      02-23-2013, 12:16 PM   #2773
XmX32
Originally Posted by Frogman View Post
I can't add any more than whats in the "E-Sys - Getting Started Coding - Part 1.pdf" document. You need to follow it EXACTLY.
If you have gotten to the point where you have been able to edit the values, then:
1. save the changes to disk.
2. Press the Back Arrrow button
3. Activate the FA (right click on FA and select "Activate FA".
4. Make sure the correct underlying CAFD file (yellow) line is selected (it may move after activating the FA).
5. Click on Code FDL.
When it's done, make sure the summary window says "0" errors on the title.
i'm not sure what was wrong but i just turned everything off and back on, did the same thing i was doing before and it all worked perfectly thanks a lot for your help. I do have two last questions. Do you have any experience with the M HUD and the speed limit info? they are not marked as working on the cheat sheet. Is there any danger in activating them and seeing what happens?
      02-23-2013, 12:27 PM   #2774
Frogman
Drives: 2012 F30 328i
There probably isn't any harm in trying, but nothing is risk free. You can always VO code an ECU back to the factory settings, so the risk is minimal.
We're pretty sure that none of the M_HUD stuff will work without an M-Cluster.
You can try SLI too, but a lot of talented people have tried without success. Something about having to have the right camera and possibly needing an FSC code too.
Same with the HUD turn signals. They work on the F10's, but we have not had any luck getting them to show on the F30 HUD.
Experiment away if you want to and please post your results!
      02-23-2013, 01:03 PM   #2775
10nelyboi
Drives: 2012 - 335I
I'm new to this forum and still learning about code, will some 1 be kind enough to summary a few key points on what I need to code my car ? from what i have read after spending hours in this thread, i would need the Enet cable, which I'm planning to make it myself, which program would I need (which version ) and what about all ViN numbers and password ,I have a 2012
33i Luxury line with tech and premium package.
thank you.
PS : I m located in So Cal, if some is kind enough and willing to show me to code in person, I will come to you and of course pay you for your time
      02-23-2013, 02:24 PM   #2776
Frogman
thank you.
I'm in So Cal (Ventura County) too and have coded many F30's. Send me an e-mail at frogmanf30 at gmail dot com if you are interested.
You just missed the coding meet we did last weekend!
See: http://www.f30post.com/forums/showthread.php?t=798492
I've also had many people come here for coding if you don't mind the drive and don't want to wait for the next meet.
BTW: I don't do this for money, I do it for the BMW community and to give back for all the hard work that other people have put into making this available. I will accept Lunch though!
      02-23-2013, 05:25 PM   #2777
venkata
venkata's Avatar
Drives: F30 330e MSport
Hi, I have an F30 Msport on order here in the UK (BW10) and expecting delivery end of March. Presumably E-Sys 3.18.4 and PSDZData 2.46.3 will work fine???
Driving: F30 330e
// /M-Sport | Mineral Grey | Coral Red Leather | M Sport Plus Pack | Media Pro Plus Pack | Active Security Pack | Adaptive LED Lights | Advanced Parking Pack | Interior Comfort Pack | Enhanced Bluetooth with Wireless Charging| Black Performance Grill | Heated Seats | Heated Steering | Speed Limit Display
      02-23-2013, 06:18 PM   #2778
Frogman
2.46.3 is way too old for a new 2013 F30. You will probably have at least 2.48.3.
You'll need a new token and patch to use 48.3. PM shawnsheridan for details.
You should probably go to E-Sys 3.22.5 (after first installing 3.18.4) as it seems to load much faster than 3.18.4 and is more current.
      02-23-2013, 10:39 PM   #2779
raj10800
Drives: G20 330i
Hi Frogman, I am located in India..can you do remote coding or help me in coding?
      02-24-2013, 12:35 AM   #2780
Frogman
Sorry, I don't do remote coding. I don't actually code other peoples cars, I just let them borrow my cable and laptop and walk them through coding their own cars. That teaches them how it's done if they want to do more on their own, shows them some of the wonders of the internals of the car, and it removes the issue of the responsibility if something goes wrong.
As far an helping, this forum is all you need to help you get started coding. I can't add anything to help you that's not already here.
      02-24-2013, 12:35 AM   #2781
10nelyboi
Drives: 2012 - 335I
I sent you an email, let me know your thoughts. Thanks for doing this for the community
      02-24-2013, 12:45 AM   #2782
Frogman
Got it.
      02-24-2013, 02:06 AM   #2783
venkata
venkata's Avatar
Will do thanks Frogman
Driving: F30 330e
      02-24-2013, 05:28 AM   #2784
raj10800
Drives: G20 330i
Is anyone in this forum from India who knows coding.
      02-24-2013, 05:41 AM   #2785
dos1973
pin code
Hi all,
i didn't code a while and forget the Pin code when starting.
Can someone tell it to me please :-)
Thank you
      02-24-2013, 09:26 AM   #2786
shawnsheridan
shawnsheridan's Avatar
Originally Posted by ykau View Post
Hi Shawn,
Can teach me how to read 1B from my car using E_sys?
thanks
You just need the SWID Reader Program, which works with EDIABAS.
SWID Reader for reading 001B FSC file. Rename file from .pdf to zip
Download: SWID_reader.pdf
I have found a way to do this in E-Sys, but I assure you it is a royal PIA.
      02-24-2013, 09:30 AM   #2787
shawnsheridan
Hi Shawn, Kom another forum member told me that since I am in India and BMW does not offer BMW Assist here, I do not need fake VIN to activate BMW Live, internet, etc as in my case data will be used from my mobile device with data tethering turned on. Is this right? If yes then what are the steps to activate.
The steps are identical, but you don't have to change the VIN.
That said, whether you have BMW Assist to not, you still need a VIN with factory 614 and 615.
      02-24-2013, 09:48 AM   #2788
shawnsheridan
...as it should be....
      02-24-2013, 12:45 PM   #2789
martianpc
Drives: 2013 335i
We should really try to put together a google doc or wiki or something that is updated with everything we can do and how. This thread is getting a bit hard to keep up with.
2013 MG 335i
      02-24-2013, 12:58 PM   #2790
shawnsheridan
      02-24-2013, 06:29 PM   #2791
martianpc
Drives: 2013 335i
We could use this for sharing codes
https://docs.google.com/spreadsheet/...lE&usp=sharing
Nothing in it yet besides basic layout. However anyone can add to it or update it. How does everyone feel about something like this to keep organized? If we can get it together maybe we could have it added to the first page, or sticky on the DIY page.
Thoughts?
2013 MG 335i
      02-24-2013, 06:42 PM   #2792
shawnsheridan
Thoughts?
I don't think codes are the issue.
ilhan1103 keeps this one online, and I think it is current:
https://docs.google.com/spreadsheet/...Ia3ZmbUE#gid=0
      02-24-2013, 06:50 PM   #2793
martianpc
Drives: 2013 335i
So maybe a Wiki would be better. I was not aware of that Doc, somehow I missed it. Great to see though.
2013 MG 335i
      02-24-2013, 07:01 PM   #2794
Yobyot
Yobyot's Avatar
493
Drives: MY19 X3 M40i
A tip: I find that Activating the FA FIRST is less bothersome than doing it when trying to code the FDLs. You can activate the FA anytime -- I do it before I start searching for things to change.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
