you are stressing for nothing? My Stage 1 BMS has been issue free since install late Feb.
Ok, there are some engine coding parameters like turbo boost responsiveness available for adjustment, but should only be carried out by fully trained & authorised BMW service tech, who knows what he is doing. With so many variations, it's plausible, maybe.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      04-04-2013, 01:05 AM   #8
FrozenDarkness
I just tested the car without the BMS Stage 1 Tune and it revs just fine on standard (albeit much slower). I'm hoping I can figure this out soon, but it's not looking like happily ever after for me and tuning
going to bring it in anyway
      04-04-2013, 12:31 PM   #9
jokerswld34
Drives: 2019 BMW M760li
2019 BMW M760i  [0.00]
same thing happened to me a few thousand miles in. one day i was driving and got the malfunction light. stopped and shut car off. tried driving again and was in limp mode and very, very sluggish. Took off the bms and drove to the dealer. car seemed much better without the bms but still not 100%.
My issue was some faulty intake sensor or something along those lines. Dealer did not mention any codes other than the drivetrain malfunction (sensor) and the car was fixed in a day.
      04-04-2013, 01:04 PM   #10
FrozenDarkness
I'm hoping Mike can tune in on this since I'm sure BMS did extensive testing for this issue.
      04-08-2013, 04:39 PM   #11
FrozenDarkness
just brought it in, keep everybody updated on the status
      04-08-2013, 10:35 PM   #12
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
I got a drivetrain malfunction error today
I had my tune for 2 to 3 months and everything was fine up until today.
I was driving and when I floored it in sport+ mode to pass a truck and as soon as I passed him I got the drive train malfunction warning and the car went into limp mode and had to pull over...embarrassing level over 9000...
I called the dealer and they suggested if I could make it in safely then drive it in instead of waiting for a tow.
I took it into the dealer (with the tune still on) and they took a look at it.
the dealer I go to is modding friendly so I wasn't concerned at all
they spent almost 3 hours looking at the car and said they found nothing wrong with it but dont know why the car was in limp mode..
then they took out my bms and reset my batteru and viola...out of limp mode.
test drove it for 5 to 10 minutes and nothing was wrong.
then I drove back to the dealer to tell them that nothing is wrong and they helped me reinstall my bms and drove it out again.
within 2 minutes drive train malfunction and went into limp mode again...
so the dealer concluded it was tune causing the drive train malfunction
they assured me there's absolutely nothing wrong with my car though
I'll be interested to hear what your dealer finds
      04-08-2013, 10:42 PM   #13
Chris@codemybimmer
I havent tried installing the tune into another car to see if it has the same effect but as of now I can't tune my car =(
      04-08-2013, 11:41 PM   #14
Spikey
Australia
64
Drives: erratically
^Wow your dealer is really mod friendly, wish that was the case everywhere
      04-09-2013, 06:28 AM   #15
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
BMW's throw fault codes all the time with and without tunes. There are thousands of codes possible for every little system. Read the code which will tell you what is wrong with your car. If you need additional assistance with a code you can always email the details to me or BMS for their advice on it.
Mike
      04-09-2013, 07:43 PM   #16
FrozenDarkness
Thanks for offering Mike!
The dealer got back to me and said they replaced the vacuum hose. i don't actually know what a vacuum hose is and everything i read online seems to relate to it helping the brake system. Do you guys know what's going on?
      04-10-2013, 08:45 AM   #17
Jamesons Viggen
Turbo cars have a variety of vacuum hoses, a leak of such a hose is a big pain on a modern car as it causes a vacuum leak and often a check engine light.
      04-10-2013, 09:59 AM   #18
328cnx
Drives: F30 328i
Seems like the Bms not really relialable!
Anyone else has negative experience??
      04-10-2013, 10:08 AM   #19
Jamesons Viggen
Umm, if you READ this thread, the BMS had nothing to do with a vacuum leak.
      04-10-2013, 10:24 AM   #20
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
BMS's tunes are about as reliable as they come. These are very sophisticated cars, sometimes things go wrong. BMS is a solid company.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      04-15-2013, 01:39 PM   #21
FrozenDarkness
well the wait is over! I put the tune back in after they replaced the tube and everything looks a-ok. i'm super excited!
      04-15-2013, 03:50 PM   #22
David328M-Sport
Australia
101
Great to know. Enjoy your Stage 1 boost properly now.
